#26 |
Re: Whats the cause?
Personally I'd take JAFSB any day of the week.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
#27 | |
![]() Quote:
An easy fix: drain oil & filter out completely & replace the pan plug & new filter. Pour a gallon of carb-cleaner(the soaking-, smelly kind)into crankcase & let it sit over a weekend. DO NOT START ENGINE AT ALL WHILE THE CARB CLEANER IS IN THE PAN. ITS FUNCTION IS JUST TO SOAK THE PAN-AND-SCREEN AREAS & SOFTEN UP/DILUTE THE STOP-UP-PARTICLES; THEY ARE NOT UP HIGH IN THE ENG., BUT DOWN IN LOWER PAN AREA. After weekend has passed, then drain the oil pan 'containment' completely, kinda like overnight. Re-fill with a detergent oil , start it up & let it run until it reaches oper. temp., and drive it** about 12-15-18 miles--drive it about 45-50 mph tops, ensuring you vary the speed up and down (20-30-40-50-40-30-40-50, etc., as if you want to get poor gas-mileage. Bring it back and immediately drain it again, filter et al, while it is still HOT. Let it drain overnight. Re-fill with good oil & filter, and repeat the 12-18 mile trip--speeds et al. Come back & immediately drain oil & filter again--leaving it to drain overnite again. Next day, fill with good oil & filter again. Test drive & listen for noise--it hopefully is now gone. **If it makes the death-rattling sound, pull over & stop for a few minutes. Re-start, & continue the drive if the sound has quieted. Again, if it becomes noisy, repeat the pullover/stop for a few, and re-start & try again. Etc. May take a while to make it the entire trip--but I sincerely doubt it will.** This procedure will not harm your engine as long as you do not accelerate hard, pull hard hills, over-rev the eng, or keep driving if death rattle is yelling to "give me a few minutes' rest while the blockage drops off my screen". I've used this procedure several times, on 300/six-Fords, 3.8 GM FWD V-6's, Chev V-8's, Olds 260/350/455's, Pont. 301's and 400's and 455's, Buick 350's and 455's, Nova 250(230?) six's, slant-6 Mopars, and probably a couple others. Never had one fail to respond favorably; and on some, I saw them continue running well for several years afterwards. Good luck to you. Let's hope this one guess(of many possible ones) was a lucky one & that the success rate continues. Bear in mind, it's as difficult to diagnose on-line as it would be to diagnose a dog's symptoms--his hurting belly could be a bruise? or a ruptured spleen? or he ate green apples? or he was a she, & was pregnant? Maybe you might let us know your outcome. A more proper method if the diagnosis-guess was correct would be to pull the pan, clean it out(using carb cleaner would work then, but cheaper & just as effective fluid could be found for that), clean out oil-return holes under valve covers, & replace the pickup screen AND oil pump. ###This method I described above just saves the labor: ever pulled a pan from a 300-six out of 65-75 Ford pickups??? Hafta just about completely remove the engine--so, in these Fords, this carb-cleaner method could save a $2000-job!### Again, good luck to you. This system works if you work it!!! Sam |
#28 |
![]() Join Date: Oct 2012
#29 |
We are all entitled to our own opinions.
#30 |
Yep...but mines always right! Had a 64 with a V8 so its difficult to hate....would still have it/be driving it but for some Illegal Aliens. But, overall the 65 with I6 is the better choice for daily use.
#31 | |
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
#32 | |
Chevy addict
X2 As a side note, I have also heard similar sounds from a loose flywheel. |
#33 |
![]() Join Date: May 2007
leave sharps alone, not only did he give a how to on blowing up a six he also told us how to buy a new one and spend a couple months tinkering with oil leaks.
![]() buddy I am just playing sharps, peace!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#34 |
Dayum cheep gasoline! Now I only buys good gas but I still gots leaks. If it wassa an 8 itd have even more spots ta leak! Betcha I coulda cracked 6 pistons simultaneously inna 8! Never gotta chance though cause bandits got my 8 first.
#35 |
Post Whore
![]() Join Date: Mar 2013
Hey guys....I am not trying to be a control freak here...but this thread is 2 pages long...and the original poster has not responded. I say we let this thread die until he returns with his progress. My buck and a half.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#36 |
He's prolly feelin crushed. Just bought his first square body truck and right quick it starts to death rattle. I know how I felt when Ol John Lee died and then when I blew an engine in the replacement truck. Its lika kick in low hangin fruit.
#37 |
I've talked to him several times away from the forum. Even tho I was a bit harsh at first.
We're planning on bringing his truck to our shop to find out what's really going on with it and see if it is terminal or not. Since talking with him, he's a good young man, just working a lot and trying to get into the hobby. A lot of people here, including myself, think we're "experts" and need to stop an realize we all started at the same place. |
#38 |
#39 | |
Post Whore
