Old 04-25-2015, 02:37 AM   #26
In The Ten Ring
Re: In line filter suggestions?
I am so glad I found this thread again (even more glad the forum allows one to read through all the threads they started).
I am officially dropping my plans for an extra filter under the cab.
I was going to go with 3/8th inch tubing for the supply to the pump but now I think I'll just use 5/16th inch like it had before.
QUESTION: I used 3/8th inch from the tank through the floor so I could use a 3/8th inch shut off valve I had. Is there a 3/8th inch to 5/16th inch connector?
NEVERMIND!
I found this:
http://www.ebay.com/itm/Fuel-Line-Co...11918d&vxp=mtr
In The Ten Ring is offline   Reply With Quote
Old 04-25-2015, 03:22 AM   #27
nzc10
nzc10's Avatar
I like the clear plastic inline filters in the engine bay after the pump easier to spot any fuel issues
"I ain't got no time for side tracks!"
69 R/T Charger
72 C10 Chevrolet
85 302 Jaguar
99 955 Daytona
10 1050 Speed Triple
nzc10 is offline   Reply With Quote
Old 04-25-2015, 05:53 PM   #28
In The Ten Ring
ttt
Old 04-25-2015, 07:57 PM   #29
MAC71
MAC71's Avatar
I always use the GM filters that use the O ring fittings. The flow well, filter well and will not leak. Also every autoparts store has them. They are Stainless steel so you could polish it if you wanted to. Wix pn# is 33481. Also a late 60's ford coil bracket works well to mount the filter.
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
MAC71 is offline   Reply With Quote
Old 04-25-2015, 08:00 PM   #30
MAC71
MAC71's Avatar
This is not on my truck but my vette but you get the idea.
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
Old 04-25-2015, 08:23 PM   #31
In The Ten Ring
Dang that looks nice!
I'm still tempted to do the same thing (or something similar) but so many people on here think it's overkill since the sending unit has a sock and the 6 cylinder carb has its in-carb filter.
Old 04-25-2015, 08:39 PM   #32
Warrens69GMC
Warrens69GMC's Avatar
Fram G6566
http://www.autozone.com/1/products/5...ram-g6566.html
Old 04-25-2015, 09:08 PM   #33
EARNHARDT#3
EARNHARDT#3's Avatar
Originally Posted by TBONE1964 View Post
Greg,
If your carb has a filter (like a Q-Jet) then it should be plenty. The in carb filters do a great job at filtering which is what they are suppose to do. It does not matter how many filters you have before it, if it fails then you have junk in the carb.
The stock GM fuel system is more than capable of filtering and supplying fuel to your engine unless you are running 9 second 1/4 mile times. Then things just need to be bigger.
I agree! All of these little filters people add drives me nuts. If your tank is rusty, replace or clean it. If your lines are rusty inside you can bend all new ones and get new rubber hoses and stainless clamps for less than $25.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 04-25-2015, 11:23 PM   #34
In The Ten Ring
I hear you man. I was going to put an extra filter rather like the one you've shown here but it's just too much trouble. Besides, I have 250 I6 with mechanical pump and most people told me not to.
I had my tank "renewed" so that's good. I am about to finish up bending all new Poly Armor lines. I had my carb rebuilt. I put on a new Carter fuel pump yesterday. I have a new sending unit from Tucker.
