01-22-2014, 06:06 PM | #26 |
Re: overheating issue
(bought 72 gmc several years ago. had a rebuilt original 307 with like 30 miles on it. has a set of 99 truck heads on it. truck sat for several years with motor covered).... I keep reading this over and over, did you drive this around for a while before you stored it or did you get it and park it for years. if thats the case, are intake gaskets wrong or maybe put on wrong? perhaps blocking the water passage to the top rad hose? just reaching...."remove the t-stat, drain the block, pour water in the top rad hose where its unhooked from the rad. and see if it comes out the bottom of the block,"
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. Last edited by hamjet; 01-22-2014 at 06:22 PM. |
01-22-2014, 08:41 PM | #27 | |
01-23-2014, 02:04 AM | #28 | |
I have a GMPP 350 with Vortec heads like the 99 heads in the OP's 1st post. GMPP told me that I should run a bypass hose from the pump to the intake. The reason they gave is that the old style 350 blocks (not sure of other SBCs) have a coolant passage cast in the block up to and through the right head, but Vortec heads do not have the holes so the coolant flow is blocked and the heads aren't adequately cooled during warm up. I would also think the heated coolant may have difficulty getting to the thermostat to open it. I also have factory A/C with the heater shutoff valve so that may have entered into their recommendation. |
01-23-2014, 04:02 PM | #29 | |
01-23-2014, 04:05 PM | #30 | |
01-23-2014, 04:20 PM | #31 |
Sorry to respond to a question to someone else, but since he's not online... I'd assume that's what he meant. Drain plugs on both sides.
01-23-2014, 04:48 PM | #32 |
I just got on, no, I meant take the bottom radiator hose off and see by pouring water in where the thermostat goes and see if water comes out the bottom radiator hose. it should flow all the way to the bottom, comming out the water pump...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
01-25-2014, 03:32 PM | #33 |
Hi rich67, did you find out anything yet?????
01-25-2014, 07:29 PM | #34 |
Just out of curiosity when you removed the serpentine system, what kind of pulley was on the water pump?
If it was smooth pulley that might just mean it receives the back of the belt and rotates the opposite direction of the crank shaft rotation. This would explain the failure to circulate zero coolant. The water pump look right, and be right for a serpentine system but not standard V-belts. The vanes of the water pump would be manufactured accordingly to circulate water for its respective system. Just my .02 cents. 88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!! My Build Thread: Project 72' Green http://67-72chevytrucks.com/vboard/s...d.php?t=587932 |
01-25-2014, 07:53 PM | #35 |
i am curious to know if you have made any progress on this issue. pretty solid thinking from the previous posters.
'69 c10 longbed granny 4spd 292 "Behemoth" '67 c10 longbed granny 4spd 292 "Burzum" some pictures of my work in progresshttp://photobucket.com/zaeea R.I.P. Corey "Flattus Maximus" Smoot 11/3/11 You will be missed. Your sound lives on. |
01-25-2014, 09:04 PM | #36 |
Unless i missed it i didn't read (speed reading maybe?) anywhere where you replaced the water pump with the correct rotation water pump, a serpentine setup uses a reverse rotation impeller inside the same housing, it will not allow the water to flow properly if you are now running V-Belts.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-02-2014, 08:12 AM | #37 |
any new updates, I also have a vortec top end set up and i do not have a bypass hose , i drilled a couple of small 1/16 holes in my thermostat to allow air to escape and water to flow
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
02-02-2014, 04:36 PM | #38 |
I've got a 190* thermostat as well. When I warm it up the temp climbs all the way to the mark just below the red and then drops to normal operating temp (takes about 20 seconds to drop). It's been like that since I got the truck over a year ago. Have you tried seeing if that happens, or does the temp just stay up?
02-02-2014, 05:09 PM | #39 |
If your coolant is still cold and the temp gauge is peaking, your gauge or sender or both are not working right.
Cooling systems are pretty simple. If pump, radiator, cap, and hoses are good, and you said you tested the t-stat, it has to be right. Let the motor idle with cap off, when motor warms the coolant enough, the t-stat will open, and the coolant level in the rad will fall. Re-fill the radiator and install cap. If both hoses get warm, its good. I suspect faulty gauge and/or sender.
F/S: 1972 C30 Stakebed parts truck F/S: 1967 C10 lwb stepside very rough 1978 C10 Longbed |
02-02-2014, 06:46 PM | #40 |
laying low
If I recall right a temp gauge uses a different sending unit than a temp light. That truck may have had a factory temp light originally and someone replaced it with a temp gauge setup. You have no way of knowing if it has the correct sending unit in it now.
Ditto on the water pump. A reverse flow pump looks just like a forward flow pump. The vanes inside are reversed however. If you removed the upper rad hose at the rad and start it up water should push out of the open end of the hose when the thermostat opens. That's the normal direction of coolant flow on these trucks. If you have a 4 row radiator you won't notice as much coolant flow into the radiator due to the extra thickness of the radiator tanks.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
02-04-2014, 05:29 AM | #41 |
im sorry folks ive been away from my puter for awhile.lol i just all the posts tho and was dam good reading. heres an update. first of all the serpentine pulley was smooth by the way. i replaced with new short snout factory correct water pump. i ran bypass hose and still the same. oh and mine doesnt stop climbing(heat guage) until i shut truck off. so i got disgusted and tore motor down. driver side head around number 7 cylinder was full of looked like large paint chips. had almost formed a cacoon lookin deal. so new gaskets and heads back on. intake sometime today. im guessin stuff came out of rad when it heated up. only flushed with water first time. but been cleaned with acid now. rad was used and i have a 3 core back in it now. cleaned and tried a four core to try to solve issue but it was used and leaked so back to the 3 core that doesnt. hope i responded to all posts. thanx everybody for yor knowledge! i appreciate it, rich
05-01-2014, 11:07 AM | #42 |
Just a car guy
Did you get it back together?
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
05-01-2014, 01:25 PM | #43 |
