#26 |
Re: How to ruin a near mint 85 gmc
It now has a cast resivor the stock one ended up leaking but its a factory 85 1ton hydro boost
1985 ![]() |
#27 |
Had a decent weather day so I broke out the buffer and spent a few hours wearing down paint one day it will be thin enough to clear coat but for now it has a good wax shine.
1985 ![]() |
#28 |
Damn! She looks brand new!
1986 Chevy Silverado LWB (project) 1967 Chevy SBSS (future project) 2003 Chevy Tahoe (wifes daily) 2004 GMC 2500 Duramax (company truck) 1986 GMC Wrangler LWB (newly acquired beater) ![]() |
#29 |
It looks real nice. I love the factory 2 tone with the stance/wheel combo. Nice job!
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#30 |
Well I decided to go ahead and pull my temporary exhaust and headers off. Ordered in some 2 inch primary hooker super comps and 3 inch x pipe kit. Headers were snug fit and had to put the mufflers before the x since they wouldn't fit anywhere else. Just have to finish up welding and it will be done.
1985 ![]() |
#31 |
After I finished my exhaust in april I noticed my engine tick was still there. I had just been dealing with the noise and couldn't say there was any issue with power after beating a nasty built early bronco in a drag race. Then a few days later I decided to pull my valve covers and I had #8 rocker cut out the top of the valve spring due to bad threads on rocker stud.
Machine shop said its cheaper to just buy a new 781 head and have it done. So I figure if I'm replacing I am going with aluminum heads with big valves. Got most of it back together I got dart adjustable guide plate at recommendation of head builder Don't get them unless fixed plates hold your rockers off center. They suck to set up and had clearance issues on my heads but the 4 locations I used them are 100% centered.
1985 ![]() |
#32 |
Nice really good hopefully it's a beast when done
#33 |
Second Chance Program
Big blocks are cool.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
#34 |
Bretzke Racing Inc.
Bad A$$!!!
Perfection at its greatest! ![]() ![]()
1982 Chevy Silverado C-10 RCLWB - IN PAINT - Inferno Orange Metallic Lowered 4.5/6 - 358 SBC 10.5:1, Comp XE268H cam, Aluminum heads, 650 Double pumper Holley carb, 2400 Holeshot Converter, upgraded T/h350 Trans. Stock Rear end for now (3.08 gear) ![]() 2004 Chevy Silverado 1500 LS RCSWB - Dark Spiral Gray Metallic Lowered 2/4 - 4.8L V8 4L60E 10-bolt. some goodies --- NEW DD 11/9/12 ![]() ![]() "Expect the Un-expected" "Gas, Grass, Or Ass...No one rides for FREE!" ![]() |
#35 |
nice work, looks very nice!
#36 |
Home Built '87
You are definitely NOT ruining it!!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
#37 |
The 700 has been great but had someone back out of buying a 4l80e built for 1000hp + that I already had built so went ahead and ordered a tci ez tcu controller and put it in my truck. Got everything finished up last night and I can say anyone thinking about going with an 80 won't be disappointed. The controller is easy to setup and even easier to tune to person preferences.
1985 ![]() |
#38 |
Been a while but now I'm back at it. The 4l80e a ez-tcu are awesome love the easy adjustents. Put a new holley double pumper on it, new front sway bar bushings and made a s10 blazer rear swaybar work on it too. Should have more updates shortly since I got a 30lb box from Calvert racing this evening.
1985 ![]() |
#39 |
Looking good, do you have any specifics on the rear sway bar? That seems like a nice set up.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
#40 |
Is that a trans cooler in the rear?
Build looks awesome!
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB 1987 GMC V3500 Dump, 6.2L diesel, TH400 1983 GMC K2500 - awaiting its restoration and Cummins swap. |
#41 |
The sway bar is out of a 98 s10 blazer factory rear just had to open up the clamp mounts for the size of my 12 blots axle tubes.
It is a transmission cooler in the rear didn't have much room up front so I used a f350 cooler I had sitting around . Keeps my trans plenty cool.
1985 ![]() |
#42 |
Got my cal-tracs installed and now I have no axle wrap or wheel hop. Now I have to get around to installing my Detroit locker.
1985 ![]() |
#43 |
Do u have any rubbing issues at front with 5" drop? What BS do you run on wheels? Thanks
Put a cover over it, have a beer or two, kool down, and look at it in a couple weeks, we all have to take a break! 64 Short Fleetside, 283, T5 http://67-72chevytrucks.com/vboard/s...d.php?t=572500 Faded 87 soon to be LS powered http://67-72chevytrucks.com/vboard/s...d.php?t=653667 |
#44 |
No rubbing issues. Don't remember the specs I searched here and got the setup everyone on here is running. Think 5.25 or 5.5
1985 ![]() |
#45 |
Im going to use that sway bar upgrade on mine.......nice build.............
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
#46 |
Was the caltrac bars easy to install? I've been thinking about them for some time.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#47 |
They are easy as long as you have a decent ball joint press or air hammer.
1985 ![]() |
#48 |
Just thought Id stop by and say what a nice truck you got there!
Red 1968 Chevy C10: 4bbl 350 v8 1984 Chevrolet Corvette Crossfire 350 1987 Chevrolet Camaro 305 4bbl 1993 Chevrolet Cavalier RS Convertible 3.1L V6 1982 Chrysler LeBaron Convertible Marc Cross Edition ![]() |
#49 |
Thanks. Got my electronic 91 burban cluster wired and working so no more GPS speedo for me. Now I just need to quit being lazy and put a Detroit locker in it.
1985 ![]() |
#50 | |
did the GPS speedo give you problems?
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
