Old 01-26-2014, 07:44 PM   #26
72c10suburban
72c10suburban's Avatar
Re: '72 Suburban - 2005 L59 5.3/4L60 swap
72c10suburban is offline   Reply With Quote
Old 01-26-2014, 07:47 PM   #27
72c10suburban
Got everything out of the way this weekend, now just to clean up the frame and shoot some paint on it.
Old 01-30-2014, 04:18 PM   #28
Number98
Prestige Worldwide
Number98's Avatar
Your putting together one sweet Burb, When I get mine back on the road we will have to hook up (I am out near Peachtree City).
Anyway, where did you pick up the dropout LS package? Locally or?
Number98 is offline   Reply With Quote
Old 01-30-2014, 07:42 PM   #29
72c10suburban
Thanks! Im game to get together. Hope to have it on the road by spring and start rackin up some miles on it.
I found it on CL. Guy in Gainesville had it. Turned out its a 2003.
Old 02-01-2014, 12:40 PM   #30
tinsoldier
tinsoldier's Avatar
I am assuming you are not planning to install the air conditioner with the Ebay mounts?
tinsoldier is offline   Reply With Quote
Old 02-01-2014, 05:08 PM   #31
72c10suburban
Na. When I do go A/C I'll probably go vintage air and use some sort of high mount bracket.
Old 02-18-2014, 12:26 AM   #32
72c10suburban
Progress has stalled for a bit on the swap. The more I've worked on it, the more damage I've seen on the frame. Looks like its had the rails knocked around and poorly repaired. The driver side wheel is back an inch, and the front crossmember is welded to the rail. The passenger side has a kink in it in front of the tranny crossmember. Too much damage to repair so i found a parts burban in the classifieds here and struck up a deal with member 'uncle' for it. Lot of good stuff left including front and rear air and the headliner stuff.
Old 03-01-2014, 10:04 PM   #33
truckdude239
truckdude239's Avatar
I bought the same intake the picture in th3 ebay add its put together wrong the bracket side goes on the airfilter side. With that said i did mine the same as picture cut off the bracket and twisted the tube till the filter was pointing torward the firewall / fendor whell
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-01-2014, 10:59 PM   #34
72c10suburban
Thanks for the info. For the price I figured I could make it work. Got any pics of yours installed? Did you relocate the battery?
Old 03-02-2014, 02:09 AM   #35
truckdude239
I'll see if I can't find one or take o e and nope battery's still there I twisted the tube till filter was angled away from battery
David fuller
2000 Tahoe 5.3l 378
Old 03-02-2014, 01:09 PM   #36
truckdude239
heres my intake same as yours
David fuller
2000 Tahoe 5.3l 378
Old 03-05-2014, 06:00 PM   #37
72c10suburban
Thanks David. looks good. Im still debating on relocating the battery to the passenger side and trying to use the air box that comes with the intake.
I've worked on the new frame a little the past couple days. I also got the Energy Suspension body mount kit in.
Old 03-05-2014, 09:33 PM   #38
Average Joe
Average Joe's Avatar
Nice progress. Any thoughts on building a new exhaust b4 you put the body back on?
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 03-06-2014, 02:04 AM   #39
desertdogg
desertdogg's Avatar
Wow great job ! you has some skills man ! congrats on your new drive train and build. I just bought a 5.3 with the 4l60e as well hoping to be able to get it installed soon, keep up the great work !
desertdogg is offline   Reply With Quote
Old 03-06-2014, 08:15 AM   #40
ls1nova71
ls1nova71's Avatar
I always move the battery to the drivers side. Not only does it allow you to use the factory air box, but also the battery cables. Makes it look cleaner in my opinion too.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-07-2014, 08:43 PM   #41
72c10suburban
Thanks. New exhaust is on the back burner for now. I got the exhaust done a couple months before i got the bug to do the LS swap, so for the the 307 that was in it i just went with 2.25 pipe. Going bigger is near the top of the list, but its gotta go down the road first
Thanks. I was hoping to be on the road by now, but between the weather and having to do the frame its kind of delayed me.
Old 03-23-2014, 11:43 AM   #42
72c10suburban
Frame is finally swapped. I used the original rear suspension on the donor frame with new Energy Suspension bushing as well as new body mount bushings. Went pretty easy but took about 7 hours.
Now, lets get back to an LS swap.
Old 03-23-2014, 02:57 PM   #43
solidaxel
solidaxel's Avatar
I moved the tube instead of battery, looks like the same air cleaner kit
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-23-2014, 07:18 PM   #44
solidaxel
solidaxel's Avatar
Originally Posted by 72c10suburban View Post
Thanks, its slowly starting to come togerther.
The intake is a ebay special. $57 shipped. I figure if it wont work, i can always resale it. Its a 4" tube.
Ebay air intake
The parts for my fuse box and OBD2 plug came in today. I'm going to build on the fuse box how to on LT1swap.com and just add 4 circuits.
When I looked up your ebay site they want 399 for there kit?
Where did you find the 57 dollar one?
LS 3 4L70E
Old 03-25-2014, 09:43 PM   #45
desertdogg
desertdogg's Avatar
I found it down on the bottom try this link
http://www.ebay.com/itm/00-01-02-03-...3D390608038206
Trying to get thru my LS swap
Old 03-26-2014, 09:23 AM   #46
solidaxel
solidaxel's Avatar
[QUOTE=desertdogg;6594848]I found it down on the bottom try this link
Thanks, found it, for that price I just wonder how good the air filter is, but I guess for that price you could use a K&N,
Did you ask them if they had them in Black?
LS 3 4L70E
Old 03-26-2014, 10:29 AM   #47
desertdogg
desertdogg's Avatar
[quote=solidaxel;6595573]
I found this one in black
http://www.ebay.com/itm/00-05-GMC-Yu...3D390608038206
Old 03-26-2014, 10:27 PM   #48
72c10suburban
The one i ordered was supposed to have black rubber, but came in red. I messaged them and they said that there vendor didnt have it in black any more, but offerd $10 off on it.
Old 06-01-2014, 12:40 PM   #49
Average Joe
updates?
Old 06-01-2014, 03:29 PM   #50
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
http://www.siliconeintakes.com/index...b6d53dfa3103ec
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
