09-21-2013, 04:25 PM | #26 |
Re: 400 sbc
I'm back! Without a block but he's holding it for me everything looked great! Cylinders not pitted. Theres a SLIGHT ridge but .020 overbore will clean them up for sure. I believe the whole code was 395-509 . I may be wrong on a number. It was grimey but I cleaned up the parts I needed to look at. The main caps still had their bearimgs and they still looked good. Slight normal wear. It is in fact 2 bolt. I wish I had the money to put down on it!! The steam holes were all clear and looked good..no cracks. The oil pan ridge was clean and looked great. Just some machine work to clean up the bores and deck (which looked good) and shell be good. Ill also hot tank it and magnaflux it just in case. As for parts..I've considered a set of aluminum vortec heads he has for it. If money allows..a set of Dart heads will be going on it. Camshaft will be a Comp cams xtreme energy of some sort. Ill be getting just a cast crank..but if I can find a good forged ill go for it. Overall I'm happy..just gotta get the money!
Posted via Mobile Device |
09-21-2013, 10:19 PM | #27 |
Re: 400 sbc
No idea how many times i've been in that situation... With a dually dana 60 lol
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
09-21-2013, 11:21 PM | #28 |
Re: 400 sbc
There's no such thing as an aluminum vortec head. If they have no markings, they're probably ProComp.
Run, Forrest, Run!!! |
09-22-2013, 07:42 AM | #29 |
Re: 400 sbc
Lol ill probably just stick with the Dart heads then Even though there's no aluminum vortecs..ya figured for as long as they were on vehicles that they would have made the switch. Nowadays a lot of heads are aluminum. I just need to find a good machine shop around now.
09-22-2013, 03:26 PM | #30 | |
Re: 400 sbc
http://www.edelbrock.com/automotive_...perf_rpm.shtml Just an FYI otherwise no marking alujerbin (lol) heads are a crapshoot Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
09-22-2013, 03:59 PM | #31 |
At the body shop.
Re: 400 sbc
Ive beat the the crap out of cast cranks. Wrecked every other part of a 400.
" That didnt make it any newer " " Dont antique the equipment " |
09-22-2013, 04:48 PM | #32 | |
Re: 400 sbc
09-22-2013, 06:21 PM | #33 |
Re: 400 sbc
As for a clean up boring to get rid of the edge at the top..should I just bore enough to get rid of it or should I just do a .030 over?
09-22-2013, 06:26 PM | #34 | |
Re: 400 sbc
09-22-2013, 08:25 PM | #35 |
Slugish
Re: 400 sbc
Yea , I just did a post on rear main seal replacement on my 400 . Its bored 40 over , 274 comp cam , alum heads etc etc . strong running engine after approx 12000 miles. Only problem is those damn leaky rear main 2 pc seals .
And yea , its been dogged plenty & take it to the 1/4 mile track occasinally. I would definitely take the pan off & replace the seal while the engine is out . Might save you a lot of aggravation down the road. |
09-22-2013, 09:53 PM | #36 | |
Re: 400 sbc
09-23-2013, 07:21 AM | #37 |
Re: 400 sbc
Edelbrock E-tec heads are Edelbrock E-tec heads, not Vortecs. They are marketed as Edelbrock E-tecs, not Vortecs. They may be similar and use the same bolt pattern, but Vortec is a GM trademark.
Aluminum Vortec-style heads, there are a few, but none that can call themselves "aluminum vortec heads". I know it's nit-picking, but there are so many knock-offs that try to jump on the bandwagon and use the name for profit with absolutely no R&D, specifically ProComp. |
09-23-2013, 02:03 PM | #38 |
Re: 400 sbc
Should I just go ahead and pick up the set of heads he has for it? I know that stock vortecs have issues with valvespring clearance
09-23-2013, 08:04 PM | #39 |
Re: 400 sbc
215cc Iron Eagles or even Brodix entry level aluminum heads would make for a torque monster that would hang on to 6500 if you needed it to. Nothing's fun about a torque pig that makes big smoke shows but is all through by 5500, there's no reaon a well prepped 2-bolt block shouldn't be able to handle 6500 on occasion, same with a cast crank. The keys are spot-on machine work (including balancing) and spending the time to research and figure out a combination of parts that dance well together rather than just throwing together what's convenient or dirt cheap.
09-23-2013, 08:44 PM | #40 | |
Slugish
Re: 400 sbc
But when Igot alum heads last year ,i was told that a 180 cc chamber would be the most efficient for my 274 comp. cam & that is what I got . And you are right 5500 rpms is about it . In other words for me to turn 6-6500 rpms I would need a bigger cam ,right? |
09-23-2013, 09:13 PM | #41 |
Re: 400 sbc
Probably bigger (or ported) heads and yes, a cam cut for higher rpm peak.
The heads you have are better for daily driving, etc., it takes bigger/more efficient ports to carry one into the higher rpm ranges... |
09-23-2013, 09:24 PM | #42 | |
Re: 400 sbc
Procomp... Hit and miss on thier products depending on what your purpose is Posted via Mobile Device
09-23-2013, 09:47 PM | #43 | |
Re: 400 sbc
09-23-2013, 10:33 PM | #44 |
Slugish
Re: 400 sbc
Ok still learning here
What in the world is a splayed cap > keep seeing this term being used |
09-23-2013, 10:47 PM | #45 |
Re: 400 sbc
I don't mean to send you on a link but check this link and it explains it well.
http://forums.corvetteforum.com/engi...main-caps.html
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
09-24-2013, 08:23 PM | #46 |
Slugish
Re: 400 sbc
lEARNED SOMETHING TODAY ,tHX sHARKBITE
09-24-2013, 09:08 PM | #47 |
Re: 400 sbc
Saw a few pics of Dart's new LSwhatever block. It has conventional mains, splayed, rather than the "Y" block's deep skirt. Claim is it can handle more power than even the LSX
All current aftermarket blocks along with GM's Bowties have splayed mains, I've never seen the bottom end blown out of one from power or revs. Detonation, oil issues, etc. will take 'em out, but they can handle more than the internals. |
09-25-2013, 08:19 AM | #48 |
Re: 400 sbc
Actually some of the best street heads I've ever seen for SBC are the GMPP Vortec large port Bowtie heads. None of the shortcomings of the factory Vortec heads and flow VERY well right out of the box. http://www.summitracing.com/parts/na...4445/overview/
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
09-25-2013, 08:21 AM | #49 |
Re: 400 sbc
^ have a pair of those ready to go on my 406. They require a dedicated intake since the ports are raised and taller than typical. GMPP makes one, so does Edelbrock, but both will need to be port matched, gotta take off about 1/4" off of the roof to get it to match.
Gooood lookin' heads, though! |
09-25-2013, 12:49 PM | #50 | |
Re: 400 sbc
