Old 02-03-2014, 09:25 PM   #26
tinydb84
tinydb84's Avatar
Re: Installed airbags and still dont set low enough.
Originally Posted by Bearcamp View Post
Would I get another 1 1/2 inches if I just cut the cup from 3 to 1 1/2?
Possibly. Just make sure you aren't rubbing the bag on anything once you do.
David
Instagram: myfabguy
Old 02-04-2014, 10:12 AM   #27
ob1monkey
Talking Re: Installed airbags and still dont set low enough.
I run drop spindles with plates on top and cut cups on bottom(flush with lower arm) 245/45/17 tire 25.7 diameter. cross member hits the floor when aired out. yes cutting the cups will help.
ob1monkey is offline   Reply With Quote
Old 02-04-2014, 11:31 AM   #28
lolife99
67-72 parts collector,…
lolife99's Avatar
Just don't cut the cup too much.
It needs to set solid in the lower a-arm
I've heard 1-5/8" is the minimum total height.
Any less and it will rock around in the a-arm.
Keith
Convert to disc brakes.
Old 02-19-2014, 07:30 AM   #29
Bearcamp
OK did find out that my ball joints are binding. What can I do about that? I noticed that when raising it from aired out to full up when it first starts going up I hear a clunk on both sides. I am going to cut my cups to 1 5/8" and should I weld them in or just let em set in the frame?
Bearcamp is offline   Reply With Quote
Old 02-19-2014, 01:44 PM   #30
Bearcamp
I'm looking at pie cutting the uppers. Read a lot about the upper ball joints binding up n seems like it might be the answer. Anyone ever do it?
Old 02-20-2014, 10:31 AM   #31
Matty Wagz
Matty Wagz's Avatar
i don't have any cups on my a arms, just plates top & bottom; bump stop perch gone... dropped spindles.
just put the 17" vette wheels on the front and 18" on back.
i have no issues with fender/ inner fender clearance and have full steering travel even when aired out.
good luck putting her on the ground, my lowest point aired out is my lower a arms.
WAGZ
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally used up and worn out, shouting '...man, what a ride!' GC
Matty Wagz is offline   Reply With Quote
Old 02-20-2014, 10:42 AM   #32
MadRatt
MadRatt's Avatar
WAGZ
Nice stance! I didn't think those wheels would look good on our trucks, but boy was I wrong! Those wheels look great! Nice job..
If you ain't living life on the Edge....
Your taking up entirely to much space!!!!
My 64 Stepper Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=586792
MadRatt is offline   Reply With Quote
