Old 10-23-2013, 08:54 PM   #26
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Originally Posted by 68GMCCustom View Post
I'm not sure he's doing the '12-'13's yet....but may be waiting for a customer that wants a tune and HP Tuners so that they can send him scans and he can send them tunes to load...and would work a combo deal. All you can do is ask. I can't say he's always gotten everything right the 1st time...but has been willing to work with me on everything thats come up and has sent half a dozen files or more to get mine fairly dialed in. W/O putting it on the rack (dyno) its hard to say its "peak" tuned. Just ask for Allen.
http://www.nelsonperformance.com/index.html
Thanks, I'll give them a call. Ok I fired it up and feathered the throttle for 3 or 4 minutes and then it would idle on its on. I let it idle for about 5 mins while I checked the fluids and adjusted the fuel pressure. After that was done, I shut it off and then tried to restart it. It wouldn't start unless I feathered the gas pedal and then I had to keep messing with the pedal to keep it idling. When I shut it off, I checked the codes and I had two P0300s and P0174.....
Hart_Rod is offline   Reply With Quote
Old 10-23-2013, 10:32 PM   #27
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Trouble codes
misfires...possibly due to the lean bank. I'd look for a spark plug/wire/coil issue on that side.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-24-2013, 07:58 AM   #28
smoky02
Location: Sunny, Florida, some might call it South Alabama
Re: Trouble codes
Also check your grounds, and random ground not being attached will do some crazy things.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 10-24-2013, 09:18 AM   #29
smoky02
Re: Trouble codes
Also, I'm not trying to scare you, but my Camaro randomly through that P0300 code a while back. I couldn't figure out what was going on, and eventually I pulled my valve covers to find I had a few broken valve springs.
Old 10-24-2013, 09:22 AM   #30
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
I'll check.
I'll check.
Where they new valve springs?
Old 10-24-2013, 11:49 AM   #31
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
John said the problem might be the 80lb injectors. ...he also said my tune was unlocked. Does that mean I don't need credits from HP TUNERS to update the tune?
Old 10-24-2013, 01:39 PM   #32
jorgensensc
jorgensensc's Avatar
Re: Trouble codes
Unlocked means that others can look at and adjust your tune. Some tuners lock it so no one can see what they have done. Also the credits bought are registered and only good for the person using hptuners to do the tune. If you want to tune it you would still need to buy/use the credits so it can be registered to you. At least that is my understanding. Different people all have to pay independently.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-24-2013, 02:37 PM   #33
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Trouble codes
There is a cost for the credits to unlock the pcm from the factory, essentially making it open (not read only). That cost is for the individual to pay a tuner.
Then there is the cost of the software itself. That is usually a cost the tuner pays as an investment in a tool, and charges his fees' to each individual to recoup costs and make a profit. This is a not a set amount. There are two main versions of the software from what I can remember.,
1. full software and box for around $550, comes with credits for a few vehicles (i think 5, keeping in mind some different vehicles would use a non-standard amount of credits).
2. Is around $750 and is the "shop" version, which includes a ton more/unlimited credits. This one costs more up front but pays for itself by waiving the need for recurring fee's for credits. IF you plan to do other peoples tunes, this will pay for itself around the 5th tune.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-24-2013, 03:07 PM   #34
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Thanks for the clarification. Here is the cheapest place I've found:
http://www.summitracing.com/parts/hpt-6021/overview/
Also, will I be able to "tune" the TCM? Thoughts on the other codes and symptoms I've posted? Thanks,
Rob
Old 10-24-2013, 08:12 PM   #35
clinebarger
Re: Trouble codes
Still getting These Codes?
P0122
P0223
P0315
P2122
And now these...
(2) P0300 Multiple misfires, Don't understand 2 of them though.
P0174 Lean Bank 1
More info on your engine & mods?
John isn't willing to help you?
clinebarger is offline   Reply With Quote
Old 10-24-2013, 09:02 PM   #36
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
P0122
P0223
P0315
P2122
And now these...
P0174 Lean Bank 1
Still getting the first 4 codes. Cleared the last 3. He's to busy. 2013 Camaro 6.2/6L80. TVS 1900 Magnacharger. 80lb siemens injectors. I mechanically removed the VVT/AFM. I'm using a 2004+ corvette pedal. Comp Cam with dual valve springs (cam specs are above), 7.4 pushrods. 1 7/8" mid length headers. LS9 map sensor. Rest of motor is stock. It won't idle and less you feather it.
