#26 |
have someone apply the brakes loosen the bleeder screw and see how much pressure the brake fluid has and do the same to the other side if they are differant then you know where your problem lies
#27 |
all this about the calipers and hoses, did anyone think that the propotioning might be bad or stuck? i have a 79 3/4 ton van that had one go bad. when you applied the brakes it would turn right then go straight, when you released the brakes it would try to go left then straight. i changed both rotors, calipers, wheel bearings and still had the problem until i changed the valve.
i know they never go bad, right- but MINE DID!
jim gallagher |
#28 |
Re: Well..new tires and alignment, STILL veers violently!! HELP!
clean the caliper mounts every time you remove the calipers. they slide on the resting points and if their is rust or dirt there it will cause the caliper to hangup and drag.
jim gallagher |
#29 |
Hollister Road Co.
I had the same thing on a 92 GMC 1500 and it was brake line after I changed everything else. The line was colapsed inside and would not let fluid return to the master making the caliper drag. I would change them both and be done with it.
#30 |
Happy to be here
![]() Join Date: Mar 2000
Digging up bones? This thread was started in 2003.....
#31 |
laying low
![]() Join Date: Mar 2001
And the original poster either never found his problem or sold the truck or gave up or just didn't want to finally post what the problem was?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#32 |
2003? surely it is fixed by now.
Rest in Peace Ed. Thanks for all the good times. |
#33 |
He's not around anymore. I remember reading about his welcome wearing thin as well.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-26-2005 at 12:39 AM. |
#34 | |
Seņor Member
And N2TRUX... of course, it's Xmas. We're bored. ![]()
#35 | |
Happy to be here
#36 |
Project92 SWB stepside
I saw Tim over at FSC. A character for sure!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
#37 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
He had some issues with agirl friend or something have not seen him for quite some time...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#38 |
Maybe he "Veered Violently" into the path of an on-coming 18 wheeler, or off a cliff, and was never heard from again......
![]() Brakes are not something you half-ass or do on the cheap. I'd rather be able to stop than go any day of the week. ![]() |
#39 |
I miss TIMSPEED!
Mike |
#40 | |
