Old 08-23-2014, 10:05 PM   #26
ivorton74
ivorton74's Avatar
Re: ebay lsx swap adapters
@lq9..heres the pic for ya...hope it helps
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 08-23-2014, 11:12 PM   #27
solidaxel
solidaxel's Avatar
Now you just have to move the transmission X member to the rear 3"
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-23-2014, 11:15 PM   #28
Blackpony
Blackpony's Avatar
Just seen this thread. I havr been running these brackets for almost 2 years now with 0 issues. They came raw metal so I just hit them with a little rustoleum and good to go. I also use the factory rubber mount and factory clam shell with these. If you set them back one inch it puts the trans in the factory spot. With my th350 and 4l60 the driveshaft went right in with 0 modifications. It literally took only these plates to bolt the ls in using the stock mounts and trans. Also the factory shifter linkage bolted right up to both transmissions. Hope this helps anyone else looking at these out. They made the ls swap a piece of cake.
Blackpony is offline   Reply With Quote
Old 08-24-2014, 12:59 AM   #29
solidaxel
solidaxel's Avatar
What type of fan are you using?
How much clearance do you have on the cylinder head on the passenger side head to firewall?
Did you not move the X member for the trans to the rear?
LS 3 4L70E
Old 08-24-2014, 01:33 AM   #30
IIGW
Originally Posted by Matt Cramer View Post
That arch shaped cutout is a little pointless...
some mounts have a hump and youd need to grind off the hump, so this mount has the middle removed so you dont have to modify the mount. so its not pointless, its actually well thought out.
and if you have access to a welder, for the price of the mounts you can make your own for under 20 bucks.
IIGW is offline   Reply With Quote
Old 08-24-2014, 11:08 AM   #31
littlevictories
i was gonna make my own, but the hour or so to run to the metal yard, and another two to cut and drill them it was easier to work an extra hour or two at work and get them off ebay for $40. plus if they were ****ed i'd have someone to be upset with other than myself.
littlevictories is offline   Reply With Quote
Old 08-24-2014, 11:16 AM   #32
Blackpony
Blackpony's Avatar
Originally Posted by solidaxel View Post
What type of fan are you using? I am using a single fan off a 2012 mustang.
How much clearance do you have on the cylinder head on the passenger side head to firewall?it is pretty tight with the engine setback, but no interference.
Did you not move the X member for the trans to the rear?with the th350 no. With the 4l60 yes that was the only modification required when swapping from the th350.
Answers in red
Old 08-28-2014, 04:53 PM   #33
Lq9'ed 80 Sierra
@ ivorton74, yes it does thanks you. I am having a issue though. my clam shells do not line up with the rubber mounts on cross member. its about an inch past were it needs to be to push bolt through. Also do these clear low mount ac when utilizing the 1 inch set back location ?
Lq9'ed 80 Sierra is offline   Reply With Quote
Old 08-28-2014, 08:57 PM   #34
ivorton74
ivorton74's Avatar
Im not sure about the ac with these mounts...im not running ac on mine
