11-22-2013, 01:38 AM | #26 |
Re: led lights
Good deal!
12-15-2013, 01:58 AM | #27 |
Re: led lights
Finally got around to installing the United Pacific LED flasher. As it turns out, I didn't need the reverse polarity plug. Turn signals front and rear work perfectly now.
12-15-2013, 07:48 PM | #28 |
Re: led lights
That's funny on the flasher. I just installed the United Pacific LED's from Summit on my 1964 stepside, and had to use the polarity reverser with the United Pacific flasher to get the turn signals to work. Also, after I installed them, when I pulled the light switch, I had bright lights (brake lights) but no brake lights when the lights were on. I unplugged the LED's and flipped the connectors over. Viola, normal lights when the lights were on, bright brake lights and turn signals! I think with LED's it's all about polarity.
These things are much brighter and the stainless housings add a bit of bling. I like them! |
12-16-2013, 01:08 PM | #29 |
Re: led lights
The only problem I have with LED's is that they no longer function as a reflector like the original lenses/buckets did. That's important to have if you're parked on the side of the road.
A buddy of mine uses a 55 watt headlight bulb added into the original buckets for brighter brake lights, and it keeps the reflector function. He had to use a glare shield from a headlight housing to keep from melting the lens; the hotter bulb makes a ton more heat when he's on the brakes a lot in traffic. I'm planning on adding H1 sockets into my original buckets. H1 bulbs can be found in just about any wattage so it'll be easy to find something bright enough. Any newer car has glare shields made into the headlights. They'll work to reflect the light back into the bucket so it's more evenly distributed, and it'll keep the heat away from the lens
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-16-2013, 01:14 PM | #30 |
C10 CLUB Y QUE!
Re: led lights
FYI..
United pacific tail are lifetime warranty!!! P.S i like the those headlights!!! |
12-16-2013, 03:07 PM | #31 | |
Re: led lights
12-16-2013, 03:15 PM | #32 |
Re: led lights
Yeah, my brake lights are that way too, now that I have the polarity right. Before, when I turned on the lights, I had the bright brake lights for tail lights, and you could see no change for brake lights. All I had to do was swap the orientation of the blugs into the tail light buckets.
I was really scratching my head, wondering how something that should be simple could be so complicated. But then I read that LED's are sensitive to polarity, and the LED came on in my head! :-) Switched the polarity on the flasher and swapped the plugs, and they are a beautiful sight! |
