#26 |
Re: New member, K20
#27 |
Re: New member, K20
#28 |
Re: New member, K20
#29 |
Re: New member, K20
My daughter and all the neighbor kids love to ride in "Big Blue" they could care less about my neighbors 2014 Ford F350 Platinum Edition $60,000 truck! |
#30 |
Re: New member, K20
#31 |
Re: New member, K20
#32 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: New member, K20
The Bus Type Heater does the same as a stock Block Heater. You plug the 110V plug into a electrical socket and it will heat the engine and heater coil. Anything that comes into contact with antifreeze will be heated. Great for cold winter months start up.
My advise is to tear any wiring that doesn't come from the factory out of the truck and if necessary start over. Used Scrap Northern trucks have better wiring harnesses than southern trucks as there not dried out from the heat. The switch on the dash is the one mounted under the dash to the right of the steering column? Get yourself a 63 Shop Manual. The American Version has less illustrations than the Canadian version apparently. I have a spare if you need one.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
#33 |
Re: New member, K20
Unity Spotlight Bracket#31.
They came with a tapered rubber wedge for 60-63 Chevy trucks. They were used on other vehicles as well. Take a look for these when you spot an old Fire Truck. Please tell me the hubcaps hanging on the wall, in post#28, are not from this truck? Original spiral rear shocks!
#34 |
Re: New member, K20
Here's the switch, also I forgot to mention I did replace the voltage regulator. I like to start with the most expensive and hardest part to replace then work backwards only to find its a loose wire, the wife loves that stuff! |
#35 |
![]() Join Date: Sep 2011
Re: New member, K20
Just saw this thread. I'm along for the ride. Great looking truck you have there!
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
#36 |
Re: New member, K20
it appears that in picture #16 that it still had the original factory steel wheels. Those are probably the factory hubcaps and I have been looking for a set of factory 8 lug wheels and caps for my 64 single wheel 1 ton 4x4 military truck. Who would think he would take them off....
#37 |
Re: New member, K20
63 4WD. did not come from the factory with hubcaps. All my literature states they did not, nor do you see any factory photo's with them on.
#38 | |
Re: New member, K20
#39 |
Re: New member, K20
I welded some clips on the 16 inch rims and run the caps when I'm feeling a bit crazy. |
#40 |
Re: New member, K20
Without.... |
#41 |
Re: New member, K20
Nice truck I have to ask what size tires are those and what brand. Thanks again Awesome.
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#42 |
Re: New member, K20
With. |
#43 |
Re: New member, K20
Whew, that would have started another headache!
#44 |
Re: New member, K20
1 GMC and 1 Chevy, depending one which side of the truck your looking at. |
#45 |
Re: New member, K20
The spare |
#46 |
Re: New member, K20
The other four. |
#47 |
Re: New member, K20
#48 |
Re: New member, K20
oem4me has a set of 61-63 8 7/8 I.D. painted caps I think.
The ones from the front 58-60 Chevrolet Both rears 66
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 11-21-2013 at 05:54 PM. |
#49 |
Re: New member, K20
Thanks for the help and info on my truck.
#50 |
Re: New member, K20
I posted awhile back that my battery would die if I turned the headlights on after driving for about 30-40 min. I went back and pulled all the plow wiring out from the headlights and re grounded the lights, took the family for a drive, turned on the headlights and bam the volt gauge drops! Turned on the heater and bam, the gauge drops all the way! Made it home with lights almost completely gone, backed into the garage, turned it off and of course no juice to start. I have replaced the alt and voltage regulator, but I am wondering if the alt is no good? Could my belt have anything to do with this? I fabed my own power steering bracket and am running a double pulley on the alt to the steering pump if this means anything. Thanks for the help.
