02-24-2014, 10:48 PM | #26 |
Re: 1964 C10 db on 22s
Frame shortened so we couldn't help but set the bed on it to see how she looked. ...... but now we have wheel fit issues
02-25-2014, 01:45 AM | #27 |
What are the fit ment issues? Hope they aren't like mine
02-25-2014, 10:28 AM | #28 |
haha mine arent at the top of the bed ... I dont think. When this frame was started it was ment to go into a 2001 silverado now that it is going into a 64 there is some width issue. even though it is .5 inch more narrow than the stock the wheels wanna hit the bodyline even with our negative camber. in the pik you can kinda see our wheel addapters. well those make the vette 5 lug convert to the big 6. problem is they are 3 inches wide each. what we have had to do is switch from vette hubs to trailblazer front 4wd hubs(same spline count as a vette) but they are small 6 so we had a piece machined to addapt the hubs. i will post piks of all of that process here in a little bit
02-25-2014, 07:54 PM | #29 |
I'm looking forward to seeing this the caliber of the work already done I'm sure you'll get everything to fit
02-26-2014, 11:31 AM | #30 |
Nice build Jwalters!
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
02-26-2014, 04:13 PM | #31 |
Thanks guys ill upload a bunch more piks later to show our width prob and solution
Last edited by j.walters; 02-26-2014 at 04:18 PM. Reason: PIK WAS SIDEWAYS AGAIN |
02-26-2014, 09:05 PM | #32 |
Trying to gauge just how much fender we will have left....
02-26-2014, 09:18 PM | #33 |
Ok, so being originally built for a 2001 silverado we had a few clearance issues. First was the vette rear independent with the 01 the width was fine. However on the 64 was a little skinnier. When we srtarted the standard adapter worked just fine. But bieng almost 6 inches thick we were back at square one. Through lots of research and some dumb luck.... and working at a GM collision center we found that AWD trailblazer front hubs have the same drive splines as a Corvette. But the lugs are 6x5 and we needed the big chevy 6. Well with a little ingenuity and a machinist we came up with these. I also included a pik of new by the old adapter.
02-26-2014, 10:36 PM | #34 |
Great fabrications.
02-27-2014, 12:40 AM | #35 |
Super cool build man
02-27-2014, 01:01 AM | #36 |
Thanks guys, we are hammering away on the ls swap now ill upload piks asap
03-01-2014, 09:31 PM | #37 |
Fixing a little rust on the fender. Full of good ole Mississippi red dirt.
03-01-2014, 11:20 PM | #38 |
Finally got the rear hubs on and the 22s tucked under the bed. Tuckin all 6
03-01-2014, 11:22 PM | #39 |
Just a lil tight
03-01-2014, 11:25 PM | #40 |
Remaking body mounts and separated the two to do some finish welding and send out to be blasted
03-01-2014, 11:27 PM | #41 |
Nothing sexier than 4 wheel neg camber
03-01-2014, 11:32 PM | #42 |
Little margin for error
03-01-2014, 11:34 PM | #43 |
Trimming off the front so we can get to building a new rad support
03-01-2014, 11:37 PM | #44 |
Cantilever timed in and cab stripped and wheels all tucked in for the night
03-02-2014, 12:30 AM | #45 |
Anyone ever shave the drip around the firewall? If so did you weld it solid all the way around?
03-02-2014, 12:07 PM | #46 |
Nice fab work, looks great. I can't believe the condition of that bed, I WANT it.
03-02-2014, 12:12 PM | #47 |
Ya that's kinda why we are going a little bit overboard on some things cause we don't have the cost of replacing sheet metal. We will see though the cab is going to the sand blaster this week.
03-02-2014, 12:35 PM | #48 |
This truck came from Mississippi and is amazingly really rust free. A couple pin holes in cab corners and thr lowers on the front fenders. We were really fortunate to find this in Missouri in this shape.
03-02-2014, 04:40 PM | #49 |
WOW!!! Is all I can say!!! This is one amazing build. You guys are absolutely killing it!!
03-03-2014, 12:17 AM | #50 |
Thanks. We have a ton of work to do but we have some really good guys helping.