Old 10-24-2013, 09:34 PM   #37
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Here are the cam specs:
http://www.summitracing.com/parts/cca-54-45311
UPC: 036584213741 Cam Style: Hydraulic roller tappet Basic Operating RPM Range: 1,500-6,700 Intake Duration at 050 inch Lift: 219 Exhaust Duration at 050 inch Lift: 235 Duration at 050 inch Lift: 219 int./235 exh. Advertised Intake Duration: 269 Advertised Exhaust Duration: 285 Advertised Duration: 269 int./285 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.607 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.621 in. Valve Lift with Factory Rocker Arm Ratio: 0.607 int./0.621 exh. Lobe Separation (degrees): 113 Camshaft Gear Attachment: 3-bolt Computer-Controlled Compatible: No Grind Number: 269LRR HR13
Old 10-25-2013, 02:30 AM   #38
smoky02
Re: Trouble codes
More than likely your misfire is due to the custom grind cam. When speartech built my harness and initial tune they did a horrible job of giving me a start tune. I told him all the specs of my motor(you can see in my sig). And he sent me a tune for an ls1. That could be what's happening to you. John Weeks got it worked out for me though.
Old 10-25-2013, 02:31 AM   #39
smoky02
Re: Trouble codes
Oh and to answer your question. The springs I broke were from Texas speed I bought them new and had them installed with my cam at Texas speed. They were less than a year old and had around 11,000 miles on them.
Old 10-25-2013, 08:53 AM   #40
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
That suxs. Mine springs are new and matched to the cam by CompCams. Hopefully that isn't the problem.....
Same here on the tune.... I thought John used EFI live?
Old 10-25-2013, 03:14 PM   #41
68GMCCustom
Re: Trouble codes
cam is real close to mine....a 223/231@.050 with .610/.617 lift and 112 LSA. I'm running .650 springs...PAC I think?
Kurt -
Old 10-25-2013, 07:18 PM   #42
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Are you happy with the drivability? Idle? When you had the bad pedal, would it start and idle?
Old 10-25-2013, 08:21 PM   #43
clinebarger
Re: Trouble codes
That pedal might be causing some issue? I always try to use a pedal matched to the ECM, In '04 Corvettes still used Gen III engines & a separate TAC module, '05 used a E40 ECM, Then a E38 later on, Im sure there are 4 different pedals used in a 4 year period.
Why such a big injector? It would be all but impossible to tune this combo thru mail order.
Old 10-25-2013, 08:29 PM   #44
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Trouble codes
That 6.2 with a tvs would probably be using most of some 60's, IMO the 80's would be the next step up I'm used to seeing.
That said, I agree with you on the mail order issue. So I harp once again...go to a real tuner.
Old 10-25-2013, 08:39 PM   #45
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
It's an 05 -13 pedal, at least that's how the part number is listed. I wanted some room for growth with the injectors..... I agree on the tune. I was just trying to get one that was close so that I could work out some bugs prior to getting it dyno tuned. John agreed to let me send the computer back and I should have HPTuners here at the first of the week, let the learning begin!!!
Unfortunately, there is not a real tuner within 300 miles of where I live, hence that's why I wanted to get a conservative mail order tune... lesson learned, . Maybe I can figures something out with HPTuners. I'll be hitting you up with more questions next week....wanna pm me your number, .
Old 10-25-2013, 09:28 PM   #46
clinebarger
Re: Trouble codes
Stock 52 lb/hr LS9 injectors would work with a "Boost Referenced Regulator"....Though the Duty Cycle would be on the high side. 65 lb/hr would certainly work with less duty cycle.....Again still high compared to an 80lb/hr......But such a big injector can cause tuning issues.
Old 10-26-2013, 08:22 PM   #47
clinebarger
Re: Trouble codes
Your right the pedals are the same, With the same pinout as a Camaro.
Scan it with HP-Tuners & report back with the codes, The Generic scanners your using may be giving false info.
Old 10-26-2013, 08:32 PM   #48
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Thanks! The software should be here Monday. I'm putting the factory 2013 Camaro L99 computer back in and starting from scratch .....
Old 10-27-2013, 07:43 AM   #49
smoky02
Re: Trouble codes
To be honest I'm not sure which program he uses.
Old 10-27-2013, 12:04 PM   #50
68GMCCustom
Re: Trouble codes
I'd have to go back and re-read my notes...can't remember for sure but think it wasn't starting. My motor isn't as big at 6.0L but with this cam is running 50# Chrysler injectors. I still need to install the injectors I got from you.
As far as the cam...its been great with this motor though it made more vacuum when it was carb'd. The idle is lightly lopey/choppy and it jumps when I hit the go pedal.
The HPTuners will help you identify problems with the scanner then correct them with the editor. Plus with the forum communities....a lot of folks running HPT (and some running boost) will be willing to look over your scans and tune...and make suggestions. Some may actually be helpful.
Kurt -
