Old 01-10-2014, 07:13 PM   #26
68Timber
I know the pieces fit
68Timber's Avatar
Re: Replacment seats...........
Originally Posted by motornut View Post
89 burbs in the 78 Jimmy,drilled some holes bolted right up
two arm rests in 89,and a dial tilt(moved to outside)
John I have a set of those for my M1009 I'm going to put in when it warms up a little - thanks for sharing that.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-10-2014, 07:15 PM   #27
I used bench from a 92 Chevy truck
Modified the stock brackets to fit the new seat. You can see the modes in Jr's build thread. I eventually used the seat belts from the newer truck also.
Old 01-10-2014, 07:49 PM   #28
cadillac_al
Do these newer truck seats have springs in them like our old seats? I am worried about losing that extra suspension under my butt like the original seats have. Those 92 era seats seem to be the best fit because they are a slim profile and have headrests. If they have springs in them then I will definitely look for one. Thanks.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 01-10-2014, 08:48 PM   #29
stampy
stampy's Avatar
I have found a few nice seats from early 90s chevs/gmcs in the local wrecking yards. They all seem to have the same problem though, the seat is in decent shape, but the side vinyl is cracked and split. Has anybody ever repaired this?
stampy is offline   Reply With Quote
Old 01-10-2014, 10:16 PM   #30
I am not sure about the springs. It would seem like they have to have some sort of spring, but as the picture shows you can't see any at least not clearly. They feel like they have springs to me.
Old 01-11-2014, 08:38 AM   #31
cadillac_al
Thanks for the pic Palf. I think I have a friend with one of these trucks. I will have to go sit in it.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 01-11-2014, 01:14 PM   #32
nekkidhillbilly
http://67-72chevytrucks.com/vboard/s...d.php?t=559596
looks like they dont kill your leg room and the brackets could be shortend even more than he did. i think the ones from around 99 would do/look even better though.
http://images.gtcarlot.com/pictures/40612672.jpg
and the xl seats look even better but idk if id want one cause of no recline.
http://static.cargurus.com/images/si...397198708.jpeg
another good swap is mid 90s ford trucks the cabs are the same size as squares.
http://images.gtcarlot.com/pictures/58092247.jpg
and lastly 02 up ram seats but your not able to get a rear seat thats gonna fit right in the a crew if your doing a crew. best option would be to mix say a 00 super duty rear with a dodge front and dye them all the same color. or you could get front and rears from a 92-97 superduty crew and just bolt in.
http://images.gtcarlot.com/pictures/39277378.jpg the 03 ram.
all these trucks have the raised floor like a square and the cabs are the same width. in the case of like 88 up chevys the cabs arent as wide usually by about 3 inches and the chevys and 93-01 dodges have flat floor so you have no head room when going to a raised floor. i havent measured a 97 up f150 but they do have the raised floor so if the width equals out they would be a good swap too. same goes for the earlier tundras raised floor but idk about the width. titan has a flat floor along with the 10 up rams.
nekkidhillbilly is offline   Reply With Quote
