Old 09-22-2013, 02:53 PM   #26
79Betty
79Betty's Avatar
Re: Shimming after swap?
Truthfully i don't know... Looking... One to alternator and one to resistor are spliced into 1 and eye looped on starter bolt on top woth battery cable. Other goes to hei
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 09-22-2013, 04:03 PM   #27
geezer#99
geezer#99's Avatar
According to my manual you should have the black from the battery to the big terminal, a red to your altenator, a red to the junction block (you call it a resistor), both from the big terminal and the purple wire to the solenoid.
What's this other wire with the eye and where is the one to the hei hooked to?
Old 09-22-2013, 04:07 PM   #28
79Betty
79Betty's Avatar
Wifh the eye one goes to alternator other goes to junction block. Hei is hooked to the right terminal
Old 09-22-2013, 04:42 PM   #29
geezer#99
geezer#99's Avatar
Hei shouldn't be hooked to the right terminal. It should have it's own red wire from the ignition switch. THat's why your staerter won't quyit running.
Old 09-22-2013, 04:43 PM   #30
79Betty
79Betty's Avatar
I'll double check when i'm home. Weird thing is whywould this only happen after i swapped transmissions and cabs?
Old 09-22-2013, 05:14 PM   #31
geezer#99
geezer#99's Avatar
THe previous wiring in the other cab likely had a bad ignition run wire that the PO fixed by running to the starter. You changed that and fixed it in the new cab wiring.
Old 09-22-2013, 05:17 PM   #32
79Betty
79Betty's Avatar
That would make sense. I'll check it good when at home. Been aggravating me so bad thought about going back to automatic lol. Another mind always helpS think about things
Old 09-22-2013, 05:31 PM   #33
dfj73
It may have the wrong starter drive in the starter seeing as you put a new flywheel and could be different from the old. It probably stays engaged because it's stuck on the flywheel.
dfj73 is offline   Reply With Quote
Old 09-22-2013, 05:37 PM   #34
79Betty
79Betty's Avatar
One starter come off a 77 c30, one off a 77 c10, and one off a 79k10. All 3 get stuck when starting. Btw geezer my hei plug goes into the firewall harness not starter. Starter wire on right post goes to... Junction on to right side big one. Smaller one goes to alt and firewall, included pic!
Old 09-22-2013, 05:49 PM   #35
dfj73
Does the wire have power in the run position?
Old 09-22-2013, 05:50 PM   #36
79Betty
79Betty's Avatar
Which wire?
Old 09-22-2013, 06:14 PM   #37
79Betty
79Betty's Avatar
Well little fact. I put in my 78 k20 harness put of old cab. Plugged in ignition switch, turn signal switch and grounded it... Now only clicks... Yea
Old 09-22-2013, 09:21 PM   #38
dfj73
This really is a weird problem seeing as you've tried different starters and harnesses, There should be three wires on the starter the battery the cab supply and then the ignition wire which only has power on start. The clicking starter means solenoid no good but it was just working with the other harness. I think you need to chase back the ignition wire to make sure you only have power in start
Old 09-22-2013, 09:31 PM   #39
79Betty
79Betty's Avatar
Idk. It's making me so mad i'm thinking about putting my turbo 350 / np203 back in just to drive it. Auto column with k20 harness just clicks... But it acts like it's trying
Old 09-23-2013, 06:20 PM   #40
dfj73
I wish I were there i could help you out but hard on this side of the computer. I just find it hard to believe it's not the actual starter giving you problems. If you don't have power at the solenoid when in run and when you kick the starter and it click then the wiring is fine, Know what I'm saying?
Old 09-23-2013, 06:22 PM   #41
79Betty
79Betty's Avatar
Yea as that was last night lol. I took my 77 dually wiring off the motor and plugged it in to the firewall and everything else. Going to see what happens. Not like anything else has for the good lol. Will post result
Old 09-23-2013, 07:23 PM   #42
79Betty
79Betty's Avatar
Well well. With all 77 wiring, STARTER STILL GRINDS!!!!!!! Ugh! Don't think it's the flywheel since it's brand new... What else could make a grinding ugly noise?
Old 09-23-2013, 08:57 PM   #43
dfj73
it cant be meshing with the flywheel correctly, try shimming the starter down some and see if that helps at all
Old 09-23-2013, 09:25 PM   #44
79Betty
79Betty's Avatar
I'll try mortow after work n see what happens. Got a new ignition switch for column today so that eleminates that possibility all together.
Old 09-23-2013, 09:29 PM   #45
dfj73
if its grinding I'd think the wiring is alright
Old 09-23-2013, 09:34 PM   #46
79Betty
79Betty's Avatar
Well all the wiring is from a 77 c30 which i started and drove home so i think so too. This is very frustrating
Old 09-23-2013, 09:39 PM   #47
dfj73
I'm frustrated for you honestly, I know how it is when you just want to drive
Old 09-23-2013, 09:45 PM   #48
79Betty
79Betty's Avatar
Not much ya can do but keep chippin away at it. I just hope i get it lined up before my flywheel gets fubar
Old 09-23-2013, 09:50 PM   #49
dfj73
Try the shims and hopefully that works. I'm hoping at some point I can get my truck out of my garage but winter is coming and the frames not even painted yet
Old 09-23-2013, 09:52 PM   #50
79Betty
79Betty's Avatar
I painted mine from the motor back woth rubber paint like flex seal. Took to it awesome hasn't scratched and covered one can per side. Motor forward was covered in oil so bad water just runs off it lol
