Old 12-29-2013, 01:24 AM   #26
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: Anyone running 18x7 & 18x9 showwheels streeters?
Here is Brn_Agn's 69. and his comments on his wheels. I kept this info for use on my old 70 (which had the wider rear)
3.5/5" drop
I am running 17"x8" wheels on the front with 4" of backspacing. The tires are 255/50/17 Nitto NT-450's. I have not observed any rubbing.
On the rear I am running 17"x9.5" wheels with 6" of backspacing and 275/50/17 Nitto NT-450 tires. The rear axle is from a 72 model, so it is wider than the 1969 rear axle. There is only about 1" of clearance between the back of the tire and the fender well on both sides. If I had to do it over again, I would use rear wheels with 5" of backspacing as a cushion and to bring the wheels out closer to the bedside for a "nicer" look.
http://67-72chevytrucks.com/vboard/s...=370815&page=7
That truck just looks "right" to me! I personally prefer that look over 20"+ wheels. It still looks like a truck, but updated.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 12-29-2013, 01:46 AM   #27
Keating121
Keating121's Avatar
Wanting some new wheels and tires on my 67. So what exactly are you going with on the wheels, and how much backspace did you decide you need to make it all work?? Still staying away from spacers? Thanks
8/24/13 First Classic Truck
'67 Short Fleetside, Candy Apple Red! 350ci, Holly 750 double pumper (too much, will change soon), Headers with FlowMaster exhaust, 700R4 tranny.
Keating121 is offline   Reply With Quote
Old 12-30-2013, 06:34 PM   #28
67ChevyRedneck
67ChevyRedneck's Avatar
Yeah, I've located a couple of 71/72 rear axles. They're 1.5" (0.75" per side) wider than the 67-70 axles. If you still have 6 lug, your wheel options are pretty limited. Are you converting to 5 lug disc brakes, etc? I'm converting mine to 5 lug (installed disc brakes years ago with ECE 6 lug rotors).
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-30-2013, 07:04 PM   #29
Z10
Z10's Avatar
Originally Posted by jrdv View Post
18's front 20's rear.
JRDV,
I'm running the same size wheel front and back but hate the size tires I choose and need to change them. What size and brand tires are you running?
Thanks,
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 12-31-2013, 12:01 AM   #30
jrdv
jrdv's Avatar
Originally Posted by Z10 View Post
JRDV,
Thanks,
295/45/20 and 255/45/18 Toyo Proxes. I wish I could go a little wider in the back!
John
jrdv is offline   Reply With Quote
Old 12-31-2013, 12:58 AM   #31
Z10
Z10's Avatar
John
Thanks John, I appreciate it.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 01-02-2014, 01:39 PM   #32
Keating121
Keating121's Avatar
I've got the 5 lug disc conversion on the front and still have the stock 6 lug axels on the back. Was thinking of switching out internals with a Jegs conversion for 5 lugs, but that wouldn't widen anyting. Was wondering what my stock back space is.
Old 01-02-2014, 01:53 PM   #33
67ChevyRedneck
Best thing would be to remove a rear wheel, use a straight edge up into the wheel well off the face of the drum where the wheel mounts and then measure to the inner bedside to see how much BS there could be. Don't forget to leave wiggle room for suspension travel and tire width (tire's stick out past the rims on the sides!) I was reading that the max BS you should run is around 4.5-5" with the narrower rear ends without using a spacer?
Jesse James
Project "On a Dime"
