Old 01-24-2014, 12:48 AM   #26
LS-K
Re: '87 tank/fuel pump supplier
Originally Posted by ls1nova71 View Post
You will need the Corvette filter/regulator. That rail you have is returnless, there is no regulator on it, that thing that looks like a regulator is a pulse damper, does nothing to regulate pressure.
LS1Nova, since its a returnless system, what do I do with the return fitting or portion of the corvette filter/regulator?
LS-K is offline   Reply With Quote
Old 01-24-2014, 01:13 AM   #27
ls1nova71
ls1nova71's Avatar
You run the return line back to the tank.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-24-2014, 02:30 AM   #28
Andy4639
Old member
Andy4639's Avatar
Wink Re: '87 tank/fuel pump supplier
There you go!
This brings up another question then? What did the factory vehicle use and why aren't they being used? Sorry that's 2 questions!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-24-2014, 03:10 AM   #29
ls1nova71
ls1nova71's Avatar
Originally Posted by Andy4639 View Post
There you go!
The factory regulator was built into the fuel pump/sender assembly. You can use them, but it requires fuel tank mods that are past a lot of peoples abilities and/or desires since the corvette filterwith the regulator built in is so easy to use. Price probably adds into the equation too as fuel pump modules are not the cheapest.
Old 01-24-2014, 03:19 AM   #30
LS-K
LS1Nova,
Is there anything out there that regulates while in-tank or in the sending unit/assembly that is a direct fit?
Old 01-24-2014, 08:23 AM   #31
ls1nova71
ls1nova71's Avatar
LS1Nova,
For an '87 tank? Unfortunatly, no. The newer senders take a completely different type of lock ring and are bigger. I would just use the '87 tank and sender, get a Walbro255 pump or something similar and use the Vette filter.
Old 01-24-2014, 09:01 AM   #32
jamesjones
Freakin Awesome!
jamesjones's Avatar
Originally Posted by Classic-Steele View Post
I used an 87 blazer tank and sending unit, but but just reworKed some of the wiring and ran am Aeromotive 340 pump. It dropped in, and should work like factory except with the ability to support 800 HP.
Do you have the part number for that 87 Blazer tank? Or have the dimensions?
I'm trying to find a tank for my 72 Blazer.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 01-24-2014, 09:03 AM   #33
dec010974
dec010974's Avatar
ls1nova71, you very well at answering question. im still waiting on that blazer build thread mr. ls1nova71. also, i know the weather has been bad all across the united states, so for now you can play with your freeze pops. but when spring hits, let the thread begin.
dec010974 is offline   Reply With Quote
Old 01-26-2014, 03:56 PM   #34
LS-K
James Jones,
I was taking a closer look at your 87 sending unit. Did make those fittings on top? For feed and return?
Old 01-26-2014, 05:52 PM   #35
jamesjones
Freakin Awesome!
jamesjones's Avatar
James Jones,
It's not mine, it's Classic Steel's. It looks like the stock sending unit though.
Old 01-26-2014, 08:02 PM   #36
LS-K
Oh damn my fault. I was wondering how he got those fitting on it. I think mine will only have the slip on type. The one you use with good ole stainless clamps. Will I have to cut them, slip on a fitting and then use a flaring tool?
Old 01-27-2014, 12:39 PM   #37
Classic-Steele
Classic-Steele's Avatar
The tank is a Spectra GM15C and the sending unit is a FG12K. This is the setup for the 25 gallon tank. It is 1" shallower then the 31 gal. The sending unit is unmodified, with the exception of some upgraded wiring necessary to run the bugger pump.
Classic-Steele is offline   Reply With Quote
Old 01-27-2014, 06:09 PM   #38
jamesjones
Freakin Awesome!
jamesjones's Avatar
Awesome, thanks man. You might have just solved the fuel dilemma on my 72 Blazer LQ4 swap.
Old 01-27-2014, 06:58 PM   #39
Classic-Steele
No problem! Hopefully I can add a small contribution to wealth of knowledge on this board.
