Old 12-07-2013, 09:53 PM   #26
duallyjams
duallyjams's Avatar
Re: My build thread- 67 C10 SWB
Tetanus Shot
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-07-2013, 10:02 PM   #27
67chevy1
67chevy1's Avatar
That cab lifting apparatus is another great idea even for lifting off for the 1st time. I need to figure out how I can save your thread to a zip drive and divide it into chapters. LOL
67chevy1 is offline   Reply With Quote
Old 12-07-2013, 10:06 PM   #28
67chevy1
67chevy1's Avatar
I've been thinking about that filler neck idea we were talking about and you could do like you were talking and weld it to the patch piece that you put in the truck then glue the rubber grommet in place. Then set back and watch and laugh at anyone that tries to siphon gas out of it.
Old 12-07-2013, 10:10 PM   #29
Z10
Z10's Avatar
Very nice work.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 12-07-2013, 10:15 PM   #30
checkmate211e
checkmate211e's Avatar
HAHAHAHA! Thanks guys
My 67 Chevy C10 SWB build: http://67-72chevytrucks.com/vboard/s...30#post6406130
Hydroboost conversion: http://67-72chevytrucks.com/vboard/s...22#post6405622
checkmate211e is offline   Reply With Quote
Old 12-07-2013, 10:19 PM   #31
checkmate211e
I will take another pic of it soon. I am posting as many pics as I can. I have been overwhelmed lots of times during this build (the dash and vintage air evaporator is really eating alive right now). So I want to give encouragement to all the other first truck builders out there struggling with confidence.
Old 12-07-2013, 10:32 PM   #32
checkmate211e
Shaved the side marker light and replaced the lower right pocket that always seemed to catch all the run off battery acid. Moving the battery to under the truck to solve this problem. This was my "fishing" trip to Carlisle, PA for Spring Swap Meet. One of the fenders was a waste of money (aftermarket). One of the inner fenders was beyond saving. The keeper fender cost $40 and came with the pocket patch.
Old 12-08-2013, 12:15 AM   #33
sublime1996525
I love the dash idea! Can't wait to see this coming along more.
2006 Z06
2013 Cruze
sublime1996525 is offline   Reply With Quote
Old 12-08-2013, 12:21 AM   #34
67chevy1
67chevy1's Avatar
Are you having to use any body filler where you weld or can a person put weld in and grind down flush enough not to notice the repair. I am a certified pipe welder but haven't done much welding on thin body metal.
Old 12-08-2013, 01:02 AM   #35
MoreWorkToDo
Smile Re: My build thread- 67 C10 SWB
Great question, I'd be interested to hear others' experience as well. I've been told by experienced hot rodders and body guys that even with the best weld and grind jobs, a skim coat of filler is needed to finish them out.
I was worried about filler in my build, but no longer. The time it takes to get perfect grinds just isn't worth it to me. Brand new cars on the lot have filler, and so will my '69 C10.
MoreWorkToDo is offline   Reply With Quote
Old 12-08-2013, 01:31 AM   #36
67ctener
67ctener's Avatar
Great job with the welding, everything looks real nice
67ctener is offline   Reply With Quote
Old 12-08-2013, 08:20 AM   #37
checkmate211e
Here is what I have done with the dash: Had to split it into 3 pieces to keep the curves in the dash in proportion to the width of the cab. I won't be using the metal attaching the dash to the windshield permanently, it is just there to help hold it up. I cut the Bel Air dash where it starts to bend down and used the original C10 cross brace and added the metal I needed to fill it in. Eventually, a console will be built. I have bucket seats out of a 93 BMW M3 that I plan on using, picked up on craigslist for $85.
Old 12-08-2013, 08:26 AM   #38
checkmate211e
When I first started the build I did not want to use any body filler, but there is only so much you can do with a hammer, dolly, and stud gun (bought one of them as well). Not only that, but these trucks were not made perfect, so I don't think perfection without a little plastic is possible. Maybe if you are that good, but I'm not. The problem I have found is that if you try to fill up too much with weld, you are likely warping the metal around your weld. If you want a show quality paint job, most hot rod builders I have seen (on tv anyways) always use a couple skim coats of plastic over the whole car.
Old 12-08-2013, 09:52 AM   #39
checkmate211e
Here is a pic of the jig I made to form sheetmetal for the back window channel.
Old 12-08-2013, 08:14 PM   #40
checkmate211e
2 steps forward, 1 step back.... Put the engine and transmission into the frame and bolted down. But cracked the alternator bracket trying to get the bolt bushings to loosen up.
Old 12-08-2013, 11:06 PM   #41
Artikgrau325is
Very impressive build, but I just wanted to say that your cab lifting idea with the cherry picker and tow hitch ball is the most genius thing ever. I have a 1 car garage so I can't put my cherry picker on the side of the frame to lift my cab...this looks like the perfect solution, since the cab has no windshield and I'd be able to go through the front.
Are there any other details I should know before building the box and getting the ball hitch, or is it as easy as it sounds?
Artikgrau325is is offline   Reply With Quote
Old 12-09-2013, 12:07 AM   #42
checkmate211e
Thanks! I will take more pics of the box tomorrow night. Cut some grooves in the boards so that the cab won't move around. The weight of the cab will be enough to hold the cab into the grooves. Lift it up very slowly, and also have a heavier person hold onto the cherrypicker handles just incase the jack end wants to tip. My cab is stripped down, so it doesn't weight much right now. I pulled it off the frame by myself once, but don't recommend it if you have an engine in it. I also had the frame on wheel dollies so I could slide the frame out once the cab was lifted off.
Old 12-09-2013, 10:17 PM   #43
checkmate211e
More pics of the cab lifting brace. The trailer hitch is just a cheap hitch with the ball turned upside down, it slides perfectly into the engine crane arm. Notice the slots cut in the box to keep on the lip on the door opening. I put the hole toward the front of the cab because that is where most of the weight is. If your cab has more weight (seats, gas tank, etc.) you may want to take that into consideration when you drill the hole.
Old 12-09-2013, 10:34 PM   #44
67chevy1
67chevy1's Avatar
what kind of headers have you got on the engine?
Old 12-09-2013, 10:35 PM   #45
checkmate211e
Sanderson, bought them from Early Classic Enterprises.
Old 12-11-2013, 08:39 AM   #46
checkmate211e
Just bought a driveshaft that fits a 92 Caprice (700r4). Looking at the wheelbase, our swb is 115" and the Caprice is 115.9". Has anybody tried this driveshaft before?
Old 12-11-2013, 08:50 AM   #47
lolife99
67-72 parts collector,…
lolife99's Avatar
Great build!
Your cab lifter using the hitch ball is genius!
Keith
Convert to disc brakes.
Old 12-11-2013, 03:05 PM   #48
jimdaug
Does the cab handle that lifting device without any bracing? I didn't see if you had any or not.
I'm wanting to lift mine up enough to get some paint on the frame underneath, but I'm worried about the cab warping. Especially since my rockers are rusted out.
jimdaug is offline   Reply With Quote
Old 12-11-2013, 04:00 PM   #49
steelhorse
steelhorse's Avatar
Wow, Great job so far.
steelhorse is offline   Reply With Quote
Old 12-11-2013, 06:26 PM   #50
checkmate211e
I don't think it has warped any. I guess it depends on how much weight you have in the cab (seats, steering column, etc.) and what kind of condition the rest of the cab is in. I didn't have any braces on the cab, but you could put in braces across the doors if you want to take the precaution.
Thanks for the compliments guys!
