Old 10-20-2013, 08:09 AM   #26
superwade57
Re: Drop gone bad?
Originally Posted by INSIDIOUS '86 View Post
It's a normal thing for rallies actually as for the side to side difference make sure your springs are seated in the upper cups
Could be the normal square lean from gas tank weight over the years. If you have dual tanks just use the pass to even it out lol.
superwade57 is offline   Reply With Quote
Old 10-20-2013, 10:17 AM   #27
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Re: Drop gone bad?
My lean was very noticeable after I dropped my truck. Swapping my leafs side to side made my lean almost disappear.
killthewabbit is offline   Reply With Quote
Old 10-20-2013, 03:47 PM   #28
KrazyRay
KrazyRay's Avatar
Re: Drop gone bad?
I pulled my front coils out and cut 1 coil off and the stance is now perfect, however, I have the square lean of about one inch. I'm sure its from the fat driver and the driver side gas tank. I'm going to swap springs left to right hoping it will lean a bit to the passenger side and then level out when I (fat driver) get in with a full tank of gas. Here's pics of grinding the ridge so the brake lines miss the drop spindle:
KrazyRay is offline   Reply With Quote