Old 01-31-2014, 03:12 AM   #40
LS-K
Boy do I need help!! This is a head scratcher for someone with my skill, or lack thereof. I finally got the 87 sending unit, tank, etc.... I hope someone can help.
So my understanding is that LSx engines use high pressure fuel systems(58psi), so what do I do with the sending unit's feed/return/evap lines? I mean it looks like it only takes the good ol' slip fitting that use the traditional hose clamps, isnt this NOT HIGH PRESSURE COMPATIBLE? wont they burst right off at the first moment the pump turns on?
All your help is very appreciated, hell if you guys lived in Tucson, I'd buy you guys a round of cold beverages.
Old 01-31-2014, 03:38 AM   #41
ls1nova71
ls1nova71's Avatar
87's were fuel injected, but it was throttle body injection which only runs at around 17-20 psi that's why they were just clamped. The barb on the end of the line will keep the hose on under pressure provided you use fuel injection hose and fuel injection clamps, I like to put two clamps on them with the screw parts opposite of each other. Many have been done this way, a couple of my cars included. If you don't feel comfortable with it you could braze on AN fittings, or if you're good with a flaring tool, you could cut the barb off the end and double flare it.You also could use nylon line with compression fittings as long as you can find the right fittings. Keep in mind you will need some kind of flexible hose, rubber, steel braided, nylon ect. so you can drop the tank if the need ever arises. If you hard line it to the frame, you won't be able to move it and trying to drop the tank will probably damage the lines going into the sender.
Old 01-31-2014, 04:04 AM   #42
LS-K
LS1NOVA,
I have already bought about 20ft of stainless braided TEFLON line with a bunch of hose ends for that stainless line. would the FI clamps work with the stainless line?
Double Flaring seems to be a safer bet, but I dont think I have enough line coming out of the sending unit to work with, unless you believe its enought to double flare. Also, will those double flare fittings directly bolt on to the stainless hose ends?
Old 01-31-2014, 08:55 AM   #43
solidaxel
solidaxel's Avatar
I used some 37* steel fittings, but I had to enlarge the ID to fit the sending unit pipe, then I silver soldered them to the sending unit.
I found the fittings over at the Parker Store in the area of Ajo and Palo Verde.
He also has the female fitting,s BUT after you get the lines to the right length he will need to crimp them. Done Deal !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-31-2014, 10:26 AM   #44
ls1nova71
ls1nova71's Avatar
LS1NOVA,
I wouldn't try to clamp that kind of hose. You will need some kind of fittings to adapt the hose.
Old 01-31-2014, 10:46 AM   #45
truckdude239
truckdude239's Avatar
i cut the ends off my sender and used compression fittings to -6 an on the sender havent leaked yet
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-31-2014, 03:18 PM   #46
aggie91
I'm just glad to be here!
aggie91's Avatar
X2 here...Cut the bead off the end of the tube, use a Parker or Swagelock compression fitting to male AN adapter for the give OD of the steel line coming off the sending unit. The supply tube should be 3/8" od and the return should be 5/16" od.
3/8" Tube: Swagelock fitting:
http://www.swagelok.com/search/find_...7-a5d3fd3672c3
5/16" Tube: Swagelock takes 2 fittings:
http://www.swagelok.com/search/find_...7-a5d3fd3672c3'
And:
http://www.swagelok.com/search/find_...t=SS-600-6-6AN
Hope this helps you find what you need. If you have a Parker Store, they can get you what you need too.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-31-2014, 03:30 PM   #47
Classic-Steele
What brand of sending unit is that? My spectra one had metric o ring fittings on it. The barbed style of this one makes me wonder if its a carbureted one...?
Old 01-31-2014, 03:34 PM   #48
LS-K
I got this from classic parts #23-546 "gas tank sending unit W/FI, 87-91" is what it reads on the box.
Old 02-06-2014, 04:27 AM   #49
jamesjones
Freakin Awesome!
jamesjones's Avatar
Can you tell me what size the fittings are on the sender? I want to order the connections from Summit.
Old 02-06-2014, 04:26 PM   #50
Classic-Steele
I believe its M16x1.5 but I'll double check
