Old 11-18-2013, 11:52 PM   #26
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton pics
Well all I have done is what you see. That coil is what I had laying around. As soon as i figure out the electrical issue I bet it will fire right off. Coil has enough juice to burn the hair of a spiders keister.
I had to "convince" the coil bracket to accept a skinny smoother coil. I homemade a L bracket and welded it on...that sucker is not going anywhere.
No trees were killed to send this note but a large number of electrons were terribly inconvenienced.
AKA. RABIDJOE... if you have to ask you prob don't want to know. Ive had my shots *dont worry*
1960 235 4SPD C30
blazer-k5 is offline   Reply With Quote
Old 11-19-2013, 04:17 PM   #27
TJ's Chevy
TJ's Chevy's Avatar
Re: 1960 1 ton pics
Here is a picture of my Junior West Coast Chrome mirrors.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-19-2013, 04:46 PM   #28
1963c-10
1963c-10's Avatar
Re: 1960 1 ton pics
The west coast mirrors will look good on it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 12-04-2013, 09:36 PM   #29
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton pics
Those are some decent looking mirrors. I have no idea what i will use since mine are gone. lol
Do any of you know if these wheels will fit my 60?
http://lawton.craigslist.org/pts/4158017891.html
1960 235 4SPD C30
Old 12-05-2013, 09:31 AM   #30
b.sharp
b.sharp's Avatar
Re: 1960 1 ton pics
if I remember correctly the new wheels will not fit your truck. The lug pattern is the same but the center whole is too small for the older trucks. You can get 73-87 bud wheels from a newer dully if you are wanting to keep it dual wheel. I have a set for my
'65.
b.sharp is offline   Reply With Quote
Old 12-05-2013, 11:36 AM   #31
66Submarine
66Submarine's Avatar
Re: 1960 1 ton pics
I think they work; I've seen quite a few older trucks with them (I almost put some on mine). Lug nuts and studs might need to be changed; IIRC you can get a 9/16" lug nut that works with the caps, I'm not sure about 1/2" stuff. They are called "PYO" wheels, BTW. I think the 67-72 guys have a couple threads, I'll try to dig one up.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 12-05-2013, 11:40 AM   #32
66Submarine
Re: 1960 1 ton pics
http://67-72chevytrucks.com/vboard/s...d.php?t=330740
Here's a thread on 8 lug wheels for ya.
Old 12-05-2013, 07:31 PM   #33
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton pics
OH SNAP it looks like they will fit! I have single wheels I lucked out don't have a dully. Guess i better jump on them huh? lol
1960 235 4SPD C30
Old 12-05-2013, 07:34 PM   #34
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton pics
I think i will have to change my lug nuts to run them. Agreed.
1960 235 4SPD C30
Old 02-25-2014, 08:20 PM   #35
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton pics
So this happened after I bumped the valve cover with a rubber mallet.......I WILL NEVER DO THAT AGAIN!
1960 235 4SPD C30
Old 02-25-2014, 08:23 PM   #36
1963c-10
1963c-10's Avatar
Re: 1960 1 ton pics
Awwww man, that sucks. Hope its not too bad of a pain to clean up.
Old 02-25-2014, 08:48 PM   #37
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton pics
It...Im not quite sure how long it took. I was lucky and rigged a shop vac i got 90% or more of it all re oiled everything...except for all that goo/dried goo. The top of the head was perfect no sludge...
1960 235 4SPD C30
Old 02-25-2014, 09:25 PM   #38
TJ's Chevy
TJ's Chevy's Avatar
Re: 1960 1 ton pics
Glad the mess cleaned up! Have you decided on a set of mirrors? Sorry if I missed something...
Old 02-26-2014, 11:39 PM   #39
blazer-k5
blazer-k5's Avatar
Re: 1960 1 ton pics
Nope, you didnt . I did look at some mirrors. I figured that would be later though I have to fix the half melted rats nest under the dash. I plan on doing it this saturday. I will totally post a picture...If i can get it to run in the same day I will try to post a vid.
1960 235 4SPD C30
