Old 04-03-2015, 12:47 PM   #26
SS317
SS317's Avatar
Re: 4.8L Turbo Build
Man, sweet work. I've been toying with a turbo when I upgrade my tired 350. Mostly because I haven't done one and I think it would be cool.
1966 Chevy C-10
350 Engine
700R4
SS317 is offline   Reply With Quote
Old 04-03-2015, 01:44 PM   #27
69trk
69trk's Avatar
Looking good... looks like your using the same headers that im using...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 04-03-2015, 02:55 PM   #28
1bad396ss
I certainly appreciate the compliments.
I cannot take credit for the excellent tig welding on both the stainless and aluminum. That was all done by a buddy of mine. He is a top notch welder (does all of our sanitary stainless welding at work as well). Even the bracing and boxing of the frame for the downpipe pass-through is welded like it is on display!
A couple pics of welds to enjoy!
1bad396ss is offline   Reply With Quote
Old 04-03-2015, 04:42 PM   #29
tinydb84
tinydb84's Avatar
Man that looks great and I love the turbo mount!
David
Instagram: myfabguy
Old 04-03-2015, 04:52 PM   #30
1bad396ss
Thanks again. Only minor trimming of the inner fender to fit as well and puts the gate outside of the engine compartment.
Getting close to firing it up. Figured it would be nice to get a heat cycle through it and check everything out before the body is finished (that's my plan anyway).
The most accurate thing I have read here when building a turbo setup is take your budget and multiply it by 2 if you are conservative or 3 if you are realistic!!!
Old 04-05-2015, 04:36 PM   #31
BigRed76
BigRed76's Avatar
What headers are you using?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 04-08-2015, 11:22 PM   #32
1bad396ss
The headers are some cheap up and forward headers I found on Ebay; however, they seem to be built fairly well. We did cut the v-bands off and shorten the headers a bit so the 90's off of them could fit properly in the space allowed.
Old 03-12-2016, 02:13 PM   #33
1bad396ss
Progress!!! Down to the color sanding stage. Hope to get it back this month. Thought I would throw up a couple pictures.
I don't know why I even had a budget for this build!!! Dang fun things are expensive.
Old 07-19-2016, 02:34 AM   #34
12secondnova
12secondnova's Avatar
Researching stuff for my tt 4.8 build and came across your truck. It is absolutely AMAZING. Nice job man
12secondnova is offline   Reply With Quote
Old 07-21-2016, 10:55 PM   #35
1bad396ss
Appreciate it. Unfortunately, it isn't much further along since late March! I do have the bed wood all in, column, shift linkage, drive shaft, and breaks installed. Need to do a massive amount of wiring and get this thing on the road.
Been busy and haven't been on lately. I'll have to post some more pics.
Good luck with your build.
Old 07-27-2016, 06:46 AM   #36
'72 Pro Street
Good looking truck! I like the color. I'm in process of finishing up my 5.3 turbo build. Got a question where did ya mount the coil packs? Thanks!
'72 Pro Street is offline   Reply With Quote
Old 07-29-2016, 02:48 PM   #37
1bad396ss
Coil packs are mounted inside the frame rails (basically between the front cradle and where the front shock mount nut sits in the frame). Just made custom length wires from there to each plug.
Old 08-02-2016, 07:36 AM   #38
'72 Pro Street
OK thanks! That's where I ended up mounting mine too. I just need to get it tuned now. Can't wait to drive it lol
