#26 |
![]() Join Date: Aug 2008
Re: Optimal Tire Diameter
Another "BTW", if it was a 69 Z28 engine, it would have been a DZ code 302, making the engine alone worth several times more than the truck itself! A 79 Z28 engine (350) on the other hand is nothing special, but a good foundation if in decent shape.
#27 | |
![]() Join Date: Oct 2013
![]() Do you have any more pics of that beauty? Since I am keeping my truck stock height, I am leaning towards a 255/70/15 or 255/75/15. |
#28 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Sure, PM me your email address and I'll send some to you. I dont want to change the theme of this thread.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#29 |
I have decided that I will be running 255/70/15 on my truck.
I have a 68 shortbed stepside, and am wondering if the offset on 15x8 blazer rims will require a spacer or not? Thanks! |
#30 |
^^ I too am wondering this im planning on running 4x4 rallys
#31 |
I have a set of 15 x 8 6 hole rallies that were on a 68 swb 4 x 2 with no issues. I also had 15 x 8 5 hole rallies with P255/70 15 tires on my 72 lwb on all 4 corners with no issues and they fill out the wheel well very nicely. I am a fan of 4 tires and rims the same size on our trucks.
#32 | |
![]() Join Date: Feb 2015
I have a 69 with 4.11 and I could use more top end. Have been thinking about a 700R4. Will you be using the column shift or floor type? |
#33 |
The only reason I started worrying was because someone told me that the offset could cause the tires to rub omyob the inner wells on my stepside rear fenders. Thanks for the replies thus far.
