Old 01-25-2014, 03:49 AM   #26
litew8
litew8's Avatar
Re: Let's see those Original Chevy/GMC truck grilles you restored
Originally Posted by 72 Copper C-10 View Post
I think i can still find some of that stuff or close to it, but not in stores (obviously!)
I cant wait to see more! everyone's grilles look awesome, I cant wait to do mine!!
I'd be interested to know what it's called, if it polishes/protects? bare aluminum.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 01-25-2014, 11:09 AM   #27
Lou Boffa
Lou Boffa's Avatar
Guys, I read where the final polishing on several were done with Mother's and a ball. Can someone explain? Thanks
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 01-25-2014, 11:51 AM   #28
DT1
DT1's Avatar
I did mine three years ago when I painted the truck. I had a choice between Repro replacement grill and moldings or get to work on my original stuff. I've showed these pictures before, but since the topic has come up again...
Before
Stripping
After dent removal
Ready to go back on
Did the same with the moldings
DT1 is offline   Reply With Quote
Old 01-25-2014, 02:00 PM   #29
tommys72
tommys72's Avatar
DT1 I need some more info on the process you used for the trim and the grill as I want to do mine also. ..and hope they come out that good
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 01-25-2014, 03:49 PM   #30
sduckworth13
sduckworth13's Avatar
Here is a grille restore thread that DT1 started when he refinished his grille.
http://67-72chevytrucks.com/vboard/s...d.php?t=445625
Scott
sduckworth13 is offline   Reply With Quote
Old 01-25-2014, 04:15 PM   #31
DT1
DT1's Avatar
Ok, From what I remember...
First thing is to clean and strip the anodizing off. Forget about the oven cleaners and Greased Lightning. I use pure sodium hydroxide (Lye). It will take anodizing off better than anything I have ever used but you need to be EXTREMELY CAREFUL! This stuff is bad news! If you get any on your skin. If you get a shot of it in your eyes, it can blind you. Protective clothing and eye wear are an ABSOLUTE must.
You can get sodium hydroxide powder by the pound from ebay.
Fill a plastic spray bottle with a solution of one part lye to 20 parts cold water. This stuff will react with the water and become very warm. NEVER shake the bottle after mixing as it can explode.
Spray the clean aluminum grill with the solution and let it set for a few minutes. Test an area by scouring with Scotch-Brite. You might have to repeat this until the anodizing starts to dissolve. Scour the entire grill until it is free of the anodizing and rinse with water until all residue is gone.
The bare grill is now ready for dent removal. My grill didn't have any real bad dents but it had a bunch of dings all over it. I used a couple of pillow cases filled with sand for a backing while I methodically worked the dings and imperfections out from the inside with a screen door roller (Amazon). I gently rolled them out until they were just slightly raised and then tapped them down as flush as possible. I used a Rockwell Soni-Crafter, sander to work the areas smooth using finer and finer sand paper until the imperfections were completely gone.
Now is where a lot of buffing comes to play. I converted a regular bench grinder into a buffer and mounted it to a free standing base.
For the preliminary cutting I used 3M Scotch-Brite (Red) pads cut into 6 inch disks and stacked 4 of them together on the buffer. These disks will blend the entire grill to a semi flat finish and show any imperfections that need to be reworked. The next step was to fit the buffer with a 6 inch denim disk and used with black cutting compound. The next hour or two was spent methodically buffing every inch until the grill gleamed. Next I fit the buffer with a medium cotton disk and repeated the buffing with jewelers rouge.
The entire grill was then wiped down with a lint free cloth and lacquer thinner and at that point ready for finish. I have re-anodized some aluminum but it's not easy to find someone that can do a job the size of the grill. This particular grill got clear coated instead.
I used DuPont automotive clear coat. I applied a very light coat of clear coat and allowed to completely dry, then wet sanded with 1000 grit.
I masked off the area to be painted black and applied SEM Trim Black paint.
After the black was dry I applied two more coats of clear coat over the entire grill. After completely dry (A few days) I hand buffed. That's about it.
At first I was skeptical about how the grill would hold up during normal driving and just plain ol wear and tear, but after a few years, it still looks like new. Hope this helps. If you need information about where I obtained any of the stuff I used, shoot me a PM.
Old 01-25-2014, 04:17 PM   #32
DT1
DT1's Avatar
Pretty dumb of me. I should have done what you did!
