#26 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Daily Drivers
This is what I drive back and forth to work (80 miles round trip). It's an old long bed that I shortened and threw together with junk out of all my friend's scrap piles. 350/350/3.08. Gets the best mileage of any old truck I've ever built. I think its the skinny tires. I usually always run fat tires on my junk. It's sitting outside my shop in this picture getting a master cylinder so I can drive it to work in the morning.
#27 | |
![]() Join Date: Mar 2013
Re: Daily Drivers
#28 | |
Re: Daily Drivers
Rear is flipped with a homemade setup. I bought weld on axle saddles for 13 dollars from a Summit and did it myself. Rear shocks are Belltech. Rear tires are 235/75-15 on stock 6 inch wheels. It's not perfect, but I did it to prove how cheaply I could throw a truck together. There's about 900 dollars sitting there. The drop spindles, new gas tank and sendings unit, new brakes and ball joints ate up a lot of that. All the important stuff is new. Every seal, every hose, every brake part from front to back is brand new. All suspension is new or tight.
#29 |
![]() Join Date: Jun 2010
Re: Daily Drivers
Do I need to send you a check for $900 for the truck.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
#30 | |
Re: Daily Drivers
I like trucks with character and yours has it. |
#31 |
Re: Daily Drivers
I probably overstated the costs a bit. It was 900 when I first got it on the road. Since then I've put a new carburetor and battery on it. Plus some little nick nacks like tailgate chains, a saddle blanket seat cover, battery cables, door and window rubbers, and now a master cylinder. Probably 1500 now.
#32 |
Re: Daily Drivers
