#26 |
Re: Jim's 1966 SW BBG
Not at the moment on the 5 lug rear. Wanting to put original hub caps and steel wheels. Original 1966 6 lug wheels won't fit front 6 lug disc so I ordered 5 on 5 to use 70s wheels on front.
#27 |
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
#28 |
Here's a little Heads up for you…
Been watching your build, will continue, I like where you are going... ![]() Anyway, Clemdaddy is over in Fayetteville Arkansas and has a get-together the third weekend in October… I was able to attend this past October and had a great time talking trucks, and meeting a few of the members that made the trek to NW Arkansas. ![]() Not to mention getting to see Clem's little slice of American Automotive Heaven. ![]() Was great to meet two of the Oklahoma Guys… Chad64Chevy and his family - His Build thread.. http://67-72chevytrucks.com/vboard/s...d.php?t=456163 Chad is also in the process of moving somewhere up near Tulsa... Sigshooter AKA Robert - His Build thread… http://67-72chevytrucks.com/vboard/s...d.php?t=500968 Here's a link to the thread that has the Pics… http://67-72chevytrucks.com/vboard/s...30#post6324330 Have a Blessed Day out there in Chevy Truckland... ![]()
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#29 |
Got the new CCP drop spindles and disc brakes on today. Everything fit great.
#30 |
Looks great. Been watchin.
Subscribed. |
#31 |
Fancy!
Tim ![]() |
#32 | |
I used 73 4x 1/2 ton disc 6 lug wheels up front and out back. Accepts stock caps and a few others. I think they were most bcommon from 71 to 77
GOD BLESS AMERICA! |
#33 |
Nice!!!
#34 |
JIM, LOOKING GOOD, BE SURE TO GO TO THE SALVAGE AND GET A FRONT SWAY BAR, THEY ARE CHEAP AND HELP THE HANDLING A LOT. I USED ONE FROM A SUBURBAN........REMEMBER I DO HAVE SOME 5 X 5 RALLYS OVER AT THE SHOP (A BIG SELECTION OF WIDTHS) KIETH
YOU NEVER CAME AND PICKED UP THAT STEERING BOX, GUESS I WILL GIVE IT TO SOMEONE ELSE.......... ![]() |
#35 | |
I need to hit you up to lol
[/B][/B] Quote:
Tim ![]() |
#36 |
Got my new CPP master cylinder and booster on. Drilled 2 holes and bolted right up to fire wall and pedal. Got new tires on steel wheels also found a nice set of original hub caps. Can't decide on color on wheels white, black or maybe red. Drop spindles dropped just what I wanted in front.
#37 |
The later model 4x4 6 lugs steelies will work w/disk brakes and accept stock hub caps....I see you 've already gone to 5 lugs though. Nice work.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#38 |
Last week put in new gas tank, seat belts, brake lines, widow channel , transmission cooler and lines , hooked up wiring and started motor today good to hear it start. Still have many little things to finish. Hopefully test drive in the next few weeks.
#39 |
nice work you taring this thing up . it will be on the road in no time
efi 496bbc th350 custom brakes narrowed 9 coilover rear. |
#40 |
Been a few weeks since doing much. But got after it yesterday. Bleed brakes fixed line leaks, put bed back on, topped off fluids, fixed lights added custom milk crate seat ( seat is in upholstery shop) . Started and drove up and down street for the first time. Exciting!!! Another 66 back on the road after many years.
#41 |
Nice job....can't beat those 1st shake down runs after the trucks been sitting a long time.
#42 |
Picked up some parts at local swap meet. Polished up and installed aluminum grill, factory radio, rear chrome bumper and some of the side trim.
#43 |
Nice score on the swap meet parts!
![]() Are you making the show in Tahlequah Saturday???
#44 |
Ended up changing flywheel after having starter noise problems. Changed out door to Sinclair. Drove on highway first time with less than 10 miles on truck it quit running . New distributor went out. Another ride on the wrecker. Dropped in old HEI and running again.
#45 |
Truck is looking good Jim! Bummer on the distributor. Was that a Skip White/Chinese ebay one?
