Old 10-23-2013, 04:14 PM   #26
B85
B85's Avatar
Re: Building a 1985 Jimmy Ultra.
az
M29c Weasel
M151
S10
JK4 Door
F250 4x4
B85 is offline   Reply With Quote
Old 10-23-2013, 08:33 PM   #27
68Timber
I know the pieces fit
68Timber's Avatar
That exhaust is super clean. Nice work.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-23-2013, 09:59 PM   #28
B85
B85's Avatar
Thanks John,im trying?
More welding! Preheated to 250 then started welding.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-24-2013, 08:14 AM   #29
Low Elco
Wow! Can't wait to see it run!
Low Elco is offline   Reply With Quote
Old 10-24-2013, 04:00 PM   #30
B85
B85's Avatar
Finished the rear cover and some welding.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-25-2013, 10:36 PM   #31
B85
B85's Avatar
Some work on the A/C bracket.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-28-2013, 03:18 PM   #32
B85
B85's Avatar
I have been trying to get around a problem with the TB. The lever pull the wrong way. Looked at away to turn the problem around but it takes up to much room!
So my son is pulling his injectors on this 7.4 truck motor and I had to take a look at the TB. It pulles the right way and it is a 70mm bore. Thats good,but the mount is different. Out comes the cutter and now it is all welded back on!
This TB does not have a MAF sender so I will need to fab up a place for it in the runner.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 10-31-2013, 09:41 PM   #33
B85
B85's Avatar
Some work on the TV cable and needed to make a mounting stud.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 11-01-2013, 01:49 PM   #34
68Timber
68Timber's Avatar
Looking forward to seeing this make wheel smoke.
John
74 Honda Z50 build
Old 11-03-2013, 12:06 AM   #35
B85
B85's Avatar
On the 700R4 its all about the angles.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 11-04-2013, 02:03 PM   #36
Low Elco
Far out! Where'd you get that kit?
Old 11-04-2013, 02:20 PM   #37
B85
B85's Avatar
The slotted bracket came from Edelbrock 2.8 / 3.4 intake manifold. That was on the old 3.4 motor. The cable end I made. Edelbrock may sell it as just a parts kit?
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 11-05-2013, 11:37 PM   #38
B85
B85's Avatar
Need to remount the new A/C compressor. All mounted. Belt is 100" long.
Also had to use the compressor to adjust the belt.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 11-06-2013, 02:38 PM   #39
68Timber
68Timber's Avatar
The front and backside of the compressor mount, are those cut oem mounts or did you make those too?
John
74 Honda Z50 build
Old 11-06-2013, 03:34 PM   #40
B85
B85's Avatar
Here you go.
http://nostalgicac.com/mount-kits-pu...mount-kit.html
Then you just cut to fit.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 11-06-2013, 04:01 PM   #41
68Timber
68Timber's Avatar
Originally Posted by B85 View Post
Here you go.
Thank you sir. If I add AC to my military Blazer I will have to fab the bracket so that there is the ticket.
John
74 Honda Z50 build
Old 11-06-2013, 11:49 PM   #42
Pop's C-10
Pop's C-10's Avatar
i'm fan of this,
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 11-09-2013, 12:18 AM   #43
B85
B85's Avatar
Had to fix the wife's Jetta. Bad Alt. It took 2 1/2 hours to get to it!
Worked on the hot water lines to the heater.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 11-12-2013, 07:44 PM   #44
B85
B85's Avatar
Built the rear A/C bracket.
Went to a 45 Deg. at the heater hose. Looks better.
Started on getting the hot water out and to the other side of the Jimmy. Using the stock Rad.
Will reassemble the blower Wed,parts are all here!
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 11-13-2013, 07:47 PM   #45
B85
B85's Avatar
Blower is back together!
Now on to the cooling fan's!
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 11-15-2013, 02:04 PM   #46
B85
B85's Avatar
With me using the OEM cooling system needed to make a place to put the electric fans.This will house one of the Ultra's fan's and 2 7" fans.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 11-19-2013, 08:19 PM   #47
B85
B85's Avatar
Finish the fan's. I just love riv-nuts!
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 12-04-2013, 04:03 PM   #48
B85
B85's Avatar
Got some time to build some brackets and now looking at what will fit? Still need to install blower but need to change blower shaft seal. Found that after after installing the new oil?
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 01-02-2014, 03:17 PM   #49
B85
B85's Avatar
Back at it. Take a look and see if I missed anything ? Will solder up the bleed and the pipes.
M29c Weasel
M151
S10
JK4 Door
F250 4x4
Old 01-02-2014, 04:09 PM   #50
mattcrp1
mattcrp1's Avatar
Nice Work.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
