11-14-2013, 01:33 AM | #26 |
Re: Hellion Customs 1964 Blazer
Another pic
11-14-2013, 01:34 AM | #27 |
Another
11-14-2013, 01:35 AM | #28 |
Another one
11-14-2013, 01:52 AM | #29 | |
Me too!! |
11-14-2013, 04:11 PM | #30 |
Something CapFab said about your rendering made me look at it again ... are you going to put an air dam under the front to compensate for shaving the air flow intake in the hood?
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
11-14-2013, 04:44 PM | #31 |
Well when we did the rendering, I was planing on making the hood reverse opening. I have since worked in the engine compartment of a 67 GTO with a tilt front end, it definetaly made me realise that doing a reverse hood was not for me! It will have a late model style cable operated latch. I am going to find a 62-3??? hood that has the "style lines" by the signals. If you were thinking about air flow, I will be sealing the radiator to the core support and the fans to the inside of the radiator. The engine heat will just have to go out the bottom.
11-14-2013, 04:55 PM | #32 |
Any pics of the GTO and the job you did on it?
Wife and I are huge Pontiac lovers, as you can see on this page of my build: http://67-72chevytrucks.com/vboard/s...487100&page=22 I think this is going to be a fun build to watch, thanks for answering the questions !!
11-15-2013, 12:56 AM | #33 | |
11-15-2013, 01:08 AM | #34 |
McMurphy this is a 68 I did recently washed up and awaiting the flatbed to take to the Upholstery Shop.
11-15-2013, 01:17 AM | #35 |
I'm brainstorming and I don't have any doors For the Blazer. Does anyone know if the 64-66 Door Glass is flat glass? Anyone familiar with inside the doors? If I lay the B Pillars back to the point they would be vertical, would the glass have room to roll down and clear latch mechanism?
11-15-2013, 07:44 PM | #36 |
If anyone is really familiar with 64-66 doors, I could use some definitive answers to a few questions. I'm trying to sort out some issues with the quarter windows (length, weight, angle ECT....) I'm thinking about leaning the B Pillars/door frames back to the point where they are vertical. Plus I think it might look better.
(1) Is the door glass flat glass? (2) Does the factory setup actually roll up and down vertical? (The rear of the glass just comes away from the channels as it rolls down) (3) If I was to lean back B Pillar/ Door Frame to the point it went vertical instead of leaning forward, would the door glass have clearance at latch when rolled down? |
11-16-2013, 01:50 AM | #37 |
Ok it looks like I can lean back the B Pillars without any door glass to latch clearance issues. We modified the rendering and I think it looks better like this anyways!! What do you guys think? I'm hoping if I do it then I can move the quarter window motor to the front side of the wheelhouse for more room and get it closer to the center of the glass to help with it dragging/binding.
Modded rendering won't upload. I will post up tomorrow. Last edited by Hellion Customs; 11-16-2013 at 02:03 AM. Reason: Pic won't upload |
11-16-2013, 01:57 AM | #38 |
The front floor and inner rockers were pretty trashed so we cut the entire floor out for a "flat floor". It still has the stock supports and braces except the one that crossed the trans tunnel.
11-16-2013, 01:59 AM | #39 |
Another before pic of front floors
11-16-2013, 11:17 AM | #40 |
this is a very ambitious build
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
11-16-2013, 12:04 PM | #41 |
KEEP ON TRUCKIN'
Keeping the olives glued to this build.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
11-16-2013, 02:02 PM | #42 |
01-15-2014, 09:02 AM | #43 |
Its been a while since I posted on this build. I have been mostly hanging in the 47-59 builds section. Even tho we have been extremely busy at the shop with a few other full builds, I have found a bit of time to get some progress on the Blazer. So lets get caught up here
01-15-2014, 09:16 AM | #44 |
PM Bomp or Alan's Classic. If anyone's cut deeper into a 60-66, I haven't seen it. Cool project.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
01-15-2014, 09:25 AM | #45 |
Since my last update we have changed a few things. Well I has having trouble getting the side glass to work correctly in mock up, so while brainstorming and looking for ways to save weight on the setup, I realized I thought it would look better if the B-Pillar was straight instead of leaning forward. Also I painted a BMW with the green I had picked out for the Blazer and realized I did not like it so I decided I liked blue. So we changed up the rendering. What do you guys think?
01-15-2014, 09:31 AM | #46 |
So the first thing to do is get the body off of the frame and welded to the body table and the frame welded to the frame table.
01-15-2014, 09:36 AM | #47 |
Next thing before all the bracing goes in was to crawl around inside and find and center punch all the spot welds and install some Clecos in strategic location so I can make sure each panel goes back where it should.
01-15-2014, 09:39 AM | #48 |
More Clecos installed on all the panels going to be removed at some point during the build.
01-15-2014, 09:41 AM | #49 |
After bracing up the body I removed the wood flooring.
01-15-2014, 09:52 AM | #50 |
Next we remove the roof. Well thankfully most of the sides are bolted on which made it easy because every bolt broke. The front and rear are spot welded on and made things more difficult. I chose to fold down the rain gutter to gain access for the panel separator blade which will make for a bunch of hammer and dolly work later on but I need to keep the windshield frame and rear door opening intact at this point.
