Old 10-18-2013, 12:41 PM   #26
724x4LB
724x4LB's Avatar
Re: blocks need springs
Thanks. I like the spring down away from the frame. It would seem that I could get more articulation with that set up also. I found these at 4wheelparts
http://www.4wheelparts.com/Lift-Kits..._pn=t%2Fc19670
72 Chevy 4x4
Gifted 383
Function over Form
724x4LB is offline   Reply With Quote
Old 10-18-2013, 05:56 PM   #27
swamp rat
swamp rat's Avatar
I'll give you a tip, I ordered my kit and there was not one mention of possible frozen rusted bolts or even the worn out rubber frame bushing in the front. Regardless of where you buy the springs be prepared to have frozen spring and shackle bolts, maybe even go check them before you order the springs. I had to buy new shackles and and also added a greasable bolt and bushing kit from Offroad design, these bushings are a little shorter in length and the sleeves have hols drilled in so there is passages for the grease to flow. All this stuff and now problems with my shocks have held up my progress tremendously.
If your front springs have the slipper pads between the leaves i'd also try and do the same to the rear, and consider the wedge on the bottom. I think BDS springs are about the same price for just the springs.. I have a lot of pic's on my build thread..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-18-2013, 09:52 PM   #28
724x4LB
724x4LB's Avatar
O trust me I know that things that can go wrong and hard when doing leaf springs. I've got a several sets under my belt. The good thing is this truck was just put together by the p/o. So I think it will go smooth in that sense. The new springs have new bushings in them so I wont have to worry about that either. The spring perch's are gonna be tough,,but I'll manage.
Not sure if the front has slipper pads but it dont look like it. I think I'll check and see if I can slip the greaseable bolts in the budget. I usually jack that whole area full of waterproof grease. Just in case.
72 Chevy 4x4
Gifted 383
Function over Form
Old 11-03-2013, 04:13 PM   #29
724x4LB
724x4LB's Avatar
Quick update: I got the heater core ordered. Dropped the inner fender wells to access the engine compartment...super easy. Plus it gives ya a ton of room to relax. She devolped a valve cover leak on her last run out to vegas last week. Lost half a quart of oil in an hour...eek. It was just a loose bolt thou. Checked the rockers and tighted it back down....fixed. While I'm here thou I was able to wash the entire front end and give it all a fresh coat of flat black, plus undercoat the back of the fenders.
So now while I wait I need to take care of ordering these spring perches for the rear axle. Problem is I don't know what to order to replace them. Anyone have any advise on where and what size perches to order?
72 Chevy 4x4
Gifted 383
Function over Form
Old 11-03-2013, 09:34 PM   #30
bbcmudtruck
Have you checked in LMC? I'm sure one of the vendors will have the perches you need. Check with early classics, LMC or Brothers. GMC Paul would be another good place to check.
bbcmudtruck is offline   Reply With Quote
Old 11-03-2013, 09:42 PM   #31
swamp rat
swamp rat's Avatar
I just thought of something, Off road design had some small offset blocks that can ether be on center, or offset ether front or back, 1" thick, if ya don't want full springs maybe add this?
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-04-2013, 04:35 PM   #32
724x4LB
724x4LB's Avatar
Thanks for that info. I found some places to get the perches ,,, I just don't know what to get. I measured the axle tube and spring width. 3" on both. Thought it would be more complicated...lol.
72 Chevy 4x4
Gifted 383
Function over Form
Old 11-04-2013, 04:39 PM   #33
724x4LB
724x4LB's Avatar
That's a cool piece. Where do ya get 5" lift springs thou?
72 Chevy 4x4
Gifted 383
Function over Form
Old 11-04-2013, 05:12 PM   #34
724x4LB
724x4LB's Avatar
Correction: 3" tube 2.5" spring. I see a lot for this size. Is there a difference in which brand to get..? They look pretty basic to me. I was considering some anti spring wrap perch for when I get springs and remove the lift block.
72 Chevy 4x4
Gifted 383
Function over Form
Old 11-05-2013, 02:45 AM   #35
swamp rat
swamp rat's Avatar
Just found this thread again, one poster said he had a 5" spring pack made by Alcan post # 17
http://67-72chevytrucks.com/vboard/s...&highlight=BDS
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-05-2013, 04:44 AM   #36
68shortfleet
Tuff Country lists a 6" lift with rear springs on their website. They distribute through summit too though.
And, Member "teeitup" has a dual steering stabilizer kit listed in the for sale section right now. It is the stacked style, rather than the side-by-side style, but the price is right.
68shortfleet is offline   Reply With Quote
Old 11-05-2013, 07:18 AM   #37
jjzepplin
jjzepplin's Avatar
thanks for that info . i think it rides ok in the front. the rear is stiffer. I also need some real shocks. He put new ones but I dont know who makes em they're just white. I took a couple pictures real quick to show what it has. I also removed the stupid black paint from the grill. I wonder about the pitman arm ....did he do what needs to be done when you lift it? And anyone know anything about the driveshaft? I just know it cant be stock.
Thoughts and comments welcome!
Nice truck! That rear driveshaft DOES have a slip joint in it right?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-05-2013, 11:19 AM   #38
724x4LB
724x4LB's Avatar
Hey thanks for that info....now if I could get one of you guys over my house to help me with these spring perches.....getting exicted....I got parts trucks at my garage door. xmas in November! I took her last video before I started rippin it apart. Next time she's pullin out she be a new truck.
72 Chevy 4x4
Gifted 383
Function over Form
Old 11-06-2013, 03:15 PM   #39
jjzepplin
jjzepplin's Avatar
YouTube
Can't see the video... says it's private?
Old 11-06-2013, 09:19 PM   #40
swamp rat
swamp rat's Avatar
Same here.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-12-2013, 12:26 AM   #41
724x4LB
724x4LB's Avatar
Dam...I think I fixed it...I got a bunch of stuff done over the past week or so while waiting for parts. I finally have heat! Heater core and hoses...also found some left over braiding.
Also painted the grill, took a part the dash and interior painted it....a quart of paint and some free time. The interior was a horrible brown yellow black mess. So needless to say im stoked its finally painted.
Spring perchers arrived....im gonna get on replacing those next..
72 Chevy 4x4
Gifted 383
Function over Form
Old 11-12-2013, 12:33 AM   #42
swamp rat
swamp rat's Avatar
Vid works, the truck sounds nice! Keep up the good work.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-12-2013, 02:26 AM   #43
724x4LB
724x4LB's Avatar
Thank you. Just need some more free time now.
72 Chevy 4x4
Gifted 383
Function over Form
