#26 |
Re: 1980 Stepside Build... My first build thread
I also tried something a little different, and would like to hear your opinions (good or bad). My truck came with a square tube chrome grille, and I absolutely hate these. I really want to put a 73 grille and headlight surrounds on it, but thought I would try a little creative work on what I already have first. Let me know what you think!
#27 |
Whoops, forgot the pic...
#28 |
Last nights CL score! Everything I need to turn it into a 73!
Only $40! |
#29 |
Started by polishing the bezels last night
#30 |
Installed the brackets, cleaned and reprinted the grille...
#31 |
Re painted the bezels.
#32 |
And finally, installed everything and gave it a final polish. Even cleaned and polished the turn signal lenses.
#33 |
The bow tie looked a little naked, so I filled it in with some carbon fiber print vinyl that I had left over from another project
#34 |
I am so happy with the way this turned out! Looks soooo much better than the 1980 bezels and tube grille.
#35 |
Now - on to the driveshaft. When I flipped the rear axle, I had to move it to the rearmost position on my perches (they have three holes) just to get the driveshaft to squeeze in. It was so tight, that any large bump could cause the shaft to bottom out in the transmission.
So I took 1.5" out of it. |
#36 |
All welded up, and ready to go back in!
#37 |
After that, I got hungry and gave up and went inside. Tomorrow I need to shift the rear axle forward, build a throttle cable bracket, and maybe clean up the mess in my shop...
#38 |
One more shot head on
#39 |
![]() Join Date: Dec 2012
The grille looks great. Good job sir. I look forward to seeing more.
I don't care how old or gangster you think you are; if a 3 year old hands you a play phone you answer that! I like long walks on the beach, dinner by candle light, and poking dead things with a stick. |
#40 | |
[IMG]
![]() Quote:
OLD SCHOOL LOW: 78 Short Wide Heavy Half-Ratty Rod at moment. Old 4blt stroked to 383 Vortecs, Weiand, Scat, Hedman 1 5/8, Howards Roller, .495/500, Scorpion. Leaf flip, cut coils. Make do tires and wheels for now. Slip ahead a year? Sold GMC, bought Harley, got all obsessed doing the biker thing, now starting again w 65 SWB, 283,2bbl, 3 on tree. |
#41 |
The spring perches I bought are aftermarket (don't remember brand). As with most aftermarket perches, they have three holes for the spring centering pins. Center, and approximately 3/4" front and back from center. Allows for a little fine tuning. In my case, I had to slide the axle back one hole when I flipped it because my driveshaft was too long. Now that I have shortened the shaft, I can put it back on center.
I recognized your truck when I opened this up. I have been watching your build thread also! |
#42 |
This is aafter axle flip, sitting on ground. Look alright? Perches I used are Jegs #60195 w only center hole.[IMG]
#43 |
Looks about like mine did. How much travel do you have before it bottoms out in the trans?
#44 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Old School Low, I posted in your build thread about lowering stuff. Maybe it will help a bit.
#45 |
No one to bounce while I look at the moment, but I have so little travel dont think it could move more than 1/8 in. If thats the case, does it look ok as is? I am back to stock shackles but might go to first hole on extended. I like lowww (but still hoping no notch). Yeah but your exhaust is clean ghetto. I wont even show u mine, but it might be in prev photos. All will be sanitary w engine swap. Next door neighbor is not friend at all but is a mechanic and has agreed to take existing 350 as payment for doing swap. We're outside and snow and freezing for next few days. Can barely see my motor anymore with coats, hats etc hanging all over it.
#46 |
I have 5/8 thread left on shim bolt. I want to try using all that up w shims to try and correct camber. Or a solid spacer? (i need to sell something and buy DJM drops for 229.99 huh?)
#47 |
Old school - what I'm asking is if you unbolt your joints from the rear diff, how far can you push the driveshaft into the transmission before it bottoms out? In my case, there was barely enough room to actually remove the driveshaft - nod it could only be removed if it was turned "just right"
#48 |
Well, dont know at the moment. Does shiny area tell us anything? Looks like 1/2in from bottoming into tranny.
#49 |
Got my axle recented this morning, and took it out for a short test drive. Still some minor bugs to sort out, but it's working pretty well,
#50 |
Got a pic at the bottom of the hill
