#26 |
Re: Cabs Need any cuts, parts etc?!
Paypal sent thanks
#27 |
![]() Join Date: Jan 2007
I could use the deluxe trim beneath the rear window with the clips, etc.
Also, I need an A/C evaporator box. Specifically the inner metal trim piece but I will buy the entire box if separating is an issue. Thanks, Wil
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
#28 |
#29 |
#30 |
![]() Join Date: Jul 2013
I will take the gas cap, cab trim, 12 clips (AND THE TWELVE SCREWS) shipped to me at 79106 for $30, Pm me with payment instructions, thanks a bunch.
#31 |
This is an original two tone truck, it has factory "studs" to put the clips on. Search the forum for other methods of adding the paint divider trim..looks pretty simple and quite a few have done it.
I accept PayPal "personal" at: playersnmv@aol.com Adam |
#32 |
Got another set of cab trim? And, how about the A/C evap box?
#33 |
I have a perfect 72 RV cab that the back was cutout for a pass thru. It was cut above and below the back window opening. I want to get in line for these areas and will send you the dimensions in the morning so you can quote the patches.
Thanks,
Brett ![]() 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
#34 |
Hey Budnikguy,
I need approx. 46" wide x 6" tall x 6" deep (should put us into the headliner area) on the upper. Also need 46" wide x 30" tall x 3" deep (floor) on the lower. Might also be interested in cowl patches for another cab I have. Same areas that *Gregg* was describing "I need part of the right side cowl/firewall right above the heater box & on the left side too to the right of the wiring block." not as big a deal please quote separately with and without. Let me know if you need more specific info for these. Shipping to 84010 or Greyhound to Salt Lake terminal would also work. Thanks,
#35 |
Petroleum User
I need the driver side rocker and cab corner and into the floor where the outer supports weld to the inner support(all in one piece would be optimal)
![]() 1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
#36 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Interested in pieces from both sides, including cab corners, inner/outer rockers, where kick meets floor pan, lower fender extension, etc. Basicly the bottom of cab from just above body line not including center of floor. If that doesnt makesense PM me your # and I will call you and explain. Need both sides. Shipped to 27587?
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#37 |
Adam, how much for the floor sheetmetal. I cropped the section I need.
Scott |
#38 |
![]() Join Date: Apr 2013
In need of a passenger side cab corner no rust plese lmk shipped to 78259 TX...
Eric (Evaded)
If I see a Zombie.. Im runnin it over with my Truck. |
#39 |
Adam, are you still parting the cabs out.
Scott |
#40 |
Looking for roof section. Im in OC and can pick up if possible.
#41 |
#42 |
#43 | |
$45.00 shipped for both sides, please confirm with measurements exact size.
Adam Quote:
#44 | |
On the RV patch pieces, I would need $60 plus Greyhound cost...depending on box size, probably 30-40 to ship. For the firewall pieces, both sides for $45 shipped depending on exact measurements. Could also ship those pieces with the other RV patches and save you some $...lmk.
Adam Quote:
#45 |
You want to come up? or are we talking about shipping it? $50 if you come up...figure another 25 to ship, so $75 delivered. LMK
Adam |
#46 | |
Shipping those big chunks may be a killer...you might look into what a freight cost would be...by zip is 92508.
#47 |
#48 |
#49 |
#50 |
