Old 02-19-2014, 01:40 PM   #26
grs
Re: HEI Problem
Originally Posted by grs View Post
I will run a 12 gauge wire with 12 volts tomorrow. How can I check the module?
I got it running. I hooked a 12 gauge wire to the Fuse box. I found a spare terminal. Would I get more voltage off of the switch?
grs is offline   Reply With Quote
Old 02-19-2014, 01:40 PM   #27
Rich 5150 69
Rich 5150 69's Avatar
Re: HEI Problem
Originally Posted by T.J. MCCAULEY View Post
Ok...I'll try that. Yer talkin to someone who is electronically illiterate...well..maybe not That bad...but...lol! Thanks.
Tie directly in the pink wire from your iginition switch straight to the HEI, thats how mine is 22 years ago.....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 02-19-2014, 02:16 PM   #28
Sharps40
Re: HEI Problem
You can tap into a full 12 volts easily at the fuze box using one of the "Ignition Unfused" terminals. Or you can tap a full 12 volts from the ignition switch as indicated.
I believe you can then eliminate the wire runningh from the starter to the dizzy...
I'm guessing with full time 12 volts you are 97% percent fixed.....after that, with luck, it'll simply be inspection and tuning.
Sharps40 is offline   Reply With Quote
Old 02-19-2014, 08:58 PM   #29
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: HEI Problem
Rich...is this the pink wire you are talking about???? 1st picture. Second picture....I noticed on my fuse box where my finger is pointing..it says "Ignition unfused" will that supply enough voltage to the hei? And or work?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 02-19-2014, 09:06 PM   #30
Rich 5150 69
Re: HEI Problem
The pink wire from your ( after ) ignition switch, anything before that is not swtched...back of your switch will be marked ign or run.
This pic from Cragers post, ign post at the 11:00 position...
Old 02-19-2014, 10:01 PM   #31
gimmy 64
Re: HEI Problem
don't run it to your fuse box extra terminal. follow the pink wire back to the fuse box and install it there. you may have to remove the fuse box+
gimmy 64 is offline   Reply With Quote
Old 02-27-2014, 12:33 PM   #32
AMERICAN PICK-UP
Re: HEI Problem
Bump
AMERICAN PICK-UP is offline   Reply With Quote
Old 02-27-2014, 12:39 PM   #33
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: HEI Problem
Well...my new HEI works like a dream. I ended up hooking it to the starter solenoid. Works great, burns the fuel no issue. Plugs are now running a tad hot, but since I run 92 octane I should be fine. All the wiring around the valve cover and by the starter has been loomed up since the picture was taken.
Old 02-27-2014, 02:21 PM   #34
grs
Re: HEI Problem
Why are you using 92 octane?
Old 02-27-2014, 02:25 PM   #35
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: HEI Problem
When running a hot spark, and big carb..you want as much octane as possible. Especially when your spark is advanced. Low octane will cause pinging or detonation, which will result in severe engine damage. Older engines like high octane low ethanol. I run 92 E10...which is highest you can get for under $4 per gallon...we have a station that sell 100 octane...but its at over $5 per gallon. Anytime you run a performance engine or performance parts on your engine...running better fuel always pays off.
Old 02-27-2014, 02:30 PM   #36
grs
Re: HEI Problem
I use Shell high octane in my new cars once in a while. It cleans the fuel injectors.
Old 02-27-2014, 07:47 PM   #37
Irishbleueyes
Re: HEI Problem
Nice engine TJ, whats your compression ratio?
Irishbleueyes is offline   Reply With Quote
Old 02-27-2014, 10:43 PM   #38
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: HEI Problem
Bout 95 in all cylinders last I checked. Brand new from factory was 8:0:1...and that's MAYBE 130 pounds....so...runs good.
Old 02-28-2014, 07:59 AM   #39
brokenspoke
brokenspoke's Avatar
Re: HEI Problem
The spare terminal is best IMHO
brokenspoke is offline   Reply With Quote
