02-23-2014, 03:32 PM | #26 |
Re: 67-72 C-10 Parts
67-72 Chevy C-10/C-20 Parts;
Cab Corners both sides - 15.00 ea SOLD Rear Pillar Repair both sides - 15.00ea SOLD Left Side Rocker - 15.00 SOLD Left Side Inner Floor for Rocker repair - 60.00 this one is 51" long SOLD Door Vent Window Assemblies Left and Right - 100.00 for pair Vent Window Gaskets New - 35.00 for pair Rear Glass - 25.00 Trailing Arm for Rear-end with new u-bolts - 120.00 pair SOLD Stock Automatic Cross-member - 50.00 Stock Front Disc Brake Spindles - 60.00 for pair SOLD Power Steering Pump with bracket - 40.00 SOLD Brake Booster - 45.00 came off big block truck Disc Brake Proportioning Valve - 45.00 SOLD New Stainless Steel pre-bent brake from master cylinder to frame - 40.00 SOLD Polyurethane Cab Support Kit - 60.00 NEW from Energy Suspension see PIC's SOLD Rebuild Lower Control Arms with new ball joint/bushings - 120.00 for pair SOLD Fan Shroud V8 with AC - 50.00 2 barrel Air Cleaner Assy with riser - 30.00 4 barrel Air Cleaner Assy with riser - 50.00 2 core radiator retainer/upper mount - 15.00 pair 4 core radiator retainer/upper mount - 20.00 pair and other misc parts Last edited by Gulf Rat; 04-02-2014 at 08:53 PM. Reason: update prices |
02-23-2014, 04:22 PM | #27 |
updated prices and more - pics
02-23-2014, 06:32 PM | #28 |
Looking for a automatic steering column.
02-24-2014, 04:14 PM | #29 |
New Stainless Steel pre-bent brake from master cylinder to frame - 40.00 how mush shipped to 42223?
02-24-2014, 08:42 PM | #30 |
67-72 Chevy C-10/C-20 Parts; make me offer...stuff needs to go.
Cab Corners both sides - 15.00 ea SOLD Rear Pillar Repair both sides - 15.00ea SOLD Left Side Rocker - 15.00 SOLD Left Side Inner Floor for Rocker repair - 60.00 this one is 51" long SOLD Door Vent Window Assemblies Left and Right - 100.00 for pair with new gakets Vent Window Gaskets New - 35.00 for pair Rear Glass - 25.00 Trailing Arm for Rear-end with new u-bolts - 120.00 pair SOLD Stock Automatic Cross-member - 50.00 Stock Front Disc Brake Spindles - 60.00 for pair SOLD Power Steering Pump with bracket - 40.00 SOLD Brake Booster - 45.00 came off big block truck Disc Brake Proportioning Valve - 45.00 SOLD New Stainless Steel pre-bent brake from master cylinder to frame - 40.00 SOLD Rebuild Lower Control Arms with new ball joint/bushings - 120.00 for pair SOLD Fan Shroud V8 with AC - 50.00 Gas pedal with throttle control..rare option 2 barrel Air Cleaner Assy with riser - 30.00 4 barrel Air Cleaner Assy with riser - 50.00 2 core radiator retainer/upper mount - 15.00 pair 4 core radiator retainer/upper mount - 20.00 pair and other misc parts Last edited by Gulf Rat; 04-02-2014 at 08:51 PM. |
02-24-2014, 09:30 PM | #31 |
did the cab corners and rocker , pillar repair pieces sale , put in line if not
02-24-2014, 09:36 PM | #32 |
I will take all the repair panels-PM sent- Thank YOU!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
02-25-2014, 07:56 PM | #33 |
low n' slo
sorry, gonna pass on the shroud. thanks anyways
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
02-25-2014, 08:10 PM | #34 |
02-25-2014, 10:02 PM | #35 |
pics of the auto x-member?
Payment sent-might want x=member...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 02-25-2014 at 10:17 PM. |
02-25-2014, 10:22 PM | #36 |
More pics, x-member..vent windows, and rare gas pedal with throttle control.
02-25-2014, 11:15 PM | #37 |
Still have control arms?
02-25-2014, 11:21 PM | #38 |
02-25-2014, 11:39 PM | #39 |
Do you have pic?
Do you take PayPal and ship to 30273? |
02-26-2014, 07:39 AM | #40 |
02-26-2014, 09:49 PM | #41 |
Pics of lower control arms
02-27-2014, 09:50 AM | #42 |
Haven't forgot about you looking at a x member from a 71.
02-27-2014, 09:58 AM | #43 |
Same x-member I already have. Thanks.
02-27-2014, 10:29 AM | #44 |
I know they aren't on the list ,but do you have a headlight retaining ring ,windshield wiper motor ?
1972 Custom 10 LWB 1973 V8 Vega wagon 1925 Model T Wrecker 1913 Model T Speedster http://s181.photobucket.com/albums/x...07/72skoolbus/ |
02-27-2014, 10:01 PM | #45 |
02-27-2014, 10:03 PM | #46 |
Door Vent Window Assemblies Left and Right - 100.00 for pair with new gakets Vent Window Gaskets New - 35.00 for pair Rear Glass - 25.00 Trailing Arm for Rear-end with new u-bolts - 120.00 pair SOLD Stock Automatic Cross-member - 50.00 Stock Front Disc Brake Spindles - 60.00 for pair SOLD Power Steering Pump with bracket - 40.00 SOLD Brake Booster - 45.00 came off big block truck Disc Brake Proportioning Valve - 45.00 SOLD Rebuild Lower Control Arms with new ball joint/bushings - 120.00 for pair SOLD Fan Shroud V8 with AC - 50.00 Gas pedal with throttle control..rare option 2 barrel Air Cleaner Assy with riser - 30.00 4 barrel Air Cleaner Assy with riser - 50.00 2 core radiator retainer/upper mount - 15.00 pair 4 core radiator retainer/upper mount - 20.00 pair and other misc parts Last edited by Gulf Rat; 04-02-2014 at 08:50 PM. |
02-27-2014, 10:29 PM | #47 |
$80.00 plus shipping for controller arms
02-28-2014, 12:52 AM | #48 |
Still have ps pump and bracket? Is it for a short water pump?
02-28-2014, 07:45 AM | #49 |
02-28-2014, 09:25 AM | #50 |
