02-17-2014, 07:50 AM | #26 |
Re: How Low Can I Go??
02-17-2014, 08:24 AM | #27 |
MashTheGas72, Like 19GM71 I will be purchasing through ebay as well. I see them listed quite often.
02-17-2014, 09:56 AM | #28 |
The frame I bought from Hart Rob came with a 4/6 drop. I want to use my truck as a truck and don't want to butcher the frame,so will be swapping bags in place of coils on rear. I also like having the option of running the more traditional hot rod rake when the mood strikes,which is actually just equally lowered front and rear/stock stance but lower.
Greg,that's the rule of thumb...The rear sits 2" higher in stock form. I believe that's what the original literature shows as well. So,you are talking about a 1 1/2" difference which will give a 1/2" rake(?). Would that be detectable? I doubt it. Whenever you lower the rear on coil spring trucks it offsets the rear to the right. By 3-4" it is noticeable. You would want an adjustable panhard bar to center the rear. The other rule of thumb is up to 4" drop+ adjustable panhard/4"+ = Super Trac bar,which actually relocates mounting points to keep the bar at an effective angle.
02-17-2014, 11:34 AM | #29 |
CAN'T FIX NOTHIN
I got the whole kit from cpp springs front and rear sway bars track bar all 4 shocks and rear shock relocation brackets best I remember it was ?? $800 ?? Or so ?? I am well pleased with the partts and for a beginner they come with insrtuctions too ,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
07-07-2016, 09:21 PM | #30 | |
Any rubbing issues front or rear?
-RafaeL |
07-09-2016, 07:27 PM | #31 |
4" spring drop in back is the max be for you need a adjustable track bar
