#26 |
Re: The mean lean
your passenger side leaf may be sagging. mine is. torque can do that
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
#27 |
Re: The mean lean
I thought if it was a sagging leaf the whole truck would lean not the body I measured the frame and bumpers their level.. So wouldn't that mean the bushings and mounts are shot..not the leafs I could be wrong I'm learning as I go
#28 |
Re: The mean lean
![]() Ive got that good torque lean too haha. A whole inch lower on the back right. wasn't like that months ago. |
#29 |
Re: The mean lean
look Under to see if the cab bushing is rusting tru the support and floor
#30 |
Re: The mean lean
Well I took of my grill and headlight bezels to look at radiator/body mounts the passenger side is all rusted out that's why the lean on pass side. Bad news but at least I figured it out.. How hard is it to swap out the radiator support? Do I have to take fenders off?
#31 |
Re: The mean lean
This is what I'm working with not good lol need a radiator support bad.. |
#32 |
Re: The mean lean
Ok so today I picked up a nice oem radiator support very happy as you can tell in the top pic mine has seen its day.. Well my question is how hard is it to remove and install one? It looks pretty straight forward or not...
#33 |
Re: The mean lean
passenger side be ok you can just get fat even out
#34 |
Re: The mean lean
Thanks great answer....
#35 |
Re: The mean lean
^haha!
Austin 1996 Chevrolet K1500 Silverado ![]() 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
#36 |
Re: The mean lean
Someone needs to have an answer to this lean... I want to figure it out befor my truck goes in for body work..
Will I ever finish my 1986 stepper.. |
#37 | |
Re: The mean lean
You may need to support the front of the fenders somehow. There will be a series of bolts (maybe 5 or so) along the inside of the rad support (engine compartment side) attaching it to the front of the fender inner, and then a couple bolts (two, maybe) at the very nose of the fender (headlamp side). Undo the rad support bolts at the frame, spread the fenders slightly and see if you can slip the rad support out. If not, then further dissassembly will be required. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#38 | |
Re: The mean lean
If stuff is not rotted: shim it. K
#39 |
Re: The mean lean
Well I bought a nice oem radiator support. Just did a little wire brushing and sanding finished with three coats of rustoleum semi gloss. I'm pretty happy with results.. Now all I have to do is install with new bushings and no more lean well that's the plan. |
#40 |
Re: The mean lean
[ATTACH]
Well this is before and after I changed rad supports. I couldn't wait any longer the MEAN LEAN was killing me so this morning I did it new bushings as well. I measured about ten times and no more lean it's totally gone the truck is nice level all four corners YESSS.... |
#41 |
Re: The mean lean
Sorry guys this is before lol |
#42 |
Re: The mean lean
I fixed my 65 c10 with a vintage and well worn coke cooler at the p.s. rear with 80 lbs of dumb bells in it ... level
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390 ![]() |
