Old 03-01-2014, 11:44 PM   #26
SLOW POKE
SLOW POKE's Avatar
Re: Project Cannonball C10
Any updates?
68 Short step!!
SLOW POKE is offline   Reply With Quote
Old 03-02-2014, 02:00 AM   #27
mikentosh
mikentosh's Avatar
Well quite a bit has happened over the last couple of months, mainly the truck has been stripped and sent out for blasting, and the chassis arrived a few weeks back. I've been holding off on posting any more until the build really gets underway. I'm hoping to get things moving around mid-April.
Perhaps until then I'll throw up a few photos from over the winter.
mikentosh is offline   Reply With Quote
Old 03-02-2014, 02:10 AM   #28
mikentosh
mikentosh's Avatar
I spent most of December stripping down the truck and bagging everything up. Once it was gutted I towed it up to Sacramento to get blasted and primed.
It left as a rolling hulk...
...and came back squished into a Uhaul
Both the cab and bed were as clean as I was hoping for. Only some minor pinhole rust through the firewall. Front panel on the bed is trashed so we're just going to replace it.
While doing the teardown I realized the doors that came on the truck are the newer ones which accept the full width door panels. I really want the period style so it was a chore to find clean 73-76 small inner panel doors, but after a month of calls and searching I found both driver and passenger doors.
Old 03-02-2014, 02:18 AM   #29
mikentosh
mikentosh's Avatar
One morning in early February I got a text message saying a very large box showed up at the shop...
Got the motor set in...
Old 03-02-2014, 02:20 AM   #30
tinydb84
tinydb84's Avatar
damn....whole new level!
What shop is doing the work?
David
Instagram: myfabguy
Old 03-02-2014, 02:23 AM   #31
mikentosh
mikentosh's Avatar
Wes @ One Off Customs in Santa Clara, CA.
He's got a wild Camaro project finishing up right now before we can really get started on the truck. I'm hoping for April
Old 03-02-2014, 02:43 AM   #32
mikentosh
mikentosh's Avatar
Having this time has given me a chance to find/paint/rebuild a bunch of stuff...
Grabbed a non-column shift steering column out of a '76 on Thanksgiving day for $20.
Pulled the whole column apart, sanded and sprayed it in semi-gloss black, put in fresh bearings and fitted with new ignition/turn signal switches. Also topped it with a "GM Comfort Grip" wheel in 14" diameter. I took a guess on the size, which matches the diameter in my M3.
I put in a Dakota Digital turn signal lever with 4 wire cruise control (HND-3). This lever really looks like it came with the truck, but I'll be able to wire it into the ECU for modern cruise control.
Old 03-02-2014, 02:54 AM   #33
mikentosh
mikentosh's Avatar
Over the holiday break I rebuilt the vent window assemblies. What a nightmare project that was! Funny thing is I have no photos from any of that...guess I didn't want to remember.
I also ordered a bunch of Eastwood paint supplies and freshened up lots of the small parts. Turn signal/parking light housings
Horns
Inner door brackets
Old 03-02-2014, 03:03 AM   #34
mikentosh
mikentosh's Avatar
And, of course, the delivery guys have been showing up a lot lately
Vintage Air Gen IV
Totally Stainless Bolt Kit
A giant box with a reproduction hood that I'm not going to use now
An E-Stopp parking brake kit. I didn't want to try hooking the ebrake pedal up to the Wilwood setup, and I'll hide the button on this kit for a bit of theft deterrence.
Old 03-02-2014, 12:06 PM   #35
Jonboy
Slots go on anything!
Looking good Mike! This is going to be unreal when it gets together. Digging the Mini, too.
1974 Jimmy- 5.3/4L80e/NP241
Old 03-03-2014, 04:16 PM   #36
1Bad65GMC
1Bad65GMC's Avatar
Subscribed. This is going to be good.
