Old 08-02-2014, 06:32 PM   #26
uxdesigner
Re: UXDesigner's 1970 5.3 Chevy Swap
Originally Posted by HalfCaseKustoms View Post
What type of fuel tank did you use?
I ended up using the CPP zinc coated tank kit, good quality and fairly simple install. The fit is perfect and I like the tapered bottom of the tank which also includes a return bung so it's perfect for these applications.
uxdesigner is offline   Reply With Quote
Old 08-02-2014, 11:50 PM   #27
mattcrp1
mattcrp1's Avatar
What radiator are/going to run? I just got a griffin for my 76 ls swap. Pretty happy with it,
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 08-03-2014, 02:12 AM   #28
uxdesigner
I'll be running the radiator that came with the truck. I don't believe it's original but it is a reproduction of the original and it's in good shape. I've already plumbed the tranny lines into the radiator as well as the steam port to the extra connector on the radiator. I'll also be running 2 electric fans so I'll see how that works for now before I upgrade.
Old 08-30-2014, 07:28 PM   #29
uxdesigner
Got her out to get some sun on her own power for the first time. (Checking fluids and need to fix a few minor leaks)
New Seats
Rear w/ drop and new tank
Old 08-30-2014, 09:24 PM   #30
Low Elco
Hurray! Under power! Congrats!
Low Elco is offline   Reply With Quote
Old 08-31-2014, 09:53 AM   #31
woodwright
Enjoying left field
woodwright's Avatar
I like those seats. Where are they from?
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 08-31-2014, 11:28 AM   #32
uxdesigner
Thanks!
I got them at the GoodGuys car show, seller had a truck full of sets in many colors. They are brand new take outs (second row) from I believe new honda odyssea vans. Middle console flips up/down and seats are high quality leather that fit very well and are comfortable.
Old 09-03-2014, 03:28 PM   #33
uxdesigner
I've been reading up on the accelerator / gas pedal conversion (Putter - No-Weld Accelerator Conversion) thanks bud! When an idea struck me. Having just bought a new welder I figured no better way to learn than to dive right in.
I wanted to use the stock holes but of course they do not line up. I followed Putter's documentation then realized if weld a washer to the metal plate I can reuse the original plate instead of cutting out a new piece out of scrap metal.
Before: With washer to show idea
After: Welded the washer and a bit of grinding, super strong. I have to say not bad for my first attempt at fabrication.
Old 09-03-2014, 04:07 PM   #34
garmar
garmar's Avatar
Very nice, and you're moving right along!
garmar is offline   Reply With Quote
Old 09-10-2014, 12:37 PM   #35
uxdesigner
Took it around the block, no leaks! Runs strong, wouldn't shift into any gear and then realized transmission fluid was extremely low. Added a couple of quarts and now it shifts as smooth as our Tahoe.
Old 09-10-2014, 01:09 PM   #36
Low Elco
Congrats on the first run around the block!
Old 09-12-2014, 05:53 PM   #37
Roz
Awesome work! I'm going to be following this one!
Roz is offline   Reply With Quote
Old 09-27-2014, 11:28 PM   #38
uxdesigner
Put just enough body panels on the truck along with wiring up the turn signals and brake lights to make the journey across town to get exhaust. Trip was a success, I'm really happy with the results. I had not heard of Xlerator Turbo Mufflers but the shop recommended then when I asked for a simple inexpensive clean exhaust that is quiet and has some sound on acceleration. Went with 2.5 pipe all the way back, mufflers snug in-between the trailing arms with dumps right before the rear end. Install looks clean and extremely high quality welds!
Old 09-27-2014, 11:56 PM   #39
whitels1
whitels1's Avatar
Great work on the truck and the exhaust work looks nice!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 09-29-2014, 01:04 PM   #40
Low Elco
Nice tidy work!
Old 10-03-2014, 09:17 PM   #41
uxdesigner
Nice tidy work!
Thanks guys, it's defintely coming along and the drivability has definitely increased motivation. I'm still debating on whether I should paint it myself or not but having read the paint & body threads lately I'm thinking i may do it myself.
Old 06-02-2015, 10:52 AM   #42
uxdesigner
It's been a long time since an update but wanted to share some pics of the recent progress.
Old 06-02-2015, 04:23 PM   #43
solidaxel
solidaxel's Avatar
I love home paint jobs, and yours looks great!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-02-2015, 04:23 PM   #44
H20cooled
Looks great!
H20cooled is offline   Reply With Quote
Old 06-02-2015, 05:17 PM   #45
uxdesigner
Originally Posted by H20cooled View Post
Looks great!
Thanks! For a first time attempt, I'm surprisingly happy with the results. I couldn't have done it without all the great information I've gathered here from many talented individuals.
Old 06-02-2015, 05:24 PM   #46
uxdesigner
Paint Job Specifications:
Black Epoxy Primer (SPI)
2k Grey Primer (SPI)
Restoration Shop 2508 Viper Blue Pearl (TCP Global)
Custom Shop Premium Ultra-flow Clear (TCP Global)
Graco-Sharpe HVLP FX3000 Paint Spray Gun - 1.4tip (Amazon)
Old 06-07-2015, 06:08 PM   #47
Bugeyev8
Bugeyev8's Avatar
nice work so far !
Bugeyev8 is offline   Reply With Quote
Old 10-27-2015, 04:55 PM   #48
uxdesigner
Recent pics:
Old 03-11-2016, 01:43 PM   #49
Low Elco
Nice Job! I didn't know you'd come this far. Very clean!
Old 03-24-2016, 11:42 PM   #50
uxdesigner
Thanks and congrats on your success also! You guys should be proud!
