09-14-2013, 11:29 PM | #26 |
Re: Something wrong...feels expensive.... Need help
Other than the nasty fluid, the rear diff seems ok. Does it takes a gasket? Posted via Mobile Device
1973 Chevy K20 |
09-14-2013, 11:29 PM | #27 |
#2 Posted via Mobile Device
1973 Chevy K20 |
09-14-2013, 11:39 PM | #28 |
Ok, so who knows and trusts a transmission shop in San Diego?
1973 Chevy K20 |
09-14-2013, 11:42 PM | #29 |
Looks like tranny needs some help. Maybe trans pulled for some reason and when it went back in, converter wasn't seated properly. As for the rear, yes it takes a gasket, although folks have used RTV also.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
09-15-2013, 12:12 AM | #30 |
Is that brass? If so that's the main shaft bearings getting eaten alive. Mine is doing that but still has survived to this day. Mines way worse
That would be why it doesn't want to apply reverse. It's leaking internaly Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
09-15-2013, 12:13 AM | #31 | |
09-15-2013, 12:15 AM | #32 |
Can anyone tell what diff I have and how much fluid it takes?
1973 Chevy K20 |
09-15-2013, 12:16 AM | #33 | |
1973 Chevy K20 |
09-15-2013, 12:44 AM | #34 |
Diff is a 14 bolt. Not sure how much fluid. Good rear though.
09-15-2013, 09:15 AM | #35 |
Just here to tinker
If that is in fact a posi, you need to add gear oil plus a 4oz. Bottle of friction modifier. And do not buy the pre-mixed stuff. It is not the same. Also, as for the gasket, I use a product called "the Right Stuff". It is what most OEM's are using as well instead of paper gaskets. Much better than RTV and you can use it right away.
All these things should be available at your local parts store. Posted via Mobile Device
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
09-15-2013, 10:05 AM | #36 |
This is also the diff I have. What is it? Do I need posi lube? Was told it was a locker...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-16-2013, 01:10 AM | #37 |
Another Day, Another Dollar
I tore the reverse band out of the case on my 400, did the same thing
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
09-16-2013, 07:27 AM | #38 |
Watch out for your cornhole !
The pictures in posts number 23 and 24 look like a Turbohydramatic 350 pan to me.
Posted via Mobile Device |
09-16-2013, 10:10 AM | #39 | |
here is a chart
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
09-16-2013, 10:13 AM | #40 | |
There is a plug on the right side where the driveshaft attaches, take the plug out dump in some 90wt gear oil till it starts to come out.
09-16-2013, 10:16 AM | #41 |
x2 it's on its way out, I had a th350 the same thing, a fluid change got me a few more miles but ultimately it ended up like this... totally smoked.
09-16-2013, 02:17 PM | #42 |
capt. i think i see the problem. thats alot of metal in there. if it where me i would be looing for a well built 700. a 700 is a 400 with over but they where built cheap so they dont like power same as the dodge 47re. its a 727 with over. there are a few comps out there that will build a 700 well and they are not cheap but then again no trans is
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
09-16-2013, 02:27 PM | #43 | |
09-16-2013, 03:38 PM | #44 |
Ok, so I've been getting quotes on a trans swap from the TH350 to a 700R4 of about $2400
Is that right?
1973 Chevy K20 |
09-16-2013, 05:39 PM | #45 | |
yea that would be the hd 350 i think gm called them 375. but then what is the 200r4 based off of? i was always told 700 was a 400 200 was a 350. or at least base off of them
09-16-2013, 06:43 PM | #46 |
Its based off the Th200 or th250.. I can't remember. Essentially the little brother to the th350. My 79 nova (250 motor) has a Th250.
Trevor 74 C20...work in progress. 04 Saturn Ion...Daily Driver |
09-16-2013, 07:05 PM | #47 |
09-16-2013, 07:23 PM | #48 | |
A TH375 is a light duty version of a TH400....Fewer clutches & 27 spline output. The HD version of the TH400 is a TH475/3L80-HD. The 4L80E is based on a TH400. The lower-end (Center support & down) of a 700R4 is the same as a TH350, The rest of the 700R4 is a "Clean sheet design". Though the front pump is a off shoot of a 2004R. The 2004R is loosely based on the TH200, The Low/reverse, Direct, & Forward clutch assembles are a lot alike. |
