#26 |
Re: Best rear gears for 700r4
I have one of each. A 3.73 and a 3.42. If you have a 3.73 in your truck your 700r will work well. If you are going to change the gear ratio I would recommend the 3.42 ratio. It is the best overall package!
![]() Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
#27 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
#28 |
Ćall Randy's ring and pinion. They can tell you what options each axle has. My guess is you can use what ever axle you currently have.
#29 |
72 GMC
#30 |
No but it kind of defeats the purpose.
#31 |
If you're going to pull/haul anything heavy, running a 700R4/4L60 in 3rd (direct drive) is a good idea. Once you're on the roll, up shift to OD- kind of like a boat coming up on plane. If you're doing stop-n-go, up hills or extremely heavy loads, keep it in 3rd. Fuel mileage sucks, but it should be cheaper than a new transmission. Saw way too many in the trans shop, and it was brutal. If you're pulling heavy stuff, all the time, run a 4L80- they're made tough to play rough.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
#32 |
Just be sure to lock the converter (I have a switch to manually lock the converter in 1st,2nd,or 3rd) if you stay in 3rd pulling or hauling anything heavy.
I often ride the back country roads in 3rd, I lock the converter and its just like a straight drive accellerating and slowing (engine braking).
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
#33 | |
The Older Generation
Thanks Kevin.... I checked with my local independent mechanic and he said it would run around $100 to install the gears. I'm not sure I want to invest $300 to put 3.42's in the Burb... I'm just a tight a$$ I guess... ![]() LockDoc
#34 |
425hp409
![]() Join Date: Oct 2008
I have 3.73s in my 68 C10 and also in my 77 GMC Sprint with a built 454 and they both work great. About 2100 rpm at 70 mph..
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
#35 |
saginaw i now thats for 3 on tree what is saginaw mean
#36 |
Looks like 3:73 is the most common but 3:42 would be the ticket. How hard is it to change out the gears to get a 3:42? Anybody in the waco, temple, or Killeen area willing to advise and or demonstrate? Lol....
Posted via Mobile Device |
#37 | |
Its a Truck Thing......
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
#38 |
You can get 3.42s from a common and cheap (if not free) later rear. That's what I did,and my ring & pinion needed replaced anyway. If not for having no O/D for now,an possibly never,I'd run 3.73s or 4.10s just because I prefer gears with grunt and O/D allows that. I have two trucks,the ones I drive most,with 4.10s & O/D. The tires are tallish (both 4wds) and I can run along 75 mph all day no problem. For me,3.08s "is" O/D. It's too tall to go with O/D,IMO. 3.42 is the sweet spot for with or without O/D
#39 |
Found a 2004 chevy z71 with a 3:42 I can get the ring and pinion from, will it fit my rearend in the 70 model?
