#26 |
![]() Join Date: Dec 2013
Re: gas tank location
i just can't believe the justifications for not spending a couple hundred bucks to relocate a fuel tank when there are just nothing but benefits and the only down side is $. it's just one thing that should be fixed that if heaven forbid you had an accident and (by some strange chance ) your family got injured(burned or died) how would you tell their mother that you could have fixed it but didn't want to spend $300.00 .But you will readily spend $ to install 3 point seat belts ????? REALLY ? it's located inside a closed cab good luck getting out while on fire !
#27 |
Maybe even if the tank didn't explode in a crash what if you rolled it and it ruptured the tank possibly by the jack ect, or the outlet tube broke or filler became separated at that rubber hose? even if it didn't ignite i can tell you gas can still burn your skin by contact. Between that and also dealing with the smell (vapors) in the cab always made me nervous. Yea the smell is not nearly as bad now that i changed the filler hose but still, it always bothered me.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#28 |
still waitin on the documentation ??WHERE IS THE SMOKIN GUN??
your not provin a damn thing with your bigfoot type rants on exploding gastanks wild speculation of unproven facts with not one documented case over the past 45or so years aint enough to loose sleep over
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 02-09-2014 at 02:24 AM. |
#29 |
:popcorn:
Never seen, or heard of any car, or truck randomly bursting into flames from an accident that didn't involve some form of external tank, or improperly maintained equipment. The only photographic evidence I have seen came from mass media "special reports", and most of those were dis-proven as having been setup using pyrotechnics to achieve a desired result. The only times I have seen vehicle fires involved one of two things. Race fuel, including ethanol. Faulty electrics, including stripped wiring. Aircooled VW's were "notorious" for suffering from fuel fires due to old and worn fuel pumps. I know people who have only run factory style pumps, and NEVER had an issue. Not even in a rear end collision.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast! Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun. 1st BN 3rd MAR. '00-'04 ![]() |
#30 |
The original question posed here is what is worthwhile.
For cost, get a cab tank. It was already there the last 40 years and nobody spontaneously combusted. If you drive a lot like I do, throw a second tank in the bed or under it. It doesn't matter where you put it. It's gasoline. Unfortunately you started an argument that began a long time ago and is still raging for literally no reason.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
#31 | |
![]() Join Date: Sep 2010
#32 | |
#33 | |
all i get is fairy tales about it happing i want the proof
#34 |
well guys i think some people just perfer the orignalality of the oe tanks. too each there own.
I thought about makin a false filler neck in the oe spot(just too keep the look) and moving the tank. but because finding a complete bedside spare carrier setup for a stepper is tough i made the desion to nix my whole plan and put the spare where it belongs an use the oe tank. as for the risk of dieing because of my desion....i take that risk just driving on public roads everyday in anything i own.(put the phone down and drive!) i dont care for the filler in the bed floor.i've seen some pretty slick filler setups here on the board.i've also seen some rear tank setups that look way outa place back there. the oe tank never looks outa place and it has worked for 40 some years. to me the oe tank is part of the history/charater of these old trucks and mine will stay along with my lap belts. i think both grumpy and cliff have made there point here.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#35 |
The only one that cares about "proof" of blowing yourself up is YOU.. So get off of it... For me it is the fact of the Gas smell in the cab and when filling the truck the gas dripping down the side of a clean truck just sucks and getting in behind the trim... so mine will fill from behind the Tail light... another good solution for guys with 68-72 is the ole Rear marker light filler trick...
#36 | |
![]() Join Date: Sep 2012
#37 |
Look here at post # 6 http://67-72chevytrucks.com/vboard/s....php?p=4848474
I seen another example on here I'll see if I can find it. And post #25 on this thread http://67-72chevytrucks.com/vboard/s...d.php?t=117123 I'm all for doing what you want with these trucks and it is entirely up to the individual what they choose. I was burned in a gasoline fire when I was 8 years old, mine will never have an in cab tank.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear Last edited by Kennuck; 02-09-2014 at 10:57 AM. |
#38 |
As that I was never a fan of the tank inside either, this what I did, since I had the room, Had this custom made out of stainless that I had, for around $200.00
68 ![]() My other ride ,,, 07 Streetglide.. |
#39 |
Hey Glider we are practically neighbours, your two tone stepper looks interesting any pics on here of your build?
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
#40 |
I recently replaced my in cab fuel tank. Eventually I'm going to relocate it but I need to decide if I'm going EFI or not. No reason to make that move right now since my tank is brand new. Have been contemplating a Vortec upgrade but that seems super costly.
James B. 1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful) 1971 Chevy Fleetside Shortbed 4X4 (White & Rough) |
#41 |
@ glider, that is a really nice setup. I have been looking at in bed tanks for a few years now but at over $1,000, it is a bit much to come up with. I need to do something, 20 gallons just isn't enough when I am pulling my trailer.
#42 |
I know this post is old but I used to date a girl and her aunt , uncle and cousin all died in a 1972 chevy truck in 1987 in Glasgow Ky. They was T-boned right in the driver cab side on 31 E south of Glasgow - the tank didn't explode but it busted and fuel soaked all of them. They burned up in the cab. The truck was an orange and white long bed with white spoke wheels. Ill never forget it. I believe when its your time its your time but this accident happened and I don't have to prove anything to anyone.
#43 |
Foolish Mortal
I'm still waiting for a reply to my original question-specifically: Do all the relocated gas tank kits only allow you to fill from the bed, or is there a way to route to the original 'side location' where the tank was inside the truck?
#44 |
#45 |
I'm would like to be able to show you what I am doing on my 72 short bed right now because I didn't like the idea of the fuel receiver being in the bed but iam having trouble uploading pictures I went to the wrecking yard and got the whole filler Assy. From a 2002 silverado and put it in the left side panel any way let me try again to post some pics.
Posted via Mobile Device |
#46 | |
#47 |
How can I get more than one pic at a time?
#48 |
#49 |
#50 |
I worked on a 67 C-10 last week that the customer had left the factory filler neck in the cab and ran a pipe thru the back of the cab to the rear mounted gas tank. In my view it could have been made alot cleaner. But it worked and still had the old school look. Now I let my wife make the choice to move the tank for me. It made her feel safer in the truck and it gave me the option to get a better stero system. So to each there own. its your truck. Do what "YOU" want.
