Old 11-08-2013, 11:15 PM   #26
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Heater help!
Originally Posted by Sodell View Post
I thought that was the resistor?
in the B&W picture, the resistors/coils are shown under the blower motor.
with or without the AC you have them,different ones,but you have them
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-09-2013, 12:36 AM   #27
Sodell
Sodell's Avatar
Re: Heater help!
Yea, I was trying not confuse 79, that is the resistor that he is calling the blower coils. If that resistor (blower coil) is not working you will still get high fan.
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 11-09-2013, 06:56 AM   #28
79Betty
79Betty's Avatar
Re: Heater help!
Ithink i still get fan because last night i could feel wind coming out of the side of it, but nothing through the vents so i think that'llbe next issue. I couldn't see last night to confirm it though :/
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 11-09-2013, 07:31 AM   #29
Desert1957
Desert1957's Avatar
Re: Heater help!
I only see a purple hot wire, where is the ground wire?
Blower motor will not operated with out being grounded.
Desert
Desert1957 is offline   Reply With Quote
Old 11-09-2013, 08:49 AM   #30
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Heater help!
Attachment 1172670
Desert
that would do it
my non-ACs in my 78 and both 79s dont have grounds,those outside boxes are metal,my 87,88,89,with AC do have them but cause those are fiber boxes
can almost make out the spot too,like my 89
John
Old 11-09-2013, 04:48 PM   #31
79Betty
79Betty's Avatar
Re: Heater help!
Sorry i can't edit pic's everyone but can only take. The black wire from the resistor? Has purple, blue red wires. I can take it and ground it to a fender bolt hole and hear it "Click" like it kicking on. But still can't tell if the motor is turning. Also i have hot hoses now!! Found that out the hard way lol i mean this wire.
Old 11-09-2013, 10:38 PM   #32
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Heater help!
throw/wedge a couple of Kleenex/TP on the exits?
John
Old 11-09-2013, 11:25 PM   #33
zaccaglin
zaccaglin's Avatar
Re: Heater help!
The click you hear is the relay making contact and not the motor. Go ahead and connect that to the firewall with a screw. A clean, new screw that way you will have a good ground. Also from that screw attach another ring terminal with an ##12 wire crimped to it with another smaller ring terminal on the other end of that wire. Then remove one of the mounting screws from your blower motor and rough up and sand the paint off under it. Then replace the screw with the ring terminal in it. The ring terminal should be making a good ground the the blower motor through the roughed paint. This should solve your problem.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 11-10-2013, 08:57 AM   #34
79Betty
79Betty's Avatar
Re: Heater help!
And i will do just that. The motor spins, but i found out there are 2 blower motor wheels. One for HD heater and one for non HD. I have a HD motor with non HD wheel which won't work because of the offset. The wheel was rubbing the motor backing plate which is why it wasn't spinning. New one will be here tuesday! Now to figure out why the blend door won't open
Old 11-10-2013, 10:18 AM   #35
rs74
rs74's Avatar
Re: Heater help!
Not sure how your heater controls are compared to my 85 but my blend door would not operate either. Tore into it and found that the white plastic clip that holds the rod in the picture was missing. Everything else was operating except it wasn't hooked to the blend door due to missing clip.
You said you got hot hoses now. What changed? I am going to have to go back and read it again. Maybe I missed something.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 11-10-2013, 10:26 AM   #36
79Betty
79Betty's Avatar
Re: Heater help!
I did put a new thermostat in it. I'ma dig into it today after breakfast.
Old 11-18-2013, 10:37 PM   #37
79Betty
79Betty's Avatar
Re: Heater help!
Update . Sorry guysi've been busy with work n weather is not cooperating. I got my blowe motor to run. Check. Now i still can't get the blend door moving. What if the vacuum canister ball on firewall is clogged? Could this happen? I have a vac line going from my carb to it. When i unplugged it to move it for a sec it depressurized.
Old 11-18-2013, 11:06 PM   #38
crazeetxn
crazeetxn's Avatar
Re: Heater help!
Easy, but messy, way to check the heater core is disconnect the two black hoses and hook a water hose up to one and see what kind of flow you have coming out. Don't know how crap gets in there, but my son had an s-10. When I hooked the hose up, sludge came out...after that, he had hot air.
As for the blend door not moving. You can get a hand vac (brake bleeder) and see if you can pull a vac. If the actator on the back isn't working, check out this thread. It helped me replace mine. And while you're at it, you've got access to change the heater core too. Kinda one of those, well, since it's apart, might as well put in a new one.
http://67-72chevytrucks.com/vboard/s...d.php?t=460942
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
Old 11-21-2013, 10:35 AM   #39
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Heater help!
From my 81 book.....
John
Old 11-21-2013, 10:42 AM   #40
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Heater help!
must be close,if not the same?
John
Old 11-22-2013, 10:26 AM   #41
79Betty
79Betty's Avatar
Re: Heater help!
I think igot it. It blows now and hard (2 bad motors from VDO) it works!! But, it seems hard to get it to go from vent to defrost and back. Not sure why yet gonna dig into it more. But it does blow good n warm. I can sit i the cab n with no interior it still gets warm. Hope it gets good after i put my dynamat, MLV insulation and carpet in.
blower motor, heater core, heater wiring
