Old 11-12-2013, 09:22 PM   #26
Houston Ben
Houston Ben's Avatar
Re: Please help with codes!!!
Ok, feel free to flame away at me but I stated this was the first time I have ever attempted anything like this and not really mechanically inclined. I started the truck and pulled out to the street where I let it warm up. While running I checked the tranny fluid and found I was approx. 2 qts low DOH!!!!My buddy has a 2013 and he told me how much fluid I needed per his book so that's what I did and it measured good.....until I turn on the vehicle.... Now she moves like she should But I still need to have the exhaust put on with the O2's correctly put in.
Houston Ben is offline   Reply With Quote
Old 11-12-2013, 09:27 PM   #27
jorgensensc
jorgensensc's Avatar
Nobody is going to flame you! I'm pretty sure something like that has happened to everyone on this board, and if it hasn't then they haven't really challenged themselves. I had to go back and add tranny fluid to mine also. I thought I had the right amount, even filled the convertor, but it still needed more. Glad you figured it out. Keep us updated with your progress!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 11-12-2013, 09:42 PM   #28
Houston Ben
Will do, Thanks Shawn!!
Old 11-12-2013, 10:05 PM   #29
Hart_Rod
Hart_Rod's Avatar
No flaming here man, we've all made mistakes. I made a dumb one this weekend by assuming that the torque converter lock up was triggered the same way on the newer stuff just as it was on the older stuff.....it's not! Wasted 2 days of tuning....oh well, it's a learning process AND I'm not waiting on someone else to figure it out for me, I'm doing it myself.
Hart_Rod is offline   Reply With Quote
Old 11-12-2013, 10:49 PM   #30
jorgensensc
This is a fact on the torque convertor. Old stuff used the brake switch wires to the trans to engage disengage the TCC. New stuff uses the same brake switch to tell the ECM, which then tells the trans via canbus to engage/disengage the TCC.
I thought I told you about that Rob? I don't know anymore who I told what about!
Shawn
Old 11-13-2013, 10:39 AM   #31
Hart_Rod
Hart_Rod's Avatar
Shawn
You probably did Shawn. My head is starting to swim with the amount of info I'm trying to shove into my brain. I feel like I'm back in Navy Nuclear Power school....