Old 01-25-2014, 04:22 PM   #33
Lou Boffa
Lou Boffa's Avatar
Thanks DT1. Thats what I'll do.
Old 01-25-2014, 04:32 PM   #34
tommys72
tommys72's Avatar
Thank you! I will also be using this
Old 01-25-2014, 05:54 PM   #35
88fordf150
88fordf150's Avatar
Before, during & after. Used oven cleaner, polish, paint, decals & lenses.
Brad handshoe
88fordf150 is offline   Reply With Quote
Old 01-25-2014, 07:27 PM   #36
sduckworth13
I appreciate you taking the time to list all your steps, it will be be great info for guys looking for inspiration pictures and a list of steps for real world results.
Brad the grille looks great, where did you get you grille decals at ?
Scott
Old 01-25-2014, 07:30 PM   #37
tommys72
tommys72's Avatar
These look great! Makes me want to start mine right now
Old 01-25-2014, 07:43 PM   #38
88fordf150
88fordf150's Avatar
I think LMC but I can't remember for sure.
Brad handshoe
Old 01-25-2014, 07:49 PM   #39
sduckworth13
Thank you
Scott
Old 01-26-2014, 12:24 AM   #40
72 Copper C-10
72 Copper C-10's Avatar
its basically an acid, i will have to look at the bottle but is real close to alluma-bright.
Awesome work on your grille! Where did you get the decals for your trim, I would like to buy some but I dont know where to look!
Thanks,
John
72 Copper C-10 is offline   Reply With Quote
Old 01-26-2014, 12:31 AM   #41
sduckworth13
I found the decals for the 1969-1970 Chevy Truck Grille. There are several places that carry them. Here is one link.
http://www.tuckersparts.com/Grill-Decals-F-6896.html
Scott
Old 01-26-2014, 12:55 AM   #42
72 Copper C-10
I should have explained my self better! i meant the decals for the wood grain trim. sorry for the confusion and thanks for looking for me sduckworth!
Old 01-26-2014, 01:01 AM   #43
sduckworth13
Your welcome
Scott
Old 01-26-2014, 03:42 PM   #44
7d1truckguy
7d1truckguy's Avatar
Hello, since we are talking about grills, I have a 1971 gmc and I was wondering what if any is there any safe way to remove the coating on those grills, THANKS
7d1truckguy is offline   Reply With Quote
Old 01-26-2014, 03:49 PM   #45
sduckworth13
Here is what DT1 posted in his thread
Spray the clean aluminum grill with the solution and let it set for a few minutes. Test an area by scouring with Scotch-Brite. You might have to repeat this until the anodizing starts to dissolve. Scour the entire grill until it is free of the anodizing and rinse with water until all residue is gone."
Scott
Old 01-26-2014, 06:18 PM   #46
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Subscribed, I'll be trying this soon.
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 01-27-2014, 03:13 AM   #47
litew8
litew8's Avatar
Lye is the key ingredient (removing factory anodize - the protective coating on OEM aluminum). Many oven cleaner products contain lye. It can be found cheap (dollar general etc...), just read the label. No need to mix, just shoot and wait a few (no more than 15 min I think?). Use all/every safety precaution (eyes,skin,paint,ventilation etc..) seriously. I found I could sand most of my minor dings out. Careful, it's thin aluminum and you can burn through it with too much sanding.
Old 01-27-2014, 09:22 AM   #48
DT1
DT1's Avatar
I got the wood grain decals from LMC. To my surprise, they seem like good quality. If you decide to do the tail gate, make sure you inspect the decal for length. I had to return my tailgate decal twice because both times it was over an inch too short. Hard to understand. Why not make them an inch longer then they need to be? I guess the extra length would cost them .05 cents more and that can add up.
Old 01-27-2014, 09:32 AM   #49
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
GMC grills are mild steel, not aluminum like Chevys. They are chromed, not anodized.
It looks like you have a nice original grill. Keep it and get it rechromed when you can afford it. It wont be cheap, but it will be worth it. It will fit SO much better than a repop, You can so trust me on that.
Tom Vogel is offline   Reply With Quote
Old 01-27-2014, 10:07 AM   #50
72 Sierra
How do you prep the chrome to be painted the black parts on a gmc grill. thanks
72 Sierra is offline   Reply With Quote
