#26 |
Re: Project Phantom - 72 GMC body on NBS chassis.
If it were me I would put everything from th 01 to the older truck but I like the challenges. I don't think you should have to do a lot of body chopping but you will have to create your new mounting positions. The gas tank I would probly try and see if they sale any aftermarket kits and see if there is any special brackets you can fab or order from them that would help again that's all about fab. Same with the dash. What I woul do is disassemble everything and lay it all out where I want it to go and than start figuring out mounting positions that best suit than worry about cosmetic touches that would make seem like it was supposed to be there in the first place. But the real challenge is starting the project just be ready for a little commitment becouse it sounds like you want to make a real sweet truck
#27 | |
I am probably just going to keep the 87 frame w/ the solid axle front, may end up bobbing the bed eventually. After the ls swap is done I am going to a 4" lift with max of like 33" tall tire. Just mostly for looks. This truck has great sentimental value to me and I will never get rid of it. |
#28 |
Sweet i won't get rid of mine either my family is are the origanal owners so there is also a lot sentiment behind mine as well. I'm trying to do as much up date as possible but I will also keep the body look the same just modern internals and frame
#29 | |
Currently I am going to clean and modify all drivetrain related stuff on the 01 chassis b/c I can still crank it up and drive it around. Then when I have everything ready and my ducks in a row, Imma take out my 350tbi/700r4 combo (with only like 8k miles on it) and sell it and get it done! I havn't been this excited in a while! |
#30 |
#31 |
My Spoon Is Too Big
I have running driving 72 c20 and 00 silverado. Ultimately I want the vortec powering the 72. should i do body swap like this with the 00 frame drive train and suspension. or should i motor swap and have the 72 frame and components? which one is easier,
*note using hand tools in my garage no lift/welder/plasma/compressor/knowledge or anything that would make this simple.
1972 C20, 03-14-10 Build Thread 2000 Silverado 4.8L, 11-04-13 (Currently Parting) 1999 Silverado 5.3L, 07-07-14. (Engine Donor) 2015 Ram 05-20-15 (Daily Driver) |
#32 |
#33 |
![]() Almost all the needed suspension is back on.. Need to drill out my spindles to accept the 5/8 bolt for the tie rod, yes those are zip ties lol they will suffice for mock up purposes! |
#34 |
Here are a couple more pics of the donor truck! If anyone is interested in a complete 3/4 ton chassis let me know, located in edmonton alberta!
#35 |
Well that escalated quickly lol. This will be close to ride height in terms of where the suspension is sitting.Look at the upper ball joint and tie rod angles... What an improvement!!
#36 |
Got the box completely removed and hauled away today. Same folks are coming back next weekend with a crane truck to snatch up the cab!
#37 |
Hey guys where is all my encouragement? haha
#38 |
if you make this work im doing it i have a 04 that i would love to put under my 69
#39 |
![]() ![]() Don't give up!! I think it is awesome what you're doing!! |
#40 |
Got the old beast running today and drove it home for the swap to start, well, had to stop at the carwash first of course haha. Enjoy. 350/4 speed
http://youtu.be/UuS9aDjq3VE |
#41 |
Boy am I frustrated!
After countless attempts to remove this cab in one piece, I finally got fed up and just went full retard. I can't really say I ever pictured taking a sawzall to my once beloved truck.... but times change I suppose.... ![]() Now were making progress!! ![]() Frame out.... ![]() ![]() Got the cab sitting on the back of the 72 frame, now to unbolt the cab, remove, and call the wrecker for the 72 chassis and cut up cab!! ![]() |
#42 |
Everyone knows you never supposed to go full retard... But if it works...
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
#43 |
It worked alright
#44 |
#45 |
#46 |
So sexy
![]() ![]() Friend of mine came and grabbed my 72 chassis last night, so no more garbage! Hes putting a 53 body on it.... Glad it's gonna be recycled instead of sent to the scrap yard! It's now sitting in st paul ![]() Cut the fender a bit today to see how much wiggle room I have with suspension travel. With the frame lift and new lower control arms it's going to sit about 3" lower then this, so might have to cut a bit more. Step by step! ![]() |
#47 |
That's awesome. I saw your posts on Facebook, I just had to come check it out!
My 68 Stepper build |
#48 |
Cut the other fender out and cleaned up most of the crap off the firewall.... Just dicking around until I can find a welder to make cab mounts and stuff...
Gotta say though this is looking pretty awesome! ![]() |
#49 |
A320 Pilot/USAF Retired
Cool project!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#50 |
How much was/is it lowered and how? Spindles and springs and a flip kit?
