11-18-2013, 02:55 PM | #26 |
Re: Camaro front clip questions
Yes ,18x10" w/4" backspace in rear, 18x7" w/3.25 backspace in front, (should have been 4.5 bs but couldn't get them in these wheels,) here are some pics of the narrowing, the finished pics are not mine, but you can get the idea, I will have them done soon and plan on posting the process . I was told the Porterbuilt units Delmo uses are 60" wide ,hub to hub, the mustang 2 crossmembers are 56-7/8" wide and The late Camaro/Nova clip is 62-1/2"wide.
Learn to deal with reality, or reality will deal with you. |
11-18-2013, 04:04 PM | #27 | |
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
11-18-2013, 04:08 PM | #28 |
ZR2RICK,
When you narrowed the subfrane, did you check the clearance for the motor? I was thinking there was not 2" of extra room between the frame rails. What exhaust are you going to run? Shane
11-18-2013, 06:07 PM | #29 |
Zr2, wow! Your brave tackling all of that. It looks good, hope it works out.
Buggy, I am drooling over that tire set up you have. That pic looks so good I would debate putting the bed on for a while. Hahaha. You can't beat wide tires on these trucks! To be honest, when I saw your first photo, I was like...ehh that's a nice restored truck. But now seeing that you have 4 link, and coil overs...It looks great and looks like you set it up to handle well. Great set up.
USCG Aviator C-130 1959 Stepside build - http://67-72chevytrucks.com/vboard/s...d.php?t=602386 |
11-18-2013, 06:12 PM | #30 |
I am using stock GM Trailblazer exh. manifolds they are very compact, and relocated the heater hose outlet and return on the water pump but ,yes there is plenty of room.
11-18-2013, 07:49 PM | #31 |
Spblack, its hard to tell without a cab and fender on it , some guys don't move the front axle centerline forward, and the front wheels will not be centered in the wheel well.
You can measure from the leading edge of the front cab mount to the leading edge of the front shock hole on the clip . Stock center line is 28-3/8". I put mine at 29-3/8" and it was centered up perfect IMO. |
11-18-2013, 07:58 PM | #32 |
Since we are talking about moving the front end forward, I have herd 2" is best. I see you did 1", what's the general consensus about how far to move front centerline forward.
11-18-2013, 08:16 PM | #33 |
Also, thanks for everyone's input, it is nice to have all the help.
Another question, how did you guys figure out your rimland tire fitment? Did you take it to a tire shop to measure what would fit or just go buy what others have found to work. I'm guessing your going to have to buy new rims as finding the correct backspacing front and back is not going to work on Craigslist, eBay, etc...
11-18-2013, 09:40 PM | #34 |
Here's a few threads on clips:
http://67-72chevytrucks.com/vboard/s...d.php?t=220256 http://67-72chevytrucks.com/vboard/s...d.php?t=440771 http://www.jalopyjournal.com/forum/s...d.php?t=148978 I did my 58 the No Limit way, I think moving the centerline on 55-57 trucks are different as opposed to the 58-59 the front frame is 2" longer +wheel wells are different shape. best to hang a fender on it to be sure. for some reason I can't upload pics , (except for my profile pic) you can go to my profile and see how the wheel is centered. |
11-19-2013, 03:19 AM | #35 |
Here is mine
https://www.youtube.com/watch?v=k-AA...4&noredirect=1 As for tire fitment I was going to just run stock 15" with 4" set back and then get the rims sized when I am done. The stock tires fit near perfect so I'll probable just keep them |
11-19-2013, 03:29 AM | #36 | |
Hahahaha!! Just kidding! It looks like your on your way!! Good Luck with you build and keep us posted on it!!! Later. |
11-19-2013, 03:42 AM | #37 | |
I imagine that your box is tubed with those tiers on there? |
11-19-2013, 04:14 AM | #38 | |
The Coil Over Shocks you have what make are they and what is the spring rate you have on them? Thanks Buddy. Cobra427sc |
11-19-2013, 08:46 AM | #39 | |
11-19-2013, 11:27 AM | #40 |
I hung my front sheet metal on and determined what height it will be alighned at for daily driving,and ended up withe the wheelbase 3/4" longer than stock, it ends up being an eyeballed thing ,because of the rearward arch of the suspension the lower your ride height will be the more the wheel needs to come forward to look centered. here is a web site that helped me immensely in figuring out correct back spacing needed. (http://www.rimsntires.com/specs.jsp)
hope this helps.
11-19-2013, 05:01 PM | #41 |
That is an awesome link! I also found this article from classic trucks.
http://www.classictrucks.com/tech/12.../photo_23.html I think when I get the clip mounted up, I'm going to take a make something like this after doing the measurements it hat classic trucks did. I'm going to do my own version so it measures from centerline and from the mounting face of hub.
11-19-2013, 05:38 PM | #42 | |
It looks like that he is using a Mustang II front suspension kit? Will this work with the Camero/Trams An clip?? I imagine the same rule apply's to both or all applications. Am I correct in assuming this? |
11-19-2013, 05:45 PM | #43 |
What ever you did it's just perfect! Your Truck is Sweeeeeeet!!! Nice Job and thanks for sharing it with us, also thanks for the info. I have a long way to go and still need some parts, but there is a light at the end of the tunnel...I can barely see it, but I know it's there. |
11-19-2013, 06:05 PM | #44 |
All applications apply. Looks like it's just a matter of understanding what your measuring and where the measurement comes from (hub face, center). The only variable is where the widest wheel will touch on the inside turn radius. They found that it was the upper control arm, but it's going to be different with other set ups. That's why I'm going to build that tool to check where it will hit all the way around for maximum size and then reduce for clearance. And see how big a wheel will fit and reduce from there if needed.
11-19-2013, 09:51 PM | #45 |
59stepside, I just measured mine and the wheel base is 115 1/2 so mine is moved 1 1/2 inches forward from stock.
11-19-2013, 11:30 PM | #46 |
Elev8r Man
Looking at this picture made me start looking for a teardrop trailer again. I think it would be great with the 55 Burban I am working on. Especially when we take it to Colorado. I imagine driving it across the states with the wife and kids, I think it would be great.
BTW, your truck looks perfect. Thanks for the re-inspiration
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!! 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. Last edited by fabguy; 11-19-2013 at 11:32 PM. Reason: Spelling |
11-20-2013, 12:49 PM | #47 |
Thanks for measuring! This gives me a good idea on where to start. I will start with that, hang a fender and see what looks good. It's just going to be hard to eyeball because my garage is so narrow I won't be able to get much perspective from the side.
11-20-2013, 01:45 PM | #48 |
Finally able to upload pics here is mine 1" forward, 115" wheel base
11-20-2013, 01:52 PM | #49 |
if that is the final height you'll be running it looks good to me, but you will want to set your ride height to get a good idea of how far forward to set it because the perception changes the further up into the wheelwell the wheel is.
11-20-2013, 02:27 PM | #50 |
That was with the a-arms leveled to simulate ride height at mock up and frame tacked.
Truck is blown apart right now, I may add some 2" drop spindles later , but I think it'll be just fine. I just didn't want this look for the front wheel: |
