Old 02-17-2014, 07:11 PM   #1
survivingalone
14 bolt rear disc brakes with eldorado calipers
i have a new cucv 14 bolt ff axle. 4.56 gears detroit locker. im looking to add discs brakes. i want to use the eldorado calipers with parking brake levers. anyone have this setup? how did you run your emergency brake cables? did you use factory? were they long enough? did you fab brackets? can you post pictures of your setup? i want to see the hardline to softline setup as well as the emergency brake lines and how they are run/attached. thank you...
survivingalone is offline   Reply With Quote
