Old 10-20-2013, 12:23 AM   #26
jorgensensc
jorgensensc's Avatar
Re: Where did you put your gauges?
Another shot while driving. Gotta love overdrive! Just over 70 mph at 2000 rpm's!
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-20-2013, 08:03 AM   #27
leftybass209
leftybass209's Avatar
Originally Posted by jorgensensc View Post
I used Speedhut gauges for my ls swap. My fuel, volt, oil pressure, engine temp, and trans temp all run off the canbus system. The tach and speedo were not available in the right size in canbus, so they hook directly to the ECM. They do make a gps speedo though if you are running something without an electrical pulse for the speedo. They were very nice and super easy to wire.
FINALLY!!!!! I'm pleased you posted this picture. Its the idea I've had for the longest time. I had seen 1 or 2 gauges individually but never a whole matching set with the same font style. Did you need to use the metal backing or is that just the bezel?
leftybass209 is offline   Reply With Quote
Old 10-20-2013, 11:08 AM   #28
jorgensensc
I'm glad I could help! I modified the backing plate and used it also. You could probably get away with not using one, but it holds things together nicely and I was able to retain the stock turn signals. Here is a pic of the back.
