#26 |
Re: SB 2wd exhaust manifolds
Yeah Tom thanks. If you have some done can you post up a pic or two?
#27 |
"Junkyard Dog"
![]() Join Date: Jan 2008
Do you plan to use a heat riser? A manifold for a heat riser will have a flat flange for a gasket on the outlet.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
#28 |
#29 |
Tom, I don't have a problem with the smog ports. I will not be running a heat riser either. What will the cost be sending them to 22435 in VA? Thanks.......Roland
#30 | |
"Junkyard Dog"
Ok, I'll get a pair done up and post some pics. Quite busy right now (redoing the deck for the wife) so it would be next week before I have them done. If this time frame doesn't work please let me know.
Thanks, Tom
#31 |
Do you have a set with a.i.r. ports for 67-68 2wd. I need the alternator mounting on the driver side. Would perfer not to use a heat riser but i have one if i need it. Rod.
#32 |
That works for me Tom, thanks.
#33 |
OK Tom, $160 sounds good to me. Let me know when they are ready and I will get the payment to you. Thanks........Roland
#34 | |
"Junkyard Dog"
Ok thanks. Ok Thanks
#35 |
By right hand you mean passender side? I have located a driver side si if it is pass side will you sell a single? Rod.
#36 |
![]() Join Date: Apr 2013
May have to get with you very soon for a 2wd set for a 72. They look amazing, gotta get rid of my long tube headers. trucks too low and headers are lowest part of my truck.. it hates speed bumps.
![]() Evaded
If I see a Zombie.. Im runnin it over with my Truck. |
#37 |
![]() Join Date: Mar 2014
I hope it's ok to add some info to your thread. I have coated three sets of manifolds with the Eastwood hi temp powder with excellent results. Two were used during the engine brake-in with no problems. I used the stainless steel color, looks only slightly brighter than the top manifold in the first post.
http://67-72chevytrucks.com/vboard/s...d.php?t=620707 |
#38 |
Tom, just checking in on the 4x4 exhaust manifolds. Thanks.
#39 |
"Junkyard Dog"
pics of a pair of 2wd for OLEBEATER. This a very nice pair.
Dirt's72, I just did a bunch 4x4 manifolds. I just need to media blast them which I will do next week. Sorry for the delay. Thanks, Tom
#40 |
They look great, PM me with payment info. Thanks, Roland
#41 |
Ok, just checking. Thank you
#42 |
"Junkyard Dog"
Dirt's72, I have a nice pair done up for you. I'll post pics Monday night.
Thanks, Tom
#43 |
Cool, thanks
#44 |
[QUOTE=tll74;6697736]Rod, I have the RH but not the 67-68 only LH. My LH 67-68's do not have the A.I.R ports.
Do you still have this manifold with A.I.R. ports? |
#45 |
"Junkyard Dog"
[quote=chewychevy67;6747295]Rod, I believe so. I'll look for you today. I have 7 RH's still on trucks. I haven't sold one so I should still have it. Thanks, Tom
#46 |
any luck finding a good manifold? Rod.
#47 |
"Junkyard Dog"
Rod, I have this one with plugged A.I.R. ports. It does have what I call heat checked in the center. Will this work for you?
Dirt's72, I have a very nice pair done up finally. I'll post pics Tuesday. Thanks, Tom
#48 |
No cracks or spider cracks? Any chance I could get you to remove the a.i.r. plugs. Just want to be sure the threads are good. Last one I just bought off ebay they were badly stripped out. Rod.
#49 |
Also how much to ship it to S0K2T0 in SK, Canada?
#50 |
"Junkyard Dog"
chewychevy67, This one is heat checked in the center as many commonly are. It is not cracked. I could remove the the plugs if needed. But it would be next week. I'll try to have my helper get the shipping cost.
Dirt's72, Here are the pics of the manifolds. I have removed the plugs and the threads as well as plugs are fine. This is a matched pair and will work with or without a heat riser. They both have the bevel for the donut gasket. I also removed the old studs and the treads are fine. Guys, I'm gone Wednesday on a vacation trip to San Francisco with the family be back early next week. Thanks, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw Last edited by tll74; 07-09-2014 at 12:43 AM. |
