Old 01-12-2014, 06:55 PM   #26
vince921
Thumbs up Re: 1950 3100 Full Custom **GunMetal**
alright worked all day and got the framing for the new bedfloor all squared away only a little more welding tomorrow afternoon then sheetmetal ((would have finished but batteries in the ole welding helmet went dead... ))
where the 45' angles are cut in that shape will be cut out and im planning on making a trick little cover to be removable for shows and then reinstalled for when i want to take trash to the dump haha !
hopefully sheet-metal tomorrow evening !
Thanks everyone for the kind words
vince921 is offline   Reply With Quote
Old 01-13-2014, 07:39 PM   #27
vince921
got the first section of the sheet-metal all fit and tacked in .. waiting on another piece to finish the back... curse the bed for being 50 inches... lots of wasted sheet-metal needed 2 4x8 pieces
and this was just to get the look of the shape it will be a little bigger after being cut out obviously but you get the idea ... then ill make a removable center section!!
Old 01-13-2014, 10:37 PM   #28
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Great work so far man!
--Josh
Old 01-14-2014, 08:59 AM   #29
vince921
Thanks man
Old 01-14-2014, 11:19 PM   #30
xpickup
xpickup's Avatar
vince921, looks great. I know what you mean about the bed chewing up sheet metal because of it being 50 inches wide.
Shannon
xpickup is offline   Reply With Quote
Old 01-15-2014, 08:22 AM   #31
vince921
Thanks man ! Yeah it is a bummer having to seam it but shouldn't be to bad ! Picking up another piece today after work ! Hopefully have it all tacked in if all goes well tonight !
Old 01-18-2014, 11:59 AM   #32
vince921
Alright finally got the bed all tacked in ready to go .. truck is already torn back apart... just gotta get some friends to help take the bed and cab off then its time to get the chassis all smoothed out and start putting this thing together one last timee!!!!
Old 01-18-2014, 03:06 PM   #33
oldman3
oldman3's Avatar
Bed looks good, a plan is set, sounds good...Jim
oldman3 is offline   Reply With Quote
Old 01-18-2014, 06:03 PM   #34
vince921
Thank you sir!
got some help today to get the body off!!! tomorrow hopefully have the motor pulled and be ready to get this chassis all cleaned up!! waiting on my accuair setup to arrive so i can get my sensor mounts all made up
Old 01-22-2014, 09:16 AM   #35
vince921
started smoothing out the rough areas ! almost ready for some primer.. unfortunately after removing the motor, the motor mounts where very poorly welded on ... almost as with no gas the porosity was horrible so i spend all of yesterday grinding those welds out and repairing ...
the frame is completely stripped now ... hopefully in primer by the end of the week!!!
Old 01-22-2014, 10:21 AM   #36
youngrodder
youngrodder's Avatar
What size air lines are you running??...they look like garden hose compaired to my 1/4" lines...ha ha
Looking good.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-22-2014, 10:56 AM   #37
99 to Life
99 to Life's Avatar
if the other welds were good and those weren't, why would someone skimp out on motor mounts even with no gas. boggles my mind. coming along nice. yeah looks like some 1/2 line there, could always run smaller valves to slow it down if you need to.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-22-2014, 07:34 PM   #38
vince921
I don't want to by any means disrespect the previous owner by saying the work was horrible .... But the welds on the motor mounts where not the only skimped out part ... All the work on the backhalf maybe would have worked for some but it wasn't great by far ... Which is the main reason I started over completely ... I had to go through a few months and grind out all the welds on the aftermarket front suspension mount ... It hasn't been a walk in the park by any means.... But it's all fixed now! Chassis is in primer !!! Ready for some grey !!!
Old 01-22-2014, 08:27 PM   #39
vince921
Few months Ago**
Old 01-23-2014, 09:16 AM   #40
vince921
Yes it as all 1/2 line just temporary I'll be using all 3/8 with adjusters
Old 01-26-2014, 08:59 PM   #41
vince921
Got the rear end all buttoned up and the chassis is ready for some color !! Maybe tomorrow !
Old 01-28-2014, 05:26 PM   #42
vince921
got the frame all painted came out great !!
Old 01-28-2014, 05:36 PM   #43
youngrodder
Looks great. Is it paint (no powder coat)?
I love the color.
Marc
Old 01-28-2014, 06:30 PM   #44
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Very slick!
ChuckDriver is offline   Reply With Quote
Old 01-28-2014, 06:57 PM   #45
vince921
I love the color.
Marc
Yes its paint i was gonna try and do powder coat but i really wanted this color and plus i have some things i might need to weld so ill have to be doing touch ups in a perfect world i could have had everything purchased and mocked up first.. but we know how that goes.. Im more then happy with the paint
Old 01-28-2014, 08:29 PM   #46
oldman3
oldman3's Avatar
Frame looks great...Jim
Old 01-28-2014, 10:29 PM   #47
STOCKISH
STOCKISH's Avatar
Looks amazing man.
--Josh
Old 01-29-2014, 12:23 PM   #48
xpickup
xpickup's Avatar
vince921, looks great. I like paint over powder coat because you can spot in the color with paint if you have to fix or add something.
Shannon
Old 01-29-2014, 07:44 PM   #49
vince921
Shannon
Thanks man yeah that was a big factor in going with paint i know im gonna have to do some touching up !!
Old 02-05-2014, 10:21 PM   #50
vince921
Alrighty she is well on her way now... got the fuel lines mounted and ran to the front the front brake lines are ran... waiting on as new proportioning valve then will finish the rear... and then only thing left for the chassis work will be the accuair ... which I plan on ordering early next week.!!!!!
The truck will be painted the same color as the rear end !!!!! charcoal grey effect the chassis color is Audi Nimbus Grey
