Old 02-06-2015, 03:15 AM   #26
mechanicalman
Re: Stripped out tranny cooler lines in new rad... :(
Originally Posted by weever82 View Post
Such thing as brass fittings where the lines go into the radiator instead of just alluminum?
Maybe, see my post above and after examination of the cooler/fitting on the radiator you may be able to determine if you can use a 1/4" pipe tap and install the brass fittings like come in a transmission case. Keep in mind when drilling (if needed) or tapping you might ruin the cooler to the point that it leaks coolant externally. That being said, I'd try to drill minimally.
Might be safer to get a bung welded on, but that might still have to be aluminum. Worst case scenario, if you ruined the cooler to leak coolant externally, would be to put a pipe plug in it top and bottom to seal it then you would have to run external only.
Oops, not above, but previous page.
mechanicalman is offline   Reply With Quote
Old 05-25-2016, 03:02 PM   #27
72bowtiestepper
Question Re: Stripped out tranny cooler lines in new rad... :(
I know this is a old thread, but the specs. for the champion radiator say that the coolant line threads in the radiator are 1/2" -20.....not the right size for the stock flare nuts on the coolant lines. Maybe that's why some of you are stripping the threads ???
72bowtiestepper is offline   Reply With Quote
Old 05-25-2016, 03:52 PM   #28
leddzepp
Moderator
leddzepp's Avatar
I installed a champion radiator a few months ago and the tranny cooler lines fit fine, no leaks either. Fingers crossed
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 05-25-2016, 04:19 PM   #29
72bowtiestepper
Thanks for your reply...good info. I'm thinking champion changed the thread size on the newer models.
Old 05-25-2016, 04:25 PM   #30
Willie Makeit
Willie Makeit's Avatar
Originally Posted by JCD View Post
Standard thread size on a trans line radiator seems to be 5/16 inverted flare, -5 AN.
You may try and run a 5/16 -5 AN tap into it to clean up the threads..
If that won't give you enough thread to grab the line nut, tap the radiator with the next size up bottoming tap, -6 AN and get/make yourself an adapter..
Here's a good place to start for an adapter fitting, they may be able to suggest a fitting and tap you can use.
http://www.summitracing.com/search/d...apter-fittings
J.
-5 AN is 1/2-20
Willie Makeit is offline   Reply With Quote
Old 06-01-2016, 08:55 AM   #31
1969C10t
Same here new 4 row champion. Nice radiator for the money except the internal trans cooler is why I went with this brand. Now I get the impression they don't think I know how to install inverted flared fittings. Looks like I am going to have to drill and tap.
1969C10t is offline   Reply With Quote
