Old 11-20-2014, 08:25 PM   #26
3/4ton Randy
Re: Project slow-verhaulin'
The gauges are autometer antique, one of them is a quadmeter...
I also stained and put a couple of coats of polyurethane on it. I am in the middle of rewiring the truck, hence the wires everywhere..
3/4ton Randy is offline   Reply With Quote
Old 11-20-2014, 08:29 PM   #27
3/4ton Randy
The motor on these things does look cool... what a beast! Prius has envy!
Old 11-21-2014, 11:52 AM   #28
aggie91
I'm just glad to be here!
aggie91's Avatar
Nice.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 11-28-2014, 07:28 PM   #29
RANDY COX
RANDY COX's Avatar
Did you get your fender straightened out, you might need to lower your inner fender where it mounts to firewall. Looks like it needs to drop down lower for fender to line up..
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 12-22-2014, 10:17 PM   #30
3/4ton Randy
Okay thanks, I will try that...
Old 03-25-2015, 07:30 PM   #31
3/4ton Randy
Making a little progress on the truck... if you haven't read the EUREKA thread about the weatherstripping from a Honda civic they are not kidding! I bought some online, it was delivered in two weeks and installed in 10 minutes with NO paint removing glue. Awesome! The weatherstripping is on the passenger door, I don't know how well you can see it.
Old 04-05-2015, 09:58 PM   #32
3/4ton Randy
Here are a couple of more pictures of the Honda Civic weatherstripping...no glue! Press and squeeze a little...
Old 04-05-2015, 10:04 PM   #33
3/4ton Randy
I'm still working on the wiring, and have found a couple of good tricks. Positive and negative bus terminals! It will really clean up your installation and it makes diagnosing problems easier. For example, all the grounds under the dash go to a bus bar which goes to the negative battery cable via a larger diameter wire.
Old 04-05-2015, 10:08 PM   #34
3/4ton Randy
You can also do the same thing with the positive wires. Here I used an insulated post... I will post another picture when I am finished with the wiring.
Old 07-20-2015, 09:33 PM   #35
DPowers
DPowers's Avatar
Truck looks good. Any progress lately? You get the fender to line up ok?
DPowers is offline   Reply With Quote
Old 07-21-2015, 09:08 AM   #36
3/4ton Randy
I've been too busy lately with other projects. I never did get the fenders to line up right. I'm just going to take it all back apart and start over.
Old 07-27-2017, 09:00 PM   #37
3/4ton Randy
Time to resume the project! I am going to disassemble the truck so I can install a front crossmember with power disc brakes out of a 1982 Chevy.
Old 07-27-2017, 09:06 PM   #38
3/4ton Randy
So I have the fenders removed, I drained the radiator which did have a good bit of rust in the water, and then I removed the upper radiator hose and saw this stuff! Kind of soapy and might have prohibited the thermostat from opening? Anybody know what it is?
Old 07-27-2017, 09:15 PM   #39
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice truck and nice work on it. I'm not sure what that stuff is other than corrosion and maybe broken down/crystalized coolant?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-27-2017, 09:17 PM   #40
3/4ton Randy
Look at the size of this water pump! I don't see a harmonic balancer - so is this engine internally balanced?
Old 07-27-2017, 09:27 PM   #41
3/4ton Randy
Thanks for the tip on how to hook the chain up. Worked great.
Old 07-27-2017, 09:32 PM   #42
3/4ton Randy
Adapter for an oil filter. Anybody know what kind? I understand they originally used a different style filter.
Old 07-27-2017, 09:33 PM   #43
3/4ton Randy
Power steering? Not at this time
Old 07-28-2017, 08:28 PM   #44
3/4ton Randy
Another part of this project is to get rid of the SM 420 transmission. Granny-gear 4 speed, and replace it with a modern standard transmission. One of the problems as I understand it is - how do you mate a newer standard transmission to an old GMC 305 V6?
Old 07-28-2017, 08:36 PM   #45
3/4ton Randy
...but what about the clutch plate, and flywheel? I just decided to ship the flywheel to the manufacturer of the conversion kit, who says they will make a copy and set me up with a workable system with a pilot bearing, clutch plate hydraulic throwout bearing...
We will see
Old 08-01-2017, 04:21 PM   #46
3/4ton Randy
Sorry to be jumping' back and forth, but this is the way this build is going. On installing the '82 crossmember into the '66 frame, you have to drill one hole in the frame rail and enlarge another.
Old 08-01-2017, 05:28 PM   #47
3/4ton Randy
I am putting a 14 bolt ff axle from an early '80s truck, and everything seems to be lining up. The leaf springs sit right on the spring perches on the axle.
Old 08-18-2017, 03:40 PM   #48
3/4ton Randy
I've started working on the front suspension again, I got a coil spring compressor and was able to get those installed. Now I'm trying to bolt the steering linkage/tie rods ends up, and there is an issue...
The first picture is of the '80's C20 bracket that bolts the steering hardware to the frame. The next picture shows still bolted to the frame is the '66 bracket which is oriented more or less vertically
For the time being I would like to keep the '66 steering and mate it to the '80's tie rod ends, etc.