1998 GMC Suburban 2500 454 4X4
1984 GMC Jimmy - 3/4 ton axles, 5.7TBI
1990 GMC Suburban (Parts Donor) scrapped
1965 Buick Riviera - (Sold)
1999 Mercury Grand Marquis
1965 GMC SBSS (Sold)
1Bad65GMC is offline   Reply With Quote
Old 03-03-2014, 04:25 PM   #37
Cherub
Cherub's Avatar
wrd
Cherub is offline   Reply With Quote
Old 03-04-2014, 12:11 AM   #38
Low Elco
With a pile of parts like that, it's gotta be good!
Low Elco is offline   Reply With Quote
Old 03-04-2014, 02:28 AM   #39
mikentosh
mikentosh's Avatar
Thanks guys. Its coming together one part at a time. I'm trying to do something every day on it, big or small. This morning was sanding and spraying the rear window channels inside the doors. Last week I was focused on wiring, and put together my own headlight relay upgrade integrated into the factory style forward lamp harness.
BTW, after many months of waiting, all my wiring harnesses showed up from M&H Electric. They turned out awesome! They did such an exact job of matching the factory colors and plugs. I went with their classic auto fuse series which comes with an ATO style fuse block and some extra circuits for electric fans and fuel pumps. I highly recommend their setup for anybody doing a restoration on one of these trucks.
Old 03-05-2014, 02:49 AM   #40
y5mgisi
Second Chance Program
y5mgisi's Avatar
Subscribed!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-22-2014, 10:37 PM   #41
mikentosh
mikentosh's Avatar
Well the build has started. I've got a bunch of photos and stuff to go through but thought you'd like to see a couple of shots from today...
Old 03-23-2014, 05:15 PM   #42
mooseknuckles
mooseknuckles's Avatar
cool!
mooseknuckles is offline   Reply With Quote
Old 03-23-2014, 08:28 PM   #43
DrppdBlazr
DrppdBlazr's Avatar
Damn, nice build
Bodied Blazer Build
http://67-72chevytrucks.com/vboard/s...d.php?t=611842
DrppdBlazr is offline   Reply With Quote
Old 03-24-2014, 03:34 PM   #44
Project82
Bretzke Racing Inc.
Project82's Avatar
<--- Impatiently waiting for more progress!
1982 Chevy Silverado C-10 RCLWB - IN PAINT - Inferno Orange Metallic
Lowered 4.5/6 - 358 SBC 10.5:1, Comp XE268H cam, Aluminum heads, 650 Double pumper Holley carb, 2400 Holeshot Converter, upgraded T/h350 Trans. Stock Rear end for now (3.08 gear)
2004 Chevy Silverado 1500 LS RCSWB - Dark Spiral Gray Metallic
Lowered 2/4 - 4.8L V8 4L60E 10-bolt. some goodies --- NEW DD 11/9/12
"Expect the Un-expected"
"Gas, Grass, Or Ass...No one rides for FREE!"
Project82 is offline   Reply With Quote
Old 03-24-2014, 05:09 PM   #45
mikentosh
mikentosh's Avatar
Still need to go through the photos but you might enjoy this teaser video...
http://vimeo.com/89818376
Old 03-25-2014, 12:58 AM   #46
mikentosh
mikentosh's Avatar
Another photo I found on my phone. Looks better with both C5 vette wheels
And here's the tires that we are hoping to tuck under all four corners Should be a bit like a go-kart with this rubber on it.
Old 03-25-2014, 05:00 AM   #47
BAD B8B
that chassis tho!!!!!
BAD B8B is offline   Reply With Quote
Old 03-25-2014, 07:56 AM   #48
mooseknuckles
nice!
Old 03-25-2014, 08:50 AM   #49
Wasted Income
Boosted Member
Wasted Income's Avatar
Yowzer, this is gonna be sweet.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-25-2014, 12:49 PM   #50
Low Elco
Hot Stuff! Can't wait to see the next step.
