#26 |
Re: What needs to be done to this truck?
Sweet, that TBI is rockin.....
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
#27 |
Thanks man!! I am loving this truck. Only thing I need to get right is the serpentine belt. It's got a lot of squeal to it right now. I think it just needs to be a little shorter to tighten it up. Tensioner is new but I guess it could still be bad given the hit and miss nature of parts these days.
Best of all? Getting about 18 mpg on 50/50 driving. Stoked about that. |
#28 |
I'm 30 and out of just about everyone I know I am the only one who appreciates white letters OUT. That truck, lower. Also, try and find the taller of the front air dams that were available, I think it would help the appearance.
I know you didn't ask about underhood, but personally I love the look of the tall factory air cleaner arrangement with intake duct from the core support. Also, there is a thread about an engine bay transformation in 12 days or something like that...if you have that itch, I'd jump on it. No tube steps, not on square bodies, they just don't look right. Side pipes? Maybe. Some trucks can pull them off, particularly when lower. Lets see a shot from the front and rear, might help give us ideas.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
#29 |
Was definitely thinking about the bigger air dam. I like the way they look. Went with the open air cleaner to help it breathe better on the recommendation of the tuner. I kinda like the cleaner look.
#30 |
With the new engine running top notch, it might not be long before those tires are bald. When you replace them, put the letters in. The rest I would leave as is and drive it. Truck is lookin good.
#31 |
I wish they made more 20's with raised white letters even. I think it would look very cool with all of the 20" 5 spoke classic wheels like Torque Thrusts/etc. I always thought white-WALLs were for old people, black-walls for dorks, and raised white letters for cool people.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
#32 | |
#33 |
Born a Chevy Man
Ditch the nerf bars and I like the white out. Those nerf bars just down right wrong for your truck. MO
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
#34 |
Nerf bars out. Keeping the white letters out as well. I actually really like the look. Going to put some miles on it and then see how I feel. It's a blast to drive and have actually gotten a lot of compliments on the truck.
#35 |
ditch the bedrails
lower it shorter tires
70 SWB STEPSIDE 70 BLAZER 09 challenger |
#36 |
Born a Chevy Man
Bet you did not have those Nerf bars on when you got the compliments on your truck. That is a good looking truck. So I see why you get those compliments.
#37 |
Born a Chevy Man
I also like the (OE) bedrails and like the stock height and stock height tires. MO
#38 |
nothing. Truck looks great.
#39 | |
#40 |
Thanks for the feedback guys. I think I will just focus on getting the motor running absolutely perfect. I think the timing could be dialed in from here. I will focus on that and just enjoy driving the truck.
Installed the new motor with the timing marks aligned but never pulled the est plug with the motor running to dial it in with a timing light. I am guessing there may be some more power or efficiency hanging out there since I haven't. Sounds like with e TBI you really need to put a light on it to dial it in proper. |
#41 |
You just need to disconnect the EST connector, set your base timing as normal, then lock down the distributor and re-connect EST. Light does make it easier.
#42 |
Engine builder told me to set it to 10 degrees btdc so I am guessing that's what I need to baseline it too. And maybe try to advance it a little to see how it reacts. By advancing, would that mean I move it more toward 0? Like 7 degrees btdc?
#43 |
![]() Join Date: Oct 2013
Cool truck - tires black or white letters, like either way. leave ride height as is or do mild lowering. nerf bars way too big. if you what a little more power put a aftermarket 1 inch spacer under throttle body.
#44 |
Fun Stuff
![]() Join Date: Jan 2010
Truck looks good. I'd say lower the rear to match the front, level makes for better handling. To advance the timing you would move away from the 0, bigger number BTDC. Usually you would set the base at 0, then the computer adjusts for best advance.
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd |
#45 |
Your ECM is running your timining, try setting it at 0, which is what it is supposed to be at.
#46 |
Looks to me you want to lift your truck. So with that do the spring swap, but don't do the nerf bars. I'm not too much into the whole lift it thing although I do like kool four runners. Though they are far and few and between on here and I don't feel your truck is heading in that way. I like the looks of your truck as is. Get it running right and it will be a fun sleeper, bed rails and all. Happy motoring.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#47 |
I would leave it the way it is too. looks great white letters and all
#48 |
Leave the booger bars off. It looks fine as it is...just drive the piss out of it.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
#49 |
This is the est connector right?
#50 |
i would say a light tint. loose the nerf bars and rails. add a bed cover of some sort. lower but just slightly like a 2/3 or at most a 3/4 drop. nice wide tires all around.
